Old Dec 01, 2012, 09:53 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by Quadmad View Post
my setup with 3000kv motor pull 84amps on 4s
I would expect higher amps with the 4300kv motor
Depends on number of blades, fan type, etc...
Sammy70 is offline Find More Posts by Sammy70
Old Dec 02, 2012, 12:21 AM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
Yes i know the blades make a difference, what other fan types are there
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Dec 02, 2012, 12:43 AM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Besides the number of blades, there's the pitch and shape of the blades. Also, pusher or tractor type ...
fredmdbud is offline Find More Posts by fredmdbud
Old Dec 02, 2012, 01:25 AM
Quadmad is offline
Joined Jul 2012
Originally Posted by fredmdbud View Post
besides the number of blades, there's the pitch and shape of the blades. Also, pusher or tractor type ...
wow
Old Dec 02, 2012, 02:56 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
hehe, yes... you can rest assured when they make a 'ready to go combo' (eg like that Mercury) it is all designed to operate as per their specs/outline. The motor is going to be correct (RPM result) for the voltage/cells they state.
The Mercury is actually a high blade count fan (8 I think) but it will have lower pitch to allow for that. It also uses ALLOY BLADES so they can do out to 60k RPM totally fine, versus plastics doing 50K area max (safely).
It is a pusher system (fairly rare) but that is irrelevant to blade pitch and RPM.
PeterVRC is offline Find More Posts by PeterVRC
Old Dec 03, 2012, 12:20 PM
Matty001 is offline
Find More Posts by Matty001
Italia, Puglia, Porto Cesareo
Joined Nov 2011
4300 Kv sounds a little high to me for a 4s setup if you do run 4s make sure you have a good size esc, my setup with 3000kv motor pull 84amps on 4s
esc 60 A
lipo 3300 4s 40-70c FullPower
with the engine at full throttle are only absorbed and 53A-750 (approx.) watt
Matty001 is offline Find More Posts by Matty001
Old Dec 03, 2012, 03:03 PM
Quadmad is offline
Joined Jul 2012
Originally Posted by Matty001 View Post
esc 60 A
very good
I guess i have to be happy with my setup pulling 85.3 Amps @ 1285 Watts
Old Dec 03, 2012, 05:11 PM
Matty001 is offline
Joined Nov 2011
very good
But your fan has 12 blades, right?
Old Dec 03, 2012, 07:29 PM
Quadmad is offline
Joined Jul 2012
10 blade fan
Old Dec 04, 2012, 03:16 PM
Matty001 is offline
Joined Nov 2011
my t-45
T-45 Goshawok 64mm RedVelocity Fan 4s 3300 FullPower.wmv (3 min 56 sec)
Old Dec 04, 2012, 07:13 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Nice flying and landing Matty!
What Kv motor is that in your RedVelocity?
Old Dec 04, 2012, 07:18 PM
Matty001 is offline
Joined Nov 2011
4300 kv
750w 53a with 4a 3300 mah 40-70c
Old Dec 05, 2012, 05:10 AM
vittoriofi is offline
Find More Posts by vittoriofi
Joined Sep 2008
Very nice matty!!! Good edf...
Vittorio
vittoriofi is offline Find More Posts by vittoriofi
Old Dec 05, 2012, 02:18 PM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Hi all I have this T45 fitted with 70mm fan I'm really happy with the way it fly
How are you guys attaching the canopy ?at this stage I'm using tape but would like a better way of doing it any ideas ?
thanks in advance
Cheers
Adrian
Adrian_M is offline Find More Posts by Adrian_M
Old Dec 05, 2012, 05:50 PM
PeterVRC is offline
Joined Nov 2006
I haven't resumed building mine, but I almost always use a slide-lock mechanism.
http://www.hobbyking.com/hobbyking/s...0pcs_bag_.html
You will work out, over time, that magnets etc are not reliable. Eventually you will lose the canopy. You can't beat a ASSURED locking method!
They can always be fit into any 70mm or down to 64mm model (even some 50mm).
Very easy to cut/mod foam and fit. Might need a thin plywood plate glued to the canopy rear (I haven't checked this plane yet).
I replace a 'cover' of the prior cut-out foam and repaint that area, so then all you see is the 'release tab'.
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 10:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 03:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 05, 2010 12:37 AM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 11:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 05:44 PM
