Old Dec 16, 2012, 09:20 PM
warbirdboy is offline
Find More Posts by warbirdboy
Spring
Joined Sep 2008
Also guys, please replace your esc and don't risk it. I flew mine the first couple times and it did fine and it didn't get too warm. The next time i flew it, the esc caught fire and i had to emergency land. I tore the whole wing off by hitting a trashcan, but it's still in one piece. I'll have it glued back together and the scuffs fixed, but replacing the ESC is a must.
warbirdboy is offline Find More Posts by warbirdboy
Old Dec 17, 2012, 10:17 AM
eminemin is offline
Find More Posts by eminemin
The Netherlands, UT, Nieuwegein
Joined Sep 2012
Hey Guys,
I am thinking to buy this plane i am a beginner with jets but fly some years helicopters.
Is this a good plane or does it have much fails and do you have to make much modifications to make it fly ok ?
Or should i just go ahead and look for something else ( tips are welkom ) something better for about the same money for this plane ?
Thanx
eminemin is offline Find More Posts by eminemin
Old Dec 17, 2012, 11:08 AM
V-Man is online now
Find More Posts by V-Man
Airplane and Heli Flyer
V-Man's Avatar
Canada, QC, Montreal
Joined Dec 2009
From what I know, this T-45 is probably the best EDF trainer on the market. Just make sure to replace the stock ESC with a higher-amp one, and you'll be okay.
V-Man is online now Find More Posts by V-Man
Old Dec 17, 2012, 11:10 AM
nebuchadnezzar is offline
Find More Posts by nebuchadnezzar
gilford, new hampshire, usa
Joined Nov 2003
This model seems a little fragile. The multiplex Twister is made of better foam and flies well on the supplied components. Easy to hand launch.
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old Dec 17, 2012, 11:23 AM
ricksonchow is offline
Find More Posts by ricksonchow
Rickson C
ricksonchow's Avatar
United Kingdom, England, London
Joined Dec 2006
Hey Guys,
Thanx
Well, have you flown any prop plane before? I would rather start with those first as they are easier to control. After one or two prop planes, this one will be your good choice to enter the world of EDF planes. T-45 is a decent plane but you still have to make some modification to fly well or, last longer.
ricksonchow is offline Find More Posts by ricksonchow
Old Dec 17, 2012, 11:57 AM
eminemin is offline
Joined Sep 2012
| know i should start with props but i decided to go straight to EDF planes, we will see how its gonna end up probably i will crash it but thats just the way i learn.
So you find this one better over the twister ?
Old Dec 17, 2012, 01:29 PM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
that might be right but the twister costs 5 times more
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Dec 17, 2012, 02:52 PM
Joined Nov 2003
Try a couple of prop trainer types first (please!).
Old Dec 18, 2012, 02:24 AM
perfect1 is offline
Find More Posts by perfect1
Singapore, Singapore
Joined Jul 2012
Hey Guys,
Thanx
Replace the stock ESC with a 60A ESC. If you are good in orientation, this should not be a problem. Just remember to keep it moving..(this is not a heli). Enjoy!
perfect1 is offline Find More Posts by perfect1
Old Dec 18, 2012, 05:17 PM
disho is offline
Find More Posts by disho
disho's Avatar
United Kingdom, England, Durham
Joined Apr 2011
Yes
HK T-45 cs10 fan 6s BL-32 motor 6s 3000 Who needs a turbine. (4 min 48 sec)
disho is offline Find More Posts by disho
Old Dec 18, 2012, 08:10 PM
Great_Goose is online now
Find More Posts by Great_Goose
An aspirational fast jet pilot
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
Why don't you go for the 50mm T-45 they are about $80 PNF they are stable and fly well but are small which their down side. If you right it off it has not cost a lot and if you can fly it you can move on to a bigger and better EDF.
Great_Goose is online now Find More Posts by Great_Goose
Old Dec 22, 2012, 04:28 AM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
I had some issues with my lipos getting hot so i made a scoop out of a plastic dessert spoon and glued it to the bottom of the nose and an exit further back
It works really well,didn't rip it off after two flights today
Here is Video from today
Fist run needed some trimming first time out with the new vertical stab
T45 1 Clip 001 (3 min 15 sec)
Second run with fresh lipo
T45 Clip 001 (2 min 0 sec)
Quadmad is offline Find More Posts by Quadmad
Old Dec 22, 2012, 10:13 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I finally got mine all back together. I even had to strip down the AR6100 and remove solder splatter from inside the receiver! Man! that must have been a bang!.
NitroCharged is offline Find More Posts by NitroCharged
Old Dec 22, 2012, 11:17 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Jesus solder splatter inside the receiver as well?
Is that why you didn't come out yesterday? It was perfect flying comditions.
jim350 is offline Find More Posts by jim350
Old Dec 22, 2012, 11:55 PM
J-ACE is offline
Find More Posts by J-ACE
J-ACE's Avatar
Adelaide Australia
Joined Apr 2010
Jim did you find the cheater hole worked better for launch.
J-ACE is offline Find More Posts by J-ACE
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
