Old Jul 01, 2012, 11:51 AM
PsyQuad is offline
Find More Posts by PsyQuad
Joined Feb 2012
Originally Posted by iflyrc1012 View Post
the fan blades face forward, the motor is towards the rear of the plane....
I flipped it 180.
Now the 3 cables are a bit in the way of the air flow from the fan, is that a biggie?
To minimize that i need to make a hole in the fan unit and the plane to rewire them...
PsyQuad is offline Find More Posts by PsyQuad
Old Jul 01, 2012, 12:05 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
the 3 wires usually get routed around the fan. don't cut a hole in the housing, just make a
route around the fan in the foam fuse by hogging out a bit of foam then make sure the fan is
aligned straight, and close her up...
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Jul 01, 2012, 12:18 PM
PsyQuad is offline
Joined Feb 2012
Busted Fan
Busted Motor
All garbage now i think.
How the did this happen....
The motor melted into the motor housing.
It didn't fit well to begin with, i had to expand the fan slot but , now it just melted in there, worked fine on tests before i flipped the motor direction... oh god.
Edit:
I got the motor out finally... it melted into the fan duct.
I will test it now but considering the amount of plastic "filings" inside the motor even if it works it will probably have it's performance greatly affected.
Let's hope the ESC is ok, can this damage the ESC?
Old Jul 01, 2012, 12:37 PM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
The ESC is probably OK, looks like the fan rubbed the housing, loading the motor, drawing more current and heating the motor.
1) Does the motor still run?
2) Did you test the motor+fan before you installed them?
Before you install a new fan, first do some test runs to break it in. Do them in bursts, starting low and gradually going up to full throttle. Do not hold throttle for more than 5 seconds. This will let you know if the fan is rubbing; if it is, this will also allow the fan unit to "self-grind" to fit, as well as check the balance of the fan.
If the fan housing is a tight fit, there is a chance that the housing could be slightly distored and pinched, where the fan blades make contact. Again, short bursts will tell you if they are.
fredmdbud is online now Find More Posts by fredmdbud
Old Jul 01, 2012, 01:25 PM
PsyQuad is offline
Joined Feb 2012
Ok thanks!
I dremmeled, and sand-papered and enlarged the duct.
I put everything back in place and it seems OK now...
How much performance the motor suffered only the maiden will tell.
If it works like a** i will buy a new motor, if it works fine then it's all good
Old Jul 01, 2012, 07:36 PM
m_ark is online now
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
Originally Posted by PsyQuad View Post
Ok thanks!
i don't know why anyone hasn't suggested yet, but that fan pitch +7 blades is probably too much for your little motor.
I don't know what the KV on your motor is, but i had that same fan and mounted it on a 2836 3600kv from Hobbyking rated for 35 amps. The fan was way too much load for my on 4s (got hot and cracked magnets), and only gave around 500g thrust on 3s.
basically the fan is an amp hog and I threw the two copies I had away, in preference for a 6 blade system with less aggressive pitch.
Of course your experience with it might be completely different, and perhaps i was doing something wrong.
the motor you've chosen is rated to 21 amps
m_ark is online now Find More Posts by m_ark
Old Jul 01, 2012, 09:51 PM
V-Man is offline
Find More Posts by V-Man
Airplane and Heli Flyer
V-Man's Avatar
Canada, QC, Montreal
Joined Dec 2009
Sounds like a good reason to get a more powerful motor. Speed!
(Jokes aside, any reason a more powerful motor won't fit in there? Might need a bigger ESC and battery, though.)
V-Man is offline Find More Posts by V-Man
Old Jul 01, 2012, 11:11 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Here are the specs of a motor included in one motor+EDF combo (6-blade fan):
CS450-4500-30EDF ( 4500Kv ), 3S - 4S ( 11.1v -14.8v ), 900W Max, 11.1v, static thrust around 800g (37A) , 14.8v Around 1200g (56A)
Old Jul 07, 2012, 11:45 AM
Leojet is offline
Find More Posts by Leojet
Joined May 2011
It's an "Haoye" with seven blades, ok, i had one and sound great, like a real jet, but, it's a "ampeater"!!!!!!!.
