Old Nov 25, 2012, 05:07 PM
Joined Aug 2010
Originally Posted by warbirdboy View Post
Have all of you guys removed the stock ESC? Or is your plane doing just fine with it? I'm kindof skeptical on whether to fly mine because of everybody conplaining about the ESC. And i'm running a 4s in the nose and mine balances fine..moving it all the way to the wing seems a bit weird to me.
I upgraded the ESC to 50 AMP with the 3S battery. I have since upgraded it to 4S and have gone with an 80 amp ESC.
tenspeed is offline Find More Posts by tenspeed
Old Nov 26, 2012, 07:10 AM
disho's Avatar
United Kingdom, England, Durham
Joined Apr 2011
Originally Posted by Quadmad View Post
maiden was successfull yesterday I had two flights and this is the position where the lipo ended up
it flew really nice plenty of power i ran out of time so i didn't get a chance to put the carbon spar in the wing or fiberglass tape the wing was flexing to the max LOL so next flight will have a spar in it
Speed wise i would say 150-160Kph
doesn't sound as nice as disho one tho
anyways very happy wit it so far I must order a 5s to try
Any video of the flight
disho is offline Find More Posts by disho
Old Nov 26, 2012, 02:05 PM
Joined Jul 2012
No I will try take some next time i fly it
I will not fly it again till i put a spar in the wing
Cheers
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Nov 26, 2012, 03:03 PM
Spring
Joined Sep 2008
Maidened mine yesterday. It was a calm day, but there was sporadic wind gusts of like 5-10 mph. This thing can not handle wind for sure. It nearly stopped going towards the wind when a gust came, and nearly tip-stalled once (high in the air though), but when there's no wind it fly's great! Got it up and down in one piece. This is my first EDF, so i didn't trim it because i was shaking too much XD. But not a scratch, it went well
Also, this was a flight with the stock ESC. The only problem i had with the plane was that sometimes when i start up the motor, it makes a really weird grinding sound, like something is loose or like something is hitting the fan. To fix it i have to just put the throttle back down and back up again. I checked multiple times to see the cause, but couldn't figure it out. Nothing is hitting it and nothing is loose.
warbirdboy is offline Find More Posts by warbirdboy
Old Nov 26, 2012, 05:50 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
If you flew it with 3S, then I'm not surprised.
That grinding sound is probably the ESC mis-timing the winding in the motor, causing it to stutter.
fredmdbud is offline Find More Posts by fredmdbud
Old Nov 27, 2012, 12:12 AM
Spring
Joined Sep 2008
Flown with a 4s.
Old Nov 27, 2012, 10:22 AM
Joined Aug 2010
Flown with a 4s.
The stock ESC is supposed to be a 30 amp. On a watt meter mine runs somewhere around 70 amps WOT.
Old Nov 27, 2012, 01:14 PM
Italia, Puglia, Porto Cesareo
Joined Nov 2011
I have a question:
be able to install on the model a 68mm fan?
I thought this mount:
http://rc-castle.com/shop/product_in...oducts_id=1725
the second you enter the room? changes must be made? vortrei not weaken the fuselage with various cutouts ..
Matty001 is offline Find More Posts by Matty001
Old Nov 27, 2012, 01:38 PM
Joined Jul 2012
Originally Posted by Matty001 View Post
I have a question:
That's expensive you can get the same fan much cheaper from HK
73 dollars for this one
http://www.hobbyking.com/hobbyking/s...Rotation_.html
Or the 70 mm 10 blade one same as what i'm using in my T45 for 79 dollars
http://www.hobbyking.com/hobbyking/s..._1200watt.html
Old Nov 27, 2012, 01:57 PM
Joined Nov 2011
thanks for the reply and advice.
But I ask you an information.
I can install it without any problems the fan inside of the model? goes well without any problems? or changes must be made to the plane?
Old Nov 27, 2012, 02:53 PM
Auckland - New Zealand
Joined Dec 2010
Try this one
http://www.hobbyking.com/hobbyking/s...hite_EPO_.html
Adrian_M is offline Find More Posts by Adrian_M
Old Nov 27, 2012, 04:40 PM
Australia, VIC, Melbourne
Joined Nov 2006
Look up Buddy Codes for HobbyKing and you can get the 10blade alloy fan for $66
And grab that other 70mm T-45 instead at the same time too.
PeterVRC is offline Find More Posts by PeterVRC
Old Nov 27, 2012, 04:56 PM
Joined Nov 2011
I have the 64mm version.
The 70mm fan does not fit?
Old Nov 27, 2012, 05:21 PM
Joined Nov 2006
It will fit with sanding out the fan area.
A Dremel drum sander.... or sand paper around a round rod/object.
Old Nov 27, 2012, 05:30 PM
Joined Jul 2012
If u haven't brought a fan you can buy the CNC 64 mm fan from HK that one will fit with minimal work
New Product F4D Skyray 64mm EDF by FMS Model, now at Hobby Lobby Joe 1320 Foamy EDFs 785 May 06, 2013 08:21 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
