Old Aug 09, 2012, 11:52 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Originally Posted by hate2crash View Post
Thanks for all gyro responses...Anyone here ever fly hobbyking 64 mm stinger... the kit has great ratings and is all screwed together..stock fan,motor and esc hold up well on 1600-2200 amh 3s...stock speed is over 70mph..PNP is $89...not a military edf,but a very nice jet nice lines...Just wanted to know if anyone flew or owned it and how it compared in flight characteristics to the t-45...thanks
I was watching one at the field yesterday arvo. It flies beautifully, glides well. No bad habits that I saw. The stock EDF smoked up on about the second flight. So perhaps the ARF kit is a better buy. He also reported one tip stall incident, but I watched it yesterday flying fast and slow. His was pretty quick because after the outrunner failure he could not separated the loktite on the fan, and ended up just buying a Lander 10b EDF and gave it lots of speed.
Mick
ps- The T-45 is much larger and hence more managable I think, but I havnt flown the Stinger.
Bravo47 is offline Find More Posts by Bravo47
Old Aug 10, 2012, 01:57 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, L'Orignal
Joined Nov 2010
I have both T-45 and the Stinger. Both fly great, but have completely different characteristics.
I fly both on the same setup. 4S 2200 with a GWS 64mm fan and ERC 2445 motor.
The T-45 is my go to fun plane when I want to have a relaxing flight with good aerobatic performance, or if it's really windy (the T-45 handles +15kmh winds no problem at all). The T-45 is great for practicing jet aerobatics because it is so forgiving. I use this aircraft to sharpen my flying skills if I haven't flown for a while.
The Stinger is a lot smaller and faster (around 100mph). Consequently it gets very small, very quickly and is more of a handful on landing. Not your best bet for a first EDF.
I luv both these jets for two completely different reasons but for a first EDF, the T-45 can't be beat.
vanderbrander is offline Find More Posts by vanderbrander
Old Aug 10, 2012, 05:54 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
hate2,
the stock stinger is smaller than the t-45.... on 3 cells it tops out at about 85mph or so...
because of it's small size it seems to be a lot faster than the t-45....the stinger is a lot more maneuverable than the t-45, i have never bothered to put a 4 cell in the stinger for 2 reasons,
1) it didn't need the boost in speed, i think it flies fine on 3 cells
2) i don't think the stock e.s.c. will handle the extra voltage of a 4 cell...
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Aug 11, 2012, 01:07 AM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Thanks for the HK stinger reviews guys...Yes it is a good deal smaller ten t-45,but i figured i could keep it closer and go slow untill i get used to it and gradually up the speed and the manuvers...and i have 4- 3s 1800 packs already i use in my trainers...t-45 is nice and a lot of guys says its the best starter...I also watched the dynam meteor 70mm video's as well as HK 70mm sport jet ,which is a clone of the meteor basically ...Anyone here like or flew those models... I think they are approx same size as t-45 and stock setup seems very good power...thanks
hate2crash is offline Find More Posts by hate2crash
Old Aug 17, 2012, 12:12 AM
out of stock is offline
Find More Posts by out of stock
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
yoooo! just kidding
hello people im joining the hk t45 thread. im just about to place an order through hk. whats the usual wait time on ems delivery to usa? (florida)
i heard its like 2 weeks. true?
out of stock is offline Find More Posts by out of stock
Old Aug 17, 2012, 12:56 AM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
I've always used regular air post ... took about 4 weeks.
fredmdbud is offline Find More Posts by fredmdbud
Old Aug 17, 2012, 04:12 AM
perfect1 is offline
Find More Posts by perfect1
Singapore, Singapore
Joined Jul 2012
bench test
Did a bench test on my 64mm T45 EDF using stock 4500kv motor, cheap Hobbywing 60A ESC, Thunder power 3s 220mah 25C battery:
Half throttle for 2min
Running current:23A
37deg c on ESC
34deg c on motor
52deg c on battery
Draw 720mah from batt
Full throttle for 2min
Running current 18A
40deg c on ESC
32deg c on motor
46 deg c on battery
Draw 555mah from battery
Full throttle for 3min 40 sec
Running current 23A
40deg c on ESC
33deg c on motor
62deg c on battery.
perfect1 is offline Find More Posts by perfect1
Old Aug 17, 2012, 04:28 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Running current:23A
37deg c on ESC
34deg c on motor
52deg c on battery
Running current 18A
40deg c on ESC
32deg c on motor
46 deg c on battery
Running current 23A
40deg c on ESC
33deg c on motor
62deg c on battery.
Something is wrong with your way to measure current.
2min full power show 18A
While half power is 23A ...
You need a WATTmeter ... and you should report both Voltage and Amps (each battery has a different way to push out power)
50% throttle numbers are not much usefull ... 50% for you is different then real 50% , and 50% for somebody else ... is radio and calibration specific ..
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 17, 2012, 09:25 AM
perfect1 is offline
Joined Jul 2012
sorry for my mistake. typo error. It should be half throttle 18A and full throttle 23A. I use a DC clamb meter to measure the current flow at the battery lead. Also for full throttle for 3min plus, i put back about 1200mah to the battery after charging. Thanks for pointing out my mistake.
Old Aug 17, 2012, 09:53 AM
e_lm_70 is offline
Austria
Joined Jan 2004
23Amp .. at full power ... it sound way to little.
How many volt do you read from your battery under load ?
Old Aug 17, 2012, 09:54 AM
perfect1 is offline
Joined Jul 2012
i did not measure the voltage.
Old Aug 17, 2012, 09:58 AM
perfect1 is offline
Joined Jul 2012
How much current are you drawing with your T45 during full power?
Old Aug 17, 2012, 10:29 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I don't really remember ... I somehow remember of over 30amp.
My timer is set to around 4min ... and this consume more then 2400mAh ...so ... this means I consume over 30A at full power with full capacity in the battery.
Maybe in some old post I already written my number ... or other did report their current and voltage
I have no charge battery now ... so not going to test my T-45 now ... but maybe later.
Tchuss
e_lm_70
ps: Already the little T-45 50mm consume 18Amp at full power ... so ... your number sound suspicious ...
Old Aug 17, 2012, 11:18 AM
DONT PANIC! :)
Joined Jan 2012
Dang! 4 weeks is pretty long lol isn't ems suppose to be pretty quick? Like 7-8 days? ??
Old Aug 17, 2012, 08:05 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Patience is a virtue. And so is being a cheapskate
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 10:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 03:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 05, 2010 12:37 AM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 11:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 05:44 PM
