Old Aug 01, 2012, 06:36 PM
m_ark is offline
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
Originally Posted by hate2crash View Post
My experience is 41/2 months flying 3 weeks on mini cub 3ch,1month on 4ch hawksky(like bixler) and over 2 months flying 1280mm AXN clouds floater and last week started flying Arrow 1400mm which a larger version of axn...I always push myself to do more stunts...but these planes are not jets...i just want to be able to take off and land without crashing that would be a great feeling for me...Here's a great video...he is running 4s 3000 mah 60c,60 amp turnigy plush,Rc lander 64mm fan unit...I wonder if he has a thin sheet of lexan pastic glued to bottom...amazing belly takeoffs...PS do u have to modify battery compartment to fit such a large 3000 4s in this bird???Also what if i installed a gyro for alerons(kinda like training wheels on a bike to keep plane nice and level... http://youtu.be/qgZasRg4VdU
heres the fan and motor i think he is using http://shop.rc-electric-jets.com/RC-...EDF64-1A43.htm
I wouldn't recommend going from those floater aircraft to this one with under 6 months experience.
To get more experience to prepare you for flying 'speedy' aircraft, i found it helped a lot to fly smaller planes (easier/cheaper to fix if you crash), like the hobbyking swift, in high winds (ie 15mph gusting to 20mph).
Once you can tame one of those planes in difficult conditions, the speed of a jet isn't so much of a problem. After 3 months of that i put in a few months flying an upgraded Skyfun - a pusher prop jet. The speed was there, but incase i got into trouble it had heaps of static thrust to get my out of a tight spot.
Following this, flying the jet became like a relaxing past time... though low passes still get the adrenalin pumping!
To really hone your reflexes and focus, there's nothing better than a strong wind and a light plane! haha...
If nothing else, a crash is just a heavy landing that the plane is not built to withstand.
m_ark is offline Find More Posts by m_ark
Old Aug 01, 2012, 08:51 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
I have flown in the wind a lot.also FP heli's in wind..i also built several electric warbirds i could fly..corsairs,p51 t-28 ,hellcat...i guess i can always clip the wings on my arrow or axn first.which makes it very stunt worthy and even faster..axn will do over 68 mph level flight... Let me say i have these other planes i built but still have only flown the trainer gliders
hate2crash is offline Find More Posts by hate2crash
Old Aug 01, 2012, 10:27 PM
m_ark is offline
Gravity sucks.
Joined Mar 2011
This gave me the impression you didn't have much experience... Landing a jet is the same as landing anything else - if there's a strong enough headwind you can almost land vertically, otherwise you just need to come it a bit faster & try to hold onto the elvevator flare till just before the nose touches. I'm sure there are other equally good techniques also...
Old Aug 01, 2012, 11:45 PM
Joined May 2010
The planes i fly are for novice pilots...i never flew a jet of any kind,so i just need to believe i can do it i guess...it is foam and i am good at repairing these...so i just need to give it try and hopefully i will have success!But i will see if i can master a couple of warbirds i built first... thanks
Old Aug 02, 2012, 02:34 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Just make sure you have plenty of speed before you start to turn, then go full throttle through the turn. Give yourself a bit of altitude as well during the turn just in case things go wrong.
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Aug 02, 2012, 04:07 AM
m_ark is offline
Gravity sucks.
Joined Mar 2011
Mick
not sure if full throttle is required for every turn, but speed certainly is the key - if your control starts to feel soft or not accurate, you're probably approaching a stall... time to nose down and add a bit of throttle.
Old Aug 02, 2012, 05:36 AM
Bravo47 is offline
Australia
Joined Jun 2010
not sure if full throttle is required for every turn, but speed certainly is the key.
I've had a couple of close calls with my T-45 through not powering into the turn. The wing has twice tipped on me, and i was lucky i had the altitude to pull out. I guess full throttle or not would depend a lot on your thrust spec. I would not advise anybody new to EDF not to punch throttle through the turn though.
Old Aug 02, 2012, 06:03 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
There are still too many propeller people in the EDF world
Full Throttle on EDF , if not a vector EDF .. means NOTHING
All that matter is the speed compare to the wind
Control surface if not blown by relative speed in compare to the air ... get no ventilation from the EDF unit ... like most propeller plane have when throttle is applied.
