i hope so because i am ordering one lol
Latest blog entry: Estes Rubber Band Condor gets powered...
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
Making ya work eh SP?
If I have to repeat myself, yes...
![]() So you decided to give your Solo Pro a go again, after a little "cool down period"? Glad to have you back on board, and I hope you for once start having luck with the next board you install in your heli. I am starting to believe they send you faulty items on purpose, treating you as a heli part dumpsite... ![]() Btw, for those that are going to try the Hobby King 150 mAh NE connector type battery, these need a few cycles to "get going". On some batteries I could only fly around 4 minutes before the heli started spiralling down, but a few cycles later I got a full 5 minutes from them, with enough power to land. I also need less right trim to hold the tail than in the beginning. Voltage when coming from the charger has also improved. Some would not get higher than 4.18V freshly charged, and drop to 4.15 soon after that, now they read 4.24V and drop to 4.22V at most. Guess that explains the difference in tail trim, higher voltage means better tail reaction. Seems like these 150s come from a different source than their 120 mAh alternative batteries. Those were at full performance right from the start, giving over 7 minutes in the Solo Pro. Just hope the 150s have the same life expectancy as the 120s then... |
Hi,
did it - removed the canopy without damaging - did not disassemble the tail part. For those who wanna see inside of the Bravo SX and the difference to the Solo Pro: There is only the light, and the main frame, and the longer tail as difference to the Solo Pro. Main motors seem to be the same, tail motor of Bravo SX is bigger. Walter |
Today I also received my MIA Microflight S300 kit, which I have ordered for one of my Solo Pros some time ago.
But as a Bravo SX was already opened, I thought, try to take a Bravo SX for the mod. But I took a Solo Pro RX (without light). Had to do some modifications at the main frame for mounting the tail and the canopy. Never thought, that this would work so well. The Bravo SX MIA S300 flies SUPER! Even more stable than the Bravo SX! Only flew some small batteries till now (from my Eflite S300), so flight time is not "that good" yet. Nearly as good as the flight stability: The S300 Bravo SX is not that noisy as the Bravo SX You can hear it on the video (also made a video when flying with one hand and filming with the other one - but this ended in a slight cras which I do not want to publish ).
Some pics: I am really thrilled of the Bravo SX MIA Microflight S300! - Bigger, better batteries will be a further improvement. Guess, also will improve the "end of the tail" (with a rubber or whatever - tail is too long for the MIA tube). Walter |
Nice pictures and a well succeeded conversion on the MIA kit.
As for the main motor of the Bravo SX, it has a different part number than the Solo Pro motor, so it should be different: Nine Eagles Solo PRO Motor - NE4902002 Item Id: NE4902002 Bravo SX Main Motor Item Id: NE402320013A |
Btw, what is the weight of the MIA Bravo SX? And can you make bigger pictures of the frame? 800 x 600 doesn't show much details. And a video on how to remove the canopy without damage would be awesome, I think many will be struggling with that. |
Hi,
I think, a video of removing the canopy is not useful. I have to admit, that in this (the blue) Bravo SX the front shield was already gone in two halfs, so this was not a problem any more (kissing the wall...). This could be a major problem in a very new Bravo SX (did not try it on another one than the dark blue one). The tail is not really a problem, because one can bend the lower part of the tail and the canopy, so that the heli can be taken out - I even did not have to remove the rotorhead. |
