United States, IL, Park Ridge
Joined Apr 2010
Hi !
I think to match CG of Tri with CG of wing assuming CG of wing @ 25-30% of the chord. Probably best to test CG of wing before attaching Tri. Drawing is for constant chord wing but will work with any shape of wing as long both - CG of Tri and CG of wing are the same. \My first gyro only Tri was 100% stable (even I can fly it ) because was very well balanced.Tom |
Joined Apr 2010
Hi Rev !
100 % right - but easiest way to start is :"when all three motors and props are the same" Tom By the way - do You have any formula to calculate CG for diferent size of rear motor/prop. or size of motor/prop. foc particular CG ? - loks I will need it for my Bi. Thanks |
I don't know if you guys have seen this video but it may not harm to review it.
This is where the airframe puts the CG on my tri currently.
Good to see that again. Looks like his pitches up also when he goes from ForwardFlight to HoverFlight modes. Looks like he also gives some down elevator control from HF to FF to prevent the nose from pitching up. So basically I think I'm having the same issue except I have less forward pitch power since I only have one motor in the back, the rear motor is closer to the cg so it has less leverage and there is a bunch of wing area in the back making the rear motor even less effective. |
You also have a lot of "spare thrust" from the front motors, seeing how far forward of the CG they are. Have you tried to throttle back the front motors through conversion while keeping the rear one near max?
[edit] or you could add a canard and shift the CG forward |
I like the canard idea if they go in front of the motors and extend out a little further than the props to help guard against prop strikes. That's almost an entire wing length though but I'll keep it in mind. |
Almost got the servo movement set up perfectly.
The only thing is that the front right servo doesn't travel far enough. When the servo is pointed up or forward it stops moving even though there is still a little stick movement left. It's noticeable the most when the servo is forward and is commanded down with the pitch stick. Attached is the code drop I'm using
Thanks. The work we are all doing is really opening the door to some cool possibilities for us all
![]() If anyone is interested, I've tried to make the ISR portion of the servo code a little easier to use by separating it into separate code chunks that we can copy and paste with minimal changes if we want to add more servos. The current method is a little tangles up for this newb to read. This currently isn't working good though. The (DIGITAL_MOTOR_TILT) section works fine. It's stretched and centered good but the (DIGITAL_TILT_PITCH) section results in a servo that is pointing forward instead of at the desired 45 degree default position and doesn't seam to be stretched ![]() Code:
static uint8_t carry;
ISR(TIMER0_COMPA_vect)
static uint8_t state = 0;
static uint8_t count;
if (state == 0) ////////////////////////////// Start servo[5] DIGITAL_MOTOR_TILT stretching code block/////////////////////////////////////////
#if defined(VTOL)
DIGITAL_MOTOR_TILT_HIGH
#endif
OCR0A+= 150; // 500 us
state++;
else if (state == 1)
if (carry & (1<<5)) OCR0A+= 250; // another 1000 us
else OCR0A+= atomicServo[5]; // [0-1020] us
state++;
else if (state == 2)
if (carry & (1<<5)) OCR0A+= atomicServo[5]; // [0-1020] us // If servo rolls over, reset it and keep moving. Assign DIGITAL_MOTOR_TILT as servo 5.
else // Or move normally.
#if defined (VTOL)
DIGITAL_MOTOR_TILT_LOW
#endif
OCR0A+= 150;// 1000 us
state++;
else if (state == 3)
#if defined (VTOL)
#endif
state++;
} ////////////////////////////// End servo[5] DIGITAL_MOTOR_TILT stretching code block/////////////////////////////////////////
if (state == 4) ////////////////////////////// Start servo[2] DIGITAL_MOTOR_TILT stretching code block/////////////////////////////////////////
#if defined(VTOL)
DIGITAL_TILT_PITCH_HIGH
#endif
state++;
else if (state == 5)
if (carry & (1<<2)) OCR0A+= 250; // another 1000 us
else OCR0A+= atomicServo[2]; // [0-1020] us
state++;
else if (state == 6)
if (carry & (1<<2)) OCR0A+= atomicServo[2]; // [0-1020] us
else
#if defined (VTOL)
DIGITAL_TILT_PITCH_LOW
#endif
state++;
else if (state == 7)
#if defined (VTOL)
#endif
state++;
} //////////////////////////////End servo[2] DIGITAL_MOTOR_TILT stretching code block/////////////////////////////////////////
else if (state == 8)
count = 6; // 6 x 1000 us
OCR0A+= 150; // 1000 us
state++;
else if (state == 9)
if (count > 0) count--;
else state = 0;
OCR0A+= 150;
#endif
#if defined(SERVO)
atomicServo[0] = (servo[0]-1000)/4;
atomicServo[1] = (servo[1]-1000)/4;
atomicServo[2] = (servo[2]-1000)/4;
atomicServo[3] = (servo[3]-1000)/4;
atomicServo[4] = (servo[4]-1000)/4;
atomicServo[5] = (servo[5]-1000)/2;
if (atomicServo[5] > 255) {
carry |= 1<<5;
atomicServo[5] -= 250; }
else carry &= ~(1<<5);
if (atomicServo[2] > 255) {
carry |= 1<<2;
atomicServo[2] -= 250; }
else carry &= ~(1<<2);
#endif
| Thread Tools | |
| Discussion QTD- Quad Tilt Duino (Arduino- Tilt Rotor) | RCvertt | VTOLs | 100 | Jun 28, 2012 12:15 AM |
| Question Tricopter: What rear tilt angle? | bb42 | Multirotor Talk | 3 | Oct 15, 2010 09:40 AM |
| New Product The new Panther tilt rotor UAV from Israel Aerospace Industries | Hunter850 | Multirotor Talk | 2 | Oct 06, 2010 08:06 AM |
| For Sale Rc lander panther complete setup with metal edf/motor/esc/servos/retracts/battery | TurboFanElectric | Aircraft - Electric - Jets (FS/W) | 3 | Mar 25, 2010 08:29 AM |
| Sold RClander Panther 70mm Fan and motor | cjdscratch | Aircraft - Electric - Power Systems (FS/W) | 7 | Mar 13, 2010 10:31 PM |