I had the same problem, melt the fan duct and attachment of the engine at high temperatures, remember, if you have a fan with an agressive blade pitch the motor must should make a big effort!!!!!!!..
My advice is that you buy a 4500 cyclone edf unit.The plane come alive, you can choose 11.1 volts for a quiet flight or 14.8 if you want a bit of speed and agressive flight.
The cyclone fit perfectly, you should not do anything or change nothing, only put the double face 3m band for lock the unit!.
I forgot to tell you that you should use a esc of more than 50 amps, 60/80 amps for safe flying.
My settings:
4500 KV CYCLONE EDF SIX BLADES (RC-CASTLE)
SKYWING 80 AMP ESC
3300 MAH 14.8 VOLTS
Ok, here a videos of my t-45 ,were performed in the old airport of my city (Trelew - Chubut-Patagonia Argentina).The airport was closed for the Airliners, but the flying club still operate in it.
mas vuelos jet edf trelew!! (6 min 2 sec)
jet en trelew !!! (4 min 58 sec)
Bye and greetings from "The Patagonia".
Leojet is offline Find More Posts by Leojet
Old Jul 08, 2012, 11:54 AM
PsyQuad is offline
Joined Feb 2012
My settings:
SKYWING 80 AMP ESC
3300 MAH 14.8 VOLTS
This one?
http://edfhobbies.com/index.php?rout...product_id=162
Old Jul 08, 2012, 02:44 PM
Flying By is offline
Find More Posts by Flying By
Canada, MB
Joined Feb 2012
Probably this one: http://rc-castle.com/shop/product_in...oducts_id=1905
Flying By is offline Find More Posts by Flying By
Old Jul 08, 2012, 08:49 PM
giantkevmiester is offline
Find More Posts by giantkevmiester
United States, CO, Lakewood
Joined May 2011
Originally Posted by vanderbrander View Post
Just put in one of these and you'll never have to worry about your ESC again. It's light (for it's size) has a 5 amp bec and is absolutely bomb proof. I have several of these for a few years in different jets and they never give me any issues.
http://www.hobbyking.com/hobbyking/s...w_5A_SBEC.html
hey vanderbrander, do you need any mods to fit this esc into the hawk? it seems rather chunky. Also have you found any good way to route the esc wires through the fuse to the canopy area, it is really tricky and rather time consuming, and i am pretty sure this esc uses thicker wires than the one i am currently using. Does this thing really have an off/on switch and is it reliable?
giantkevmiester is offline Find More Posts by giantkevmiester
Old Jul 09, 2012, 08:59 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, L'Orignal
Joined Nov 2010
Only minor mods to fit the ESC. I put mine in the cutout directly in front of the fan. That way the esc sits pretty flush in the airflow and the wires reach the motor and you then only need a short extension for the battery wires to make it to the cockpit area. Fishing the wires can be a pain. Use a piece of stiff wire as a pull thru, tape the battery wires to the pull thru wire and gently work them thru the hole.
I'm sure you'll get it eventually it's not that bad
vanderbrander is offline Find More Posts by vanderbrander
Old Jul 20, 2012, 11:28 PM
Leojet is offline
Joined May 2011
Ok, but i have bought the dinamic balanced cyclone 64 mm edf.
I dont like the metal unit, its heavy and the performances are the same as the plastic.
Now im looking for another cyclone edf for my second t-45, i have another two but are waiting my second Su-34 Fullback unit..
Old Jul 26, 2012, 08:03 PM
Petrik59 is offline
Find More Posts by Petrik59
Petrik59's Avatar
Sverige, Södermanlands Län, Eskilstuna
Replacement for stock B3830 Brushless Outrunner 4300kv
Hi,
Anyone that knows if HK have any replacement motor that fit the 64mm fan from the T-45 GosHawk?
The bearing in my motor is really bad and sound terrible. So eather new motor or new bearings. I do not want to change the whole EDF just the motor.
This is the EDF and motor.
I can find no text or label on the motor so I do not know what it is exactly.
The EDF is now glued in the plane so I just want to change the motor.
Petrik59 is offline Find More Posts by Petrik59
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 10:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 03:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 05, 2010 12:37 AM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 11:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 05:44 PM