I'm gliding with my T-45 with dead throttle ... and I have no problem ... stall happen only at very very low speed .... assuming you did not transform the T-45 in a flying brick
Keep the T-45 light ... and it will fly beautifully ... this EDF is not the bird for make speed record ... in my view stock speed with stock motor and 3S is already fast enough for enjoy the bird ... and more then speed ... what is nice is do some acrobatics stuff .. like loops ... and it loop from level in stock without a problem.
Tchuss
e_lm_70
ps: Sorry ... reading back I see too many you ... I mean a generic reader ... not the good m_ark
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 02, 2012, 06:29 AM
perfect1 is offline
Find More Posts by perfect1
Singapore, Singapore
Joined Jul 2012
Someone told me the stock Esc will burn out quite easily in the 64mm T45 when using 3s 2200mah batt. I plan to put in an align 60A esc(from my Trex500) but i am afraid that it will make the plane heavier than it should be. Any advice please. I am new to EDF. I just want to fly around without doing anything crazy. Thanks.
perfect1 is offline Find More Posts by perfect1
Old Aug 02, 2012, 06:36 AM
e_lm_70 is offline
Austria
Joined Jan 2004
The OLD stock ESC, was rated 50Amp (It has a mark on the PCB MC50A) ... once placed under the two upper red air intake, it was not problematic at all about the power.
The common issue was some strange reset on full power .... making the T-45 risky and unpredictable.
I have a HK 60Amp on my T-45 the weight difference is minimal ... adding up to 100 gram or even 150 will not change much.
But I read here somebody has double the weight ... I mean ... it is fine ... somebody like a ultra fast flying brick ... somebody like something more light and gentle ...
Tchuss
e_lm_70
Old Aug 02, 2012, 06:46 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
agreed, i'm flying mine with a 80 amp hk simple series e.s.c., stock fan and a 2850 4 cell ...
i feel this is about the best this airframe is gonna fly.... more weight will make it too heavy...
i chop throttle when it's about 4 feet off the deck and feed in up until it touches the ground.. it's still a floater..... mine has 25 or so flights on it with this set-up.
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Aug 04, 2012, 10:01 AM
perfect1 is offline
Joined Jul 2012
orange rx sucks
Thanks for the feedback. Today i maiden my T45 using thunder power 3s 2200mah, 60A ESC and an orange rx (6ch with satellite rx)...My friend handlaunch it for me. Full throttle and full back elevator, it nearly stall. Quite happy with the power of the stock motor and the fan. I am flying it around using half throttle most of the time. Even for a EDF newbie like me, i feel that it is quite easy to fly. Great plane. My all-up-weight is 800g. During one turn, i use too little throttle and it crash. After some repair, it is up again. During the second flight, the rx fail me at about 200m away. I did a full range test after the crash and found that it lost its signal at exactly the point i crash it. It is time for me to buy a spectrum rx. Orange rx sucks.
Old Aug 04, 2012, 10:14 AM
iflyrc1012's Avatar
bklyn n.y.
perfect1,
i have been using hk orange r/x's for two years and have never had one fail on me yet....did you do a proper range check before flying it???
you should have your transmitter checked...maybe that's the problem...
Old Aug 05, 2012, 03:20 AM
Lejna is offline
Find More Posts by Lejna
Joined Sep 2010
Hi all
I want to buy my first jet plane
http://www.hobbyking.com/hobbyking/s..._Kit_only.html
and I need help to completing he 4S setup
motor - http://www.hobbyking.com/hobbyking/s..._for_64mm.html or better 3800KV or some other ??
EDF Ducted Fan Unit 7Blade 2.5inch 64mm - http://www.hobbyking.com/hobbyking/s...inch_64mm.html
ESC - http://www.hobbyking.com/hobbyking/s...k_70A_ESC.html this ?? or some other ??
which servo and battery will be good ??
Thx for a help
Lejna is offline Find More Posts by Lejna
Old Aug 05, 2012, 05:05 AM
perfect1 is offline
Joined Jul 2012
range check
Today i do a full range check on the ground using my DSX9 with a spectrum 6chn rx with satellite. Signal is still strong at 400 plus metres. I will not fly this far as i cant even see the orientation of my plane. Maybe yours is the 1st few batch. I has learn my lesson.
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
