Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
Hi,
The Hyperion seems to be much heavier than the Zippy, 7 g to 5.3 g... Anyway, I will try it when available (but not for 10 bucks). Walter |
And speaking of improvements, I would like to see the following things on the Bravo SX 2, should it ever come: - Gears with smaller teeth, to address the noise problem. - Canopy that is easier to remove - Stronger or longer skids to prevent the heli from tipping over backwards when landing - Longer tail fin so tail rotor can't touch the ground when it tips over - Navigation lights switch, might help a little with flight times or make them switch color when the battery gets low. |
That would be possible, but the added weight of the switch and wires will shorten flight times even more perhaps than the lights do. I was thinking of an electronic switch, controlled from the TX. Even some cheap 3 channel coaxials have this nowadays...
I think they left out the switch to save some weight. The scale fuselage already adds a lot, and if it gets even heavier flight times will get shorter. Marconos, did you also try the Bravo SX tail on the Solo Pro? It should fit easily. I wonder if that will make it fly more like the Bravo SX, but without the short flight times and the extra motor noise... |
Hi,
The Bravo SX canopy has a different end of tail (open, with silicone), and four bulges at the top opening of the canopy (for swashplate connections), which the canopy of the Bravo III misses. The bottom opening is also shlightly different (Bravo III little wider to back), and the Bravo III has a kind of cap, which the Bravo SX canopy misses. Landing gears are interchangeable, but Bravo III has a 3-pin plug + switch, which the landing skid of the Bravo SX has not. Walter |
Hi,
I guess, micro deans were 4.50 AUD... Nevertheless - we liked it (the Gaui starter is in the orange box in the back - we bought it two weeks later): ![]() Walter |
