Old Nov 15, 2012, 04:53 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Disho, I would expect your T-45 must go over 100mph. My 5S Meteor does 160kph (100mph) and the BL32 is a more powerful motor than mine... and also a high KV for 6S.
T-45's are a little bit more draggy, whilst the Meteor/Habu is very slick, but that motor/6S should offset that.
I would think even 120mph really.
I have an alloy CS10 2200kv I was going to use on 6S in it, but now that I have seen the T-45 I will just use a 5S 'plastic' CS10 setup. It is not worth using the alloy setup in it.
Hmmm, I will swap the Meteor CS10 into the T-45 and use the alloy in the Meteor.
PeterVRC is offline Find More Posts by PeterVRC
Old Nov 15, 2012, 04:57 PM
Matty001 is offline
Find More Posts by Matty001
Italia, Puglia, Porto Cesareo
Joined Nov 2011
Help!!! center of gravity?
Originally Posted by disho View Post
I have a big problem.
my plane does not have the rear air intake.
how do I calculate the center of gravity?
Matty001 is offline Find More Posts by Matty001
Old Nov 15, 2012, 05:46 PM
disho is offline
Find More Posts by disho
disho's Avatar
United Kingdom, England, Durham
Joined Apr 2011
Sounds like a good idea, i have the alloy 10 blade in my hunter, but the t45 still sounds the best
disho is offline Find More Posts by disho
Old Nov 15, 2012, 05:48 PM
disho is offline
disho's Avatar
Joined Apr 2011
What rear intake?? i posted cg a couple of pages back
Old Nov 15, 2012, 08:04 PM
Komm_Klink is offline
Find More Posts by Komm_Klink
Komm_Klink's Avatar
Joined Oct 2012
Could someone who has modded there T-45 from 64mm to 70mm give me some insight on the best method to do this. Pics would be great Thanks
Komm_Klink is offline Find More Posts by Komm_Klink
Old Nov 15, 2012, 08:13 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
I took a spare 70mm duct and used a hobbyknife to bevel the inside of the rim to form a "cookie cutter" edge and worked it in place using a lot of twisting.
fredmdbud is offline Find More Posts by fredmdbud
Old Nov 15, 2012, 08:14 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
One method is to glue a section of sand paper around a small can (like a small spray paint can) and use that to enlarge the fan area.
Sammy70 is offline Find More Posts by Sammy70
Old Nov 15, 2012, 08:44 PM
PeterVRC is offline
Joined Nov 2006
I will Dremel drum sand it out. And it also needs "blending" at the front end into the fan. No lip on the fan in this installation.
Exhaust...... not sure until I test it but it looks a bit small at the fan end also.
Another way is a large piece of dowel with sandpaper glued to it. So it is long and you can get it deep into a plane. The larger the diameter, the more accurate your 'rounding' out will be.
Old Nov 15, 2012, 11:51 PM
Komm_Klink's Avatar
Joined Oct 2012
Also, any tips on removing the stock 64mm fan without too much carnage???
Old Nov 16, 2012, 12:22 AM
PeterVRC is offline
Joined Nov 2006
My kit doesn't have a fan, but they are usually either hot glued in, or taped.
So you can just pry them out by hand... rock it end to end. Once you get it going it gets easier.
Some people use a hair dryer and heat it a BIT.... but you have to be careful of expanding the foam if you use heat. I have always got them out just by the "careful force" method.
Old Nov 16, 2012, 05:03 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
At long last, I found the time to upload Jim350's maiden flight of his BAE Hawk fitted with the changesun 70mm 10 blade EDF unit. This unit was a balanced unit purchased from extreme rc here in Oz.
Jim350's foamie BAE Hawk 10 blader (4 min 25 sec)
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 16, 2012, 06:24 AM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Woohoo
Ahh that sounds so nice :-) thanks Nitro
jim350 is offline Find More Posts by jim350
Old Nov 16, 2012, 01:25 PM
disho is offline
disho's Avatar
Joined Apr 2011
Hi it took alot of work with the dremel to get the fan in, i split the rear fuss in half to make it easer to work on, then i used silicon to seal the fan in, i tryed it without a nasa duct first in my other vid it felt starved of air, its now awesome with a duct cut just infront of the fan thxs
Old Nov 16, 2012, 01:40 PM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
http://www.youtube.com/watch?v=QTKENJ2fYj4
Nice but for it just don't sound as good as disho one and it looks slower too
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Nov 16, 2012, 02:00 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Well, he doesn't say what was the cell-count of the battery he used ...
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
