Old Dec 23, 2012, 01:21 AM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
It has seemed to help static thrust. I have only given it the one launch test so far as the weather hasn't been too nice.
jim350 is offline Find More Posts by jim350
Old Dec 23, 2012, 05:40 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Jace, when will you be around again?
I still have to do a final fine balance to your 70mm alu' fan. Haven't had much spare time of late.
NitroCharged is offline Find More Posts by NitroCharged
Old Dec 23, 2012, 07:06 AM
J-ACE is offline
Find More Posts by J-ACE
J-ACE's Avatar
Adelaide Australia
Joined Apr 2010
I'm on holidays now Nitro so might pop down in between X-mas and the New year hope to get the Hawk flying before then. Spare time I have no idea what that is anymore
J-ACE is offline Find More Posts by J-ACE
Old Jan 01, 2013, 05:24 PM
nick73 is offline
Find More Posts by nick73
Joined Oct 2008
I have to replace the broken fan of my T-45
Hello everyone,
after less than one year flying / crashing my T-45,
I have to replace the broken fan.
Can anyone help me finding spare parts, or compatible parts ?
The stock setup is a 64 mm fan ;
The best would be to find simply the spare fan.
If needed, I could also repalce the whole fan unit,
but I would like to keep my motor and esc.
I am not interested in increasing the power, but I would like to have at least the original 430 Watts of the stock setup
Any advice is well accepted.
Best regards.
nick73 is offline Find More Posts by nick73
Old Jan 01, 2013, 06:08 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
The stock EDF is a SAPAC 64mm 6-blade unit. You can sometimes find them generic on ebay, but usually as a complete unit (motor + fan) and not well-balanced.
fredmdbud is offline Find More Posts by fredmdbud
Old Jan 06, 2013, 09:58 AM
nick73 is offline
Joined Oct 2008
Looking for, but . . .
Hello,
thank you,
I was looking for these fans, and actually I found them, but I would not like to buy also the motor.
Anyway, I will continue my search, and then . . . I could also buy the whole unit and sell the motor only.
Best REgards.
Old Jan 06, 2013, 03:52 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Look at HobbyKing. They have 'generic' no-name fans... and likely to have that SAPAC one in there. Fan only.
At worst, pretty well any other cheapie fan would do anyway.
PeterVRC is offline Find More Posts by PeterVRC
Old Jan 06, 2013, 04:48 PM
Komm_Klink is offline
Find More Posts by Komm_Klink
Komm_Klink's Avatar
Joined Oct 2012
http://www.hobbyking.com/hobbyking/s...dProduct=11163
I am currently using this fan as a replacement in my T-45. I never ran the stock fan (broke it before first flight) so not sure what the power difference will be. But it does work, I just find it's quite under powered (if running stock on 3S).
Komm_Klink is offline Find More Posts by Komm_Klink
Old Jan 06, 2013, 06:33 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
Klink,
Any 64mm fan, no matter how much you pay for it, will be a dog in the t-45 when paired with a 3 cell lipo. Change out the stock e.s.c. for a 60 amp hk unit, and run a 4 cell 2200 to 3000 4 cell. the change is dramatic.... this t-45 is a great flying plane, but the airframe is too fat and draggy for it to be a 3 cell performer. try a Phase 3 F-16 if your looking for a 3 cell 64mm 30 amp set-up that goes reasonably fast and will slow down for landing...that airframe is slick and better suited to the 64mm fan.....if you were to buy the phase 3 f-16
kit, use your own 2 additional servos, you could use the stock e.s.c. from the t-45 for the F-16. for around $60 you could have both up and flying
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Jan 06, 2013, 10:20 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
This unit really adds some pep to this jet with a 4S battery and a cheater hole:
http://www.hobbyking.com/hobbyking/s...dProduct=21147
Old Jan 07, 2013, 06:55 AM
V-Man is offline
Find More Posts by V-Man
Airplane and Heli Flyer
V-Man's Avatar
Canada, QC, Montreal
Joined Dec 2009
Originally Posted by iflyrc1012 View Post
Klink,
What do the amps look like on a 4S system using the stock fan? How about thrust?
I'm getting my T-45 ready for Spring and I need to order an ESC for it. Might as well get a 4S battery while I'm at it... (I was originally planning on using my 450 heli's 3S 2200 mAh batteries.)
V-Man is offline Find More Posts by V-Man
Old Jan 07, 2013, 11:33 AM
tenspeed is offline
Find More Posts by tenspeed
Joined Aug 2010
Mine draws 67 amps WOT on 4S with the stock fan and motor.
tenspeed is offline Find More Posts by tenspeed
Old Jan 07, 2013, 04:07 PM
PeterVRC is offline
Joined Nov 2006
67 Amps!!!!
That is extremely high for any 'stock' system... especially 64mm.
1000w
No cheapie PNFs even give that sort of power ever. More like 400W or so.
Or... I guess it is a 3S stock system, but even then the step up to 4S won't double it. Plus it would fry quick smart at 67Amps.
Are you sure it is 67Amps!?
Old Jan 07, 2013, 04:55 PM
Komm_Klink's Avatar
Joined Oct 2012
Thinking about adding some flaps to my T-45. Just curious what the roll rate is for those of you who have already done this.
Old Jan 07, 2013, 05:47 PM
iflyrc1012's Avatar
bklyn n.y.
this is mine on 4 cells, bone stock exept a hk 60amp e.s.c. it does not need flaps..
t-45 on 4 cell lipo (1 min 47 sec)
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
