Auckland - New Zealand
Joined Dec 2010
Peter where is the video of yours, how does the performance compare to these ones
Joined Dec 2010
84 Amps 1184Watts
I would say Impressive for a 4s setup Thanks for the info Peter
Australia, VIC, Melbourne
Joined Nov 2006
Yeah, but that is the power system they HAVE thrown into it. 2000W 'capable'.... but would not be realised in the T-45.
And then there is WHAT came out of it.... likely to be WAY less than the theoretical that combo could do. Just because the T-45 has poor inlets, so they would HAVE to add cheaters for it to go as fast as it does, and that means no issue with sidewalls etc as it would be right in front of the fan under the wing anyway.... and even then it would not be enough airflow to realise the full power capability of it. Thus why I am guessing 1400w in the plane and not the 2000w area it could do on a bench. Put that all into a Habu and then it would run at a much higher power level. And THEN.... 1400W doesn't translate linearly to performance, so the difference to the 1180W 4S setup would not be huge (10kph? 15?).... but its best factor would be the far more efficient system, and far easier battery life. Throw that 6S combo in with NO cheater....... well then I guess the ducting would implode! LOL. Seeing this T-45 is all very thin walled. At 850W there was no sign of any strength issue... LOL.. Next is 950W area. And if it flies well, then I will move it up to 6S and 1200W or so. |
Joined Dec 2010
By the way what formula do you use to determine the outlet size?
Joined Nov 2006
The video said 3000kv.... which at those power levels it would run at means SMOKIN! But it did look fast too! hehe
But 2150kv sounds more usable!! Though then it is only 1100/1200w area. (I think I am at about 1300w area on some HET 2200kv 6S CS10's I have) |
Joined Dec 2010
Published on Sep 2, 2012 My Hobby king T-45 with a 70m cs10 fan, 6s BL-32 motor, 6s 3000 nano tech lipo, a 80a esc, and 2 servos, Who needs a turbine, Turn the sound up and enjoy. not 3000kv LOL |
My set up is bl 32, cs 10, 3300 nano tech lipo its 66amps at 1366 watts ![]()
Joined Oct 2009
I forgot how good these T45 airframes sound, especially now with the popularity of the CS 10blade fans. I sold my 64mm version because i found it was a little too stable and predictable, a little too easy to fly
![]() Might just have to get another one and throw a 1700watt power system in it
| Thread Tools | |
| New Product F4D Skyray 64mm EDF by FMS Model, now at Hobby Lobby | Joe 1320 | Foamy EDFs | 785 | May 06, 2013 08:21 PM |
| Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review | Spackles94 | Foamy EDFs | 69 | May 19, 2012 02:46 AM |
| Discussion Hobby King A4 Blue Angels EDF Jet | airbagit13 | Electric Ducted Fan Jet Talk | 8 | Nov 04, 2010 11:37 PM |
| For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) | The Don | Aircraft - Electric - Jets (FS/W) | 10 | Dec 07, 2008 10:24 PM |
| Discussion broken fan on 64mm sapac t45 edf | newguy2005 | Foamy EDFs | 0 | Jul 19, 2008 04:44 PM |
