Old Feb 08, 2013, 11:23 AM
disho's Avatar
United Kingdom, England, Durham
Joined Apr 2011
Originally Posted by Frank2351 View Post
Cheers Disho
I don't know how, but I left it as I was getting pxxxxd off with it. An hour later I plugged it in and it worked, but the orange reciever keeps flashing. If I rebind it the orange light goes solid, but when the battrie is disconnected and plugged back in it starts flashing. The only way I can keep it solid is if I turn my DX6i off then then plug the bat in and then turn the transmitter back on.
Disho
Did you find that with a 6 cell 3300 when held in an upright position and full throttle would it hover or did it slowly drop.
Mine slowly drops, but I recon if I gently threw it level it would be off like a goodun. Tommorow is forecasted 7mph winds, so hopefully a maiden.
Goodluck with the maiden try and get some video to compair with mine, ive got a couple of maidens this weekend weather permitting
disho is offline Find More Posts by disho
Old Feb 08, 2013, 01:13 PM
Joined Jul 2012
ME 626 is one of my favorite planewhat brand is that one ?
It looks great
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Feb 08, 2013, 01:26 PM
United Kingdom, England, Beverley
Joined Jan 2013
They look great.
What set ups have you got in them and were did you get the airframes.
Frank2351 is offline Find More Posts by Frank2351
Old Feb 08, 2013, 01:42 PM
Joined Jul 2012
They look great.
After a little research it looks like the Dynam ME 262 but I'm not 100%
Old Feb 08, 2013, 05:51 PM
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
Cheers Disho
Disho
this is normal behaviour for the orange RX's - the flashing light tells you it's lost power but has been reconnected.
the spark when you plug the ESC in is normal - that's the capacitors on the ESC charging up on initial plug in.
the high end ESC's will beep sometimes with the motor unless the RX is bound.
or if the throttle range hasn't been calibrated (usually the first thing you do after the first time you plug it in)
m_ark is offline Find More Posts by m_ark
Old Feb 08, 2013, 05:57 PM
Australia, VIC, Melbourne
Joined Nov 2006
That one is the Freewing Me-262. Almost double the cost of the Dynam Me-262, but it comes with a lot more stuff stock too. Both fly pretty much the same though.
The main difference is that if you want it to look as good as the Freewing one, the Dynam needs work... some airbrushing etc. But if the Dynam 'ok but nothing special' finish is OK for you then it is almost ready to go as it comes - both need some mods to improve shortfalls. (as per all foamies)
Dynam:
PeterVRC is offline Find More Posts by PeterVRC
Old Feb 08, 2013, 06:19 PM
disho's Avatar
Joined Apr 2011
They look great.
Thanks, the blue and white one is a 70m l39 its a fly fly kit, i have a few of there kits, it has the same set up as my t45 the twin is the new freewing me 262, also nearly got my f5e tigershark done that too has the same setup as my t45
Old Feb 08, 2013, 08:37 PM
Joined Jan 2013
Where do you get them from disho
Old Feb 09, 2013, 04:32 AM
disho's Avatar
Joined Apr 2011
Hi,got the f5e from ebay, and i use rc castle got the me262 and l39 from them check out the web site
Old Feb 09, 2013, 08:08 AM
United States, MS, Hattiesburg
Joined Mar 2012
I have a HK T-45 ordered and from what I have been reading here It looks like I need to buy an upgraded ESC. Can you order one with a Deans connector or is that something I need to do?
Thanks.
jmack007 is offline Find More Posts by jmack007
Old Feb 09, 2013, 08:59 AM
Joined Oct 2008
Does someon have a used fan for the stock T-45 ?
Hello everyone,
I have a T-45, stock setup, but the fan suddenly exploded (while i was running it at home).
I am looking for some spare fans (not the whole group, just the rotating part).
Does anyone of you have some to sell me ?
I already bought a new whole motor + fan, as it was impossible for me to find the fan only.
Here you can see the original fan :
http://www.ebay.it/itm/380364281432?...84.m1439.l2649
But i am still interested in having many spare fans ad hand, also for experimenting.
Also different from the original, but that can be used. They should be 64 mm in diameter.
Thanks in advance.
Best regards.
nick73 is offline Find More Posts by nick73
Old Feb 09, 2013, 10:24 AM
Joined Jan 2013
Well just got back from my maiden. CS 10 blade, BL32, nano tech 3300 35-70 c 6 cell and 80 amp ESC.
Oh yes I nearly wet myself with excitement. What a great flying plane and the sound is so turbine like. Everyone at the field could not believe it and it easy past our noise restrictions of 80 db as it came in at 74.
Cheers Disho, what a spot on power set up.
Old Feb 09, 2013, 10:30 AM
Joined Jan 2013
http://youtu.be/1r6sLHfeYAc?sc
Old Feb 09, 2013, 10:58 AM
Joined Jan 2013
Feb 9, 2013 (1 min 41 sec)
Old Feb 09, 2013, 11:04 AM
Joined Jan 2013
It flys very stable slow too
New Product F4D Skyray 64mm EDF by FMS Model, now at Hobby Lobby Joe 1320 Foamy EDFs 785 May 06, 2013 08:21 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
