Old Feb 04, 2013, 03:06 PM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
Originally Posted by civic06 View Post
Getting ready to start my T-45 build and have a question. I thought the higher kv the more rpms = faster plane. Disho's set-up looks like BL32 2150 kv not high RPM? What am I not getting..BTW Disho's set-up scoots. I understand more volts = more RPM but isnt 6s putting too much load on the motor?
Thanks for the replies.
Hi there
The BL32 can handle 6s no problem, even my HK alloy 10 blade 3000kv kv 4s fan can handle 5s
I did some static tests with that fan on 5s the results where impressive but I'm not sure how long it would last, the eagle tree datalogger said 105Amps @ 1942 Watts
It would probably be ok in short bursts, the lipo that i used is too big to fit in the T45 so i can't test it in the air
On 4s my T45 was clocked 205kph not too bad for a cheap fan
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Feb 04, 2013, 04:40 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
A motor is not a motor......
LOL
KV only means the RPM it will do per volt. It doesn't mean anything about what power the motor can handle.
For a given voltage, AND the load the motor has on it (what fan, prop etc), it will TRY to run a Speed X (dictated by KV), but only be able to reach "X divided by Y" according to its construction versus that load. The situation it is in will make is draw Z Amps.
For the exact same motor and situation (fan it is in) if you raise volts you will cause the Amps to rise. Power = Volts x Amps, thus power rises too.
If the motor was only made to cope with Power X, it will fry if you cause it to run (or try to run) at higher power - they will all keep going higher than they are truly capable of, for X amount... to the point they fry. Too much heat basically..... via too much current (Amps) through the windings.
So.... KV on its own means little.
What matters is a total of a number of factors.
If someone says they had a motor of X KV, and another person had another motor type of the same X KV, you still need to know WHAT were all the other specs of each motor, to know which will do what for a given cell count and fan use.
PeterVRC is online now Find More Posts by PeterVRC
Old Feb 04, 2013, 04:49 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Originally Posted by Quadmad View Post
Hi there
Thanks for the info, do you run a cheater hole? 205 is really moving, I guess this airframe is slicker than I thought.
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Feb 04, 2013, 04:50 PM
Joined Nov 2006
Those HK 10-blade alloys are Lander DPS fans. HK tend to list the correct lander specs for those (most HK numbers are wishy washy 'made up' specs. eg for other motors etc)
The 4S version is likely to be a 2950 motor (6S are 2960), I forget.
Typically capable of around 1000W.... but you can burst them out to higher some amount.
1000w/14.8v = 67Amps capable. Even that is a number that a 2950 (or even 2960) motor won't like long term. I would say by about 80Amps or so the windings are not going to be too happy! Getting very hot due to that current through their relatively thin gauge.
You would not really want to even burst run them through 80Amps much at all.
105Amps is very high and getting into the region of "Instant death"... windings fry in a split second!!
Irrespective of an alloy housing helping heat to be removed.... that is a slow long term process, and will not help fast instant heat problems... like running 80,,, 105 Amps will create.
They are a very nice fan unit. A good motor. Plus a good price at least from HK. But you don't really want to fry and ruin one for nothing! So I wouldn't advise hitting numbers over that 80Amps area for very long at all, and preferably never.
Old Feb 04, 2013, 05:02 PM
m_ark is offline
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
More KV means faster spinning more for the same number of volts, but there are more factors than how fast the motor spins. For example, number of blades on the rotor - some people in this thread have "unloaded" the stock fan by cutting 3 alternate blades off.
Motor power is a combination of RPM and torque. In the ducted fan design, slower turning motors like 2000kv may be run on more cells (like 4 or 6) so that's more volts, less amps. Faster turning motors like 5000kv are usually designed to run on fewer cells such as 3. (comparably less volts, more amps)
There even exist motors with ratings like 13500kv designed to run on 1 cell, or 12,000kv designed for 2 cells.
m_ark is offline Find More Posts by m_ark
Old Feb 04, 2013, 05:03 PM
Canada, ON, Vaughan
Joined Oct 2009
I would agree, I probably wouldn't bother trying that fan on 5S.
Any ideas on how fast the 2200kv 6S version would get the T45 up to? I'm guessing a 2650mah or 3000mah 6S would fit and balance nicely.
