Old Oct 06, 2011, 02:35 AM
Straykiller is offline
Find More Posts by Straykiller
Straykiller's Avatar
Joined Aug 2011
Originally Posted by RCvertt View Post
FunJet parts haven't arrived yet so I built this in the mean time.
Getting closer to the original idea of this thread. Handles good in forward flight.
looks really good
Straykiller is offline Find More Posts by Straykiller
Old Oct 07, 2011, 03:39 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Originally Posted by Straykiller View Post
looks really good
Thanks. It's a lot of fun. Like V22 said, time to put the back motor in it now.
RCvertt is offline Find More Posts by RCvertt
Old Oct 16, 2011, 04:46 PM
EddieWeeks is offline
Find More Posts by EddieWeeks
EddieWeeks's Avatar
Baton Rouge, LA, USA
Joined Dec 2001
Flight test start with new airframe... Arduino hardware gave me fits because it can read 8 channels, but then it does not output more than one channel.. very strange... Did a workaround with just 7ch...
This tri-copter uses the two 700 watt motors for yaw control and the 200 watt motor in the back is fixed.. The large motors are not using 700 watts with the 12x3.8 props.
Did a bit of hovering but needs more gain on all axis.
Eddie Weeks
www.jetlens.com
EddieWeeks is offline Find More Posts by EddieWeeks
Old Oct 16, 2011, 09:38 PM
ferdous7466 is offline
Find More Posts by ferdous7466
ferdous7466's Avatar
Joined Mar 2010
oh...eddie thought u got lost in the midst of so many guys. welcome back. and keep on doind things as u always do. waiting for progress report!!!
ferdous7466 is offline Find More Posts by ferdous7466
Old Oct 17, 2011, 12:45 AM
EddieWeeks's Avatar
Joined Dec 2001
Lots of test flight just now... This one does not fly right... Can not hover very well...
yaw and pitch problems.. I think pitch motor is too small... ordered a new one...
Landing gear too small... Plane is to close to the ground, this is bad for slow takeoffs.
Just lots of little problems... more to come
Old Oct 17, 2011, 04:41 AM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Originally Posted by EddieWeeks View Post
...I think pitch motor is too small...
Maybe you can cut the front motor power down a little or increase the rear or both.
Looks good. The idea of tilting the rear motor is interesting.
Old Oct 17, 2011, 09:13 AM
EddieWeeks's Avatar
Joined Dec 2001
The plane lifts off vertically but is not very stable in the pitch axis... Also the rear motor is getting very hot... The rear motor is doing its job but is not very responceive to my inputs, as compaired to the last plane which had a far larger rear motor.
Like most the way most things are fixed these days.. I will just change parts untill it works !!!
Eddie
Old Oct 20, 2011, 11:33 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Based on my experience with a quad design, I've tweaked the original design of this thread a little more. Nice big elevons, similar to the quad design, for high speed and especially low speed handling. They also negate the need for a front canard which helps keep the design simple. Just a single vertical stabilizer. This will keep the design light enough for standard retracts which I think will create less drag then the wheel pants idea.
...Like most the way most things are fixed these days.. I will just change parts untill it works !!!...
Sounds like a good plan.
Old Oct 21, 2011, 10:16 PM
EddieWeeks's Avatar
Joined Dec 2001
update... Plane flies better than the first one..
New rear motor did the trick.. Video to come..
Next step... Connect the ailerons, elev and nose steering, check balance and take off forward.. It’s a bit over powered… 500 watt x 2 on a light weight plane… I will take off in forward flight… Glide in for a landing, switch the motors vertically with them off and just land vertically. That’s the plan!!!!
Eddie
Old Oct 22, 2011, 07:54 AM
Joined Mar 2010
u r almost there eddie. egerly w8ing for result....
Old Oct 25, 2011, 09:49 PM
EddieWeeks's Avatar
Joined Dec 2001
I have been flying in the yard for a few days now... The plane is fine.. The pilot needs some work..
Going to transition next..
http://www.youtube.com/watch?v=mUU3IF6cu8k
Old Oct 25, 2011, 10:57 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Excellent Eddie!
leadfeather is online now Find More Posts by leadfeather
Old Oct 26, 2011, 07:50 AM
Joined Mar 2010
wow...thats great. its nearing that climax point eddie. Thumbs up. Go on with transition. Hovering will require a little bit attention probably?
Old Dec 08, 2011, 11:08 PM
Joined Mar 2010
No news on thek kite??? thats frustrating for like us followers
Old Dec 09, 2011, 02:43 AM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
I can't speak for Eddie but I put mine down to work on the quad rotor. Thought it would go together quickly like FoamAndTape's did but since my motor tilting is gyro controlled it's much more sensitive to vibrations which the big rear wing with motors on the tips likes to create. Looks like I've got a solution for that though so we should be back on the tri soon.
Discussion QTD- Quad Tilt Duino (Arduino- Tilt Rotor) RCvertt VTOLs 100 Jun 28, 2012 01:15 AM
Question Tricopter: What rear tilt angle? bb42 Multirotor Talk 3 Oct 15, 2010 10:40 AM
New Product The new Panther tilt rotor UAV from Israel Aerospace Industries Hunter850 Multirotor Talk 2 Oct 06, 2010 09:06 AM
For Sale Rc lander panther complete setup with metal edf/motor/esc/servos/retracts/battery TurboFanElectric Aircraft - Electric - Jets (FS/W) 3 Mar 25, 2010 09:29 AM
Sold RClander Panther 70mm Fan and motor cjdscratch Aircraft - Electric - Power Systems (FS/W) 7 Mar 13, 2010 11:31 PM
