Old Aug 05, 2012, 05:31 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Originally Posted by Lejna View Post
Hi all
I want to buy my first jet plane
http://www.hobbyking.com/hobbyking/s..._Kit_only.html
and I need help to completing he 4S setup
motor - http://www.hobbyking.com/hobbyking/s..._for_64mm.html or better 3800KV or some other ??
EDF Ducted Fan Unit 7Blade 2.5inch 64mm - http://www.hobbyking.com/hobbyking/s...inch_64mm.html
ESC - http://www.hobbyking.com/hobbyking/s...k_70A_ESC.html this ?? or some other ??
which servo and battery will be good ??
Thx for a help
If you want to keep it simple I just used one of these combo kits below-
Link- http://www.hobbyking.com/hobbyking/s...v_45A_ESC.html
along with a 4s 2200mah 30-40c lipo
most 9g servo's will do the trick. If you want to go in real cheap - http://www.hobbyking.com/hobbyking/s...?idProduct=662
I've been using this setup for a while without any probs. Its no rocket ship, but plenty fast enough for a new EDF pilot.
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Aug 05, 2012, 06:03 AM
Lejna is offline
Find More Posts by Lejna
Joined Sep 2010
I dont want this combo but thanks for a help
I will better ESC and please help me which motor will be better
Lejna is offline Find More Posts by Lejna
Old Aug 05, 2012, 07:10 PM
m_ark is offline
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
if you want cheap, reliable -this 68mm fan will require some foam removal, or mount it forward of the stock location to fit. the real beauty of this system will allow you to run 3s 2650 with good thrust and very reasonable flight duration (due to weight savings on using 3cells;
http://www.hobbyking.com/hobbyking/s...idProduct=8835
expensive, but reliable:
http://www.hobbyking.com/hobbyking/s...dProduct=17220
you'll need 40c + ratings to run this fan designed for 4 cells - great thrust!
with either, this has been the ESC i've been using;
http://www.hobbyking.com/hobbyking/s...dProduct=12189
Rock solid. (but heavy)
just remember, extend the 3 motor leads, not the battery leads (unless you would rather have to additionally solder in clusters of low ESR capacitors on the battery lead side.) Otherwise you will eventually kill your ESC capacitors ... (i found this after about 15 flights...)
RE: EDF Ducted Fan Unit 7Blade 2.5inch 64mm - http://www.hobbyking.com/hobbyking/s...inch_64mm.html
I bought two of these and found them to be too agressive in pitch...maybe using a higher cell count and lower KV motor (like 6s and 2100kv or something?) might work.
if you want to stay in 3 and 4 cell territory, i'd recommend staying away from those 7 blade rotors.
m_ark is offline Find More Posts by m_ark
Old Aug 05, 2012, 09:30 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
I want to ask anyone here if they ever flew an HK,s F-22? and if it is approx same skill needed to fly this T-45...i have a smaller 50mm F9F coming this week which will be my first EDF and like the t-45 and the f-22 both... just want to know which one would be the next best model for me to learn with...thanks
hate2crash is offline Find More Posts by hate2crash
Old Aug 06, 2012, 01:55 AM
Lejna is offline
Joined Sep 2010
if you buy this set - http://www.hobbyking.com/hobbyking/s...idProduct=8835
I can fly with 4S or 3S ?? and how convert foam to 68mm ??
there is another set of cheap to not have to modify the foam ? and fly on 4S ??
Old Aug 06, 2012, 03:32 AM
perfect1 is offline
Find More Posts by perfect1
Singapore, Singapore
Joined Jul 2012
I got a full re-fund for my orange rx. Now is time to move on to better electronis, especially for EDF.
perfect1 is offline Find More Posts by perfect1
Old Aug 06, 2012, 03:57 AM
Lejna is offline
Joined Sep 2010
what do you think about it - http://www.hobbyking.com/hobbyking/s..._Version_.html
Old Aug 06, 2012, 04:06 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
This is going to be your 1st EDF ... so ... why just not take this: http://www.hobbyking.com/hobbyking/s...dProduct=12942
And figure it later how to improve
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 06, 2012, 04:15 AM
Lejna is offline
Joined Sep 2010
I read that in this version Plug-n-Fly ESC is too weak and this is a version of the 3S I want 4S version it must have power
Old Aug 06, 2012, 04:36 AM
e_lm_70 is offline
Austria
Joined Jan 2004
3S is powerful enough.
1 year ago the stock ESC, was not weak ... no problem at all with power ... it was having some random reset during the fly ... causing some unexpected motor power off, especially at full power ... I think this issue should be solved as we speak.
In case of problem with PNF ... just replace the ESC and you are perfectly fine with stock power. ... anyhow, even in the unlucky case you will pay less money going for the PNF versoin. Stock motor and EDF unit is good ... some has also gone with 4S with stock motor and EDF
Tchuss
e_lm_70
Old Aug 06, 2012, 07:04 AM
Lejna is offline
Joined Sep 2010
But I want complete a version of 4S who can help me ?
Old Aug 06, 2012, 07:16 AM
e_lm_70 is offline
Austria
Joined Jan 2004
I would pick:
http://www.hobbyking.com/hobbyking/s...45A%5FESC.html
Two: http://www.hobbyking.com/hobbyking/s...cro_Servo.html
Dual Aileron servo is always better
One: http://www.hobbyking.com/hobbyking/s...F13sec%5F.html
For the tail.
That's all you need
Old Aug 06, 2012, 07:17 AM
m_ark is offline
Gravity sucks.
Joined Mar 2011
so go with this:
and get a plush 60 or better, plush 80 ESC and stick a 4s 2200mAh 40c battery in it and fly! (the stock motor will handle 4s very nicely.)
Flight times on the 2200mAh battery will be short because of the extra current draw over the 3 cell option, but it should fit the stock battery compartment without modifications)
Better to fly with a 2650 or 3000 if you're flying 4s for longer flight times. (requires modifications to fit.)
Old Aug 06, 2012, 07:18 AM
e_lm_70 is offline
Austria
Joined Jan 2004
As battery I will go for this : http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
For keep the weight down.
Tchuss
e_lm_70
Old Aug 06, 2012, 07:31 AM
m_ark is offline
Gravity sucks.
Joined Mar 2011
Tchuss
e_lm_70
for a small battery, the AMPS drawn by 4 cells is going to require something like
http://www.hobbyking.com/hobbyking/s..._4S1P_40C.html
a higher rated discharge pack.... it should still fit the battery cage, but you may need to put a small counterweight at the tail to balance at the CG.
i started with turnigy 3s 2200's and 4s 2200's and all 4 packs (2 of each) puffed after the first flight - they were 20c rated... (i went cheap - not the wisest move i'll admit! )
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