Old Feb 04, 2013, 05:30 PM
Quadmad is offline
Joined Jul 2012
Yes cheater hole for sure
Old Feb 04, 2013, 05:42 PM
Quadmad is offline
Joined Jul 2012
Peter you talk allot, and have all sort of info but the proof is in the pudding I haven't seen any Video of your planes
you say ##They are a very nice fan unit. A good motor. Plus a good price at least from HK. But you don't really want to fry and ruin one for nothing! So I wouldn't advise hitting numbers over that 80Amps area for very long at all, and preferably never ####
I Have been running that fan on 4s pulling 85 amps for over 50 flights I have seen no loss of performance at all
So in my book this fan can handle 85 amps all day long
Old Feb 04, 2013, 10:59 PM
Joined Nov 2006
This below as WRONG.... as it is a 2970 motor in the 10blade 4S. Which is a very good motor size... and needed to fit the windings that can do 80A+ to get 1200w with 4S.
So it is a 1200w capable motor. (but still would not be happy doing that max long term. eg all flight etc).
You could still not use 5S.
(I was thinking of the 4S 5 blade DPS with all the numbers - it uses a 2850 1000w motor)
V
V
V
LOL, you wouldn't run 85A for 1 minute, let alone all day long.....
A 2850 (or 2950) is typically a 1000W motor. Your claim is for near 1200W
1000w at 4S (14.8v) is 67Amps. That is all they are rated for.
But they can be run higher than that, for peaks, short runs.... like 80A or your 85A area.
It is over the specs of the windings and may or may not last long. That is up to luck of the ambient temp... the real winding temp of that run (came from a lot cooler, or not... or how long it ran etc etc).
But basically, you are in the region of frying it and pure luck if you do or don't.
No technical merit, just luck.
If you choose to risk it, and the loss of the motor cost ($50 approx) then fine.
Old Feb 05, 2013, 12:45 AM
Quadmad is offline
Joined Jul 2012
V
V
V
Don't really give a toss what you think.like I said before, you have all the numbers and figures over 4000 posts, can you actually show me a Vid of your T45 flying so i can see how well it really performs. you seems to be the guy who know it all.
I'll keep pushing this fan as hard as i can,and when or if it dies I'll just buy another motor, 50 bucks I make that in less than an hour LOL
PS: by the way I have always been very lucky
Old Feb 05, 2013, 05:28 AM
perfect1 is offline
Find More Posts by perfect1
Singapore, Singapore
Joined Jul 2012
LOL
After reading your post, i understand much more about the relationship between KV, volt, amp etc.... I think the manufacturer should include the wire size of their motor so that we can estimate the current it can withstand.
perfect1 is offline Find More Posts by perfect1
Old Feb 08, 2013, 07:23 AM
Frank2351 is offline
Find More Posts by Frank2351
United Kingdom, England, Beverley
Joined Jan 2013
TURNIGY PLUSH 80 amp esc
I have finished my t45 the same as dishos, but when I plugged the ESC in in continually beeps and nothing but the mother jiggling.
When I look on the instructions it says that it is possible that the voltage is to high. I don't get this as the packs have been used before and all are fine. I have noticed though when I conect the pacts there is a small spark. I have had this before but the small spark did not cause a problem. Another strange thing is when I gentle squeeze the ESP it starts working.
Any help would be great
Frank2351 is offline Find More Posts by Frank2351
Old Feb 08, 2013, 10:17 AM
disho is offline
Find More Posts by disho
disho's Avatar
United Kingdom, England, Durham
Joined Apr 2011
Hi, have you checked that you have the throttle
trim all the way down on your transmitter ? as this will cause the esc to beep, also check the throttle chanel is not reversed, you do get a spark conecting the packs on 6s. its possable a faulty esc as i did have one that would work when i would gentle squeeze the esc
disho is offline Find More Posts by disho
Old Feb 08, 2013, 10:40 AM
Joined Jan 2013
Cheers Disho
I don't know how, but I left it as I was getting pxxxxd off with it. An hour later I plugged it in and it worked, but the orange reciever keeps flashing. If I rebind it the orange light goes solid, but when the battrie is disconnected and plugged back in it starts flashing. The only way I can keep it solid is if I turn my DX6i off then then plug the bat in and then turn the transmitter back on.
Disho
Did you find that with a 6 cell 3300 when held in an upright position and full throttle would it hover or did it slowly drop.
Mine slowly drops, but I recon if I gently threw it level it would be off like a goodun. Tommorow is forecasted 7mph winds, so hopefully a maiden.
Old Feb 08, 2013, 11:03 AM
disho is offline
disho's Avatar
Joined Apr 2011
Cheers Disho
I don't know how, but I left it as I was getting pxxxxd off with it. An hour later I plugged it in and it worked, but the orange reciever keeps flashing. If I rebind it .
Disho
HI, i never use the orange recivers only spectrum,sounds like your out of sink, ie unplug lipo, then transmitter off, then transmitter back on and then plug lipo back in, the lightshould go solid, Mine slowly drops to remember its a big plane but dont worry look how well they fly. have you had the watt meter on ?
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
