Old Aug 30, 2012, 11:48 AM
lebl468 is offline
Find More Posts by lebl468
lebl468's Avatar
Cold Lake, Alberta
Joined May 2010
Well, less than a week and my replacement fuselage is in the mail on it's way. I must say, I am impressed with my one and only HK customer service encounter. From the moment I started the claim, till they had the fuselage order written up was 2 days. Not too shabby.
lebl468 is offline Find More Posts by lebl468
Old Aug 30, 2012, 11:55 AM
Leojet is offline
Find More Posts by Leojet
Joined May 2011
Originally Posted by tengarang View Post
THanks vandertrander.
all,,,,
so whos tried the 70mm kit...i know its not part of this thread..but some of you must have some experience with it...how does it compare with the 64mm?
With 70mm you will have more aceleration in 4s configuration, but remember the weight of 14.8 volts batt,big motor.
I don't know your t-45 model, and your specs,but the weight its the same like our t-45's.
But 1500 Mah and 11.1 volts it seem a little poor!!.Mi recomendation:
http://www.hobbyking.com/hobbyking/s...r_55_64mm.html
http://www.hobbyking.com/hobbyking/s...inch_64mm.html
And 40 amps ESC, and 11.1 volts 2200 mha.
If you want a standard performance.
Now if you want a better performance can opt for 8.14 volts and a 4500 kv cyclone turbojet.
This will have more speed with just a little more weight.
There is another option, if you want you can use this equipment also
http://www.hobbyking.com/hobbyking/s...v_45A_ESC.html
Anyway, if you want a 70mm edf you will have to work to fit the unit in the plane.
Leojet is offline Find More Posts by Leojet
Old Aug 30, 2012, 04:32 PM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Thank you for your feedback Leojet. I have this kit with me:
http://www.nitroplanes.com/60p-70mm-edf-combo.html
I already have a 60Amp plush in the t-45...the shroud on this 70mm fan does add to the circumference...
Another way I planned..
The edf 64mm you recommended I have on order and is over the pacific ocean right now...in conjunction with this motor
http://www.hobbyking.com/hobbyking/s...dProduct=10923
this second option I will not have to modify too much foam....fingers crossed....
either setup im running 4s 2200ham minimum may go up to 2800mah 4s since the t-45 can take it...the weight im not too concerned...just want to see improvement.
tengarang is offline Find More Posts by tengarang
Old Aug 30, 2012, 07:17 PM
J-ACE is offline
Find More Posts by J-ACE
J-ACE's Avatar
Adelaide Australia
Joined Apr 2010
My T-45 weighs about 2000g I run a 70mm alloy shroud 10blade CS fan and 4000mah batts it's heavy to hand launch but flies and glides fine I get about 130kmh level flight and about 6minutes flight with throttle management or 3-4min WOT
J-ACE is offline Find More Posts by J-ACE
Old Aug 31, 2012, 01:59 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
I think mine is 1/3 of your weight
But I don't get 130km/h ... BTW in case of crash ... I don't kill anybody even if I hit his face at full speed
Tchuss
e_lm_70
ps: I'm going to use this micro GPS logger for check the speed of my T-45 (50mm and 64mm) ... I'm afraid 22g of extra weight could be too much for the 34mm T-45
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 31, 2012, 06:00 AM
J-ACE is offline
J-ACE's Avatar
Adelaide Australia
Joined Apr 2010
Safety First mate I try not to fly into peoples faces . Where I fly we have a lot of respect for our models and safety of the public.
Old Aug 31, 2012, 06:04 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I would be surprised if it would be otherwise
Still ... you may not know where it can land your bird in case of radio or any other problem
So ... a light bird is safer by nature
Tchuss
e_lm_70
Old Aug 31, 2012, 01:14 PM
Guijs is offline
Find More Posts by Guijs
Joined Aug 2012
Help to choose retracts
Hello all,
I am ready to buy the T-45 from Hobbyking with the below parts at HK:
T-45 Goshawk kit
Motor HK2836 3800 kv
Turnigy Plush 60A ESC
EDF Hobbyking 64mm alloy 4000kv
AND (I will order both and decide which to use later)
EDF Ducted Fan Unit 7 Blade
Battery Turnigy Nano Tech A-PEC 2200 mah 65C
I already have EMAX ES08MD servos.
All the items above are in stock. But the last one, the DSR-A retracts are out. I was wondering if the DSR-D would fit as well. The main strut and wheel are 5mm longer and it is about 22g heavier. Did any of you already tried it?
Thanks in advance!
Guijs is offline Find More Posts by Guijs
Old Aug 31, 2012, 02:15 PM
tengarang's Avatar
Joined Aug 2010
Originally Posted by Guijs View Post
Hello all,
T-45 Goshawk kit
Thanks in advance!
Yeah Id like to know if people have any info on the DSR_D's
Id rather put retracts on...
Old Aug 31, 2012, 07:15 PM
Guijs is offline
Joined Aug 2012
Hello,
I found the DSR-30TS retracts. More expensive than DSR-A but lighter!
I will also upgrade ESC to Turnigy 85A and EDF to Mercury Alloy 64mm
Old Aug 31, 2012, 07:24 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Disappointed my t-45 arrived today with no directions,no nose,or nose cone no screws to attach wings or whatever..not sure what needs to be screwed or glued...In past 6 months i have put together 12 foam kits and this is the only one missing parts and manual....I will have to contact HK and have them send me what i need... AlsoThe canopy must have to be cut to fit...But i must say the foam is good quality
hate2crash is offline Find More Posts by hate2crash
Old Aug 31, 2012, 07:47 PM
tengarang's Avatar
Joined Aug 2010
Hello,
So are you going go with the DSR-30TS? Im thinking of pulling the trigger as well
Old Aug 31, 2012, 07:54 PM
Guijs is offline
Joined Aug 2012
Probably yes! I will just wait until sunday for a feedback of someone who actually have it! But seems like a better option than DSR-D or A.
Old Aug 31, 2012, 07:56 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
The DSRs won't fit in the wings they are quite thin
vanderbrander is offline Find More Posts by vanderbrander
Old Aug 31, 2012, 08:11 PM
tengarang's Avatar
Joined Aug 2010
Thank you vanderbrander thanks for your feedback again...much help from you thanks...
I have no first had experience with air retracts... i was referred to by someone in here a while back...nevertheless I still appreciate his kindness to share.
but do you have an alternative? my budget is 100 dollars including shipping...
please let me know thanks vanderbrander
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
