Austria
Joined Jan 2004
Tchuss e_lm_70 edit: As well, location of ESC is important, I put mine in the airflow from the two top air intake ... it I recall right stock ESC location was not having any ventilation |
Just put in one of these and you'll never have to worry about your ESC again. It's light (for it's size) has a 5 amp bec and is absolutely bomb proof. I have several of these for a few years in different jets and they never give me any issues.
http://www.hobbyking.com/hobbyking/s...w_5A_SBEC.html |
Austria
Joined Jan 2004
![]() After too many failure from Stock ESC, I did move to this one: http://www.hobbyking.com/hobbyking/s...C_4A_UBEC.html It is working without problem ... for less then half priceTchuss e_lm_70 ps: Stock has 2 servos ... so 5amp BEC is not really needed ... even if you change to 3 servos ...anyhow. my cheap ESC had 4amp BEC
Joined Feb 2012
I am considering the T-45 as my trainer EDF Jet.
http://www.hobbyking.com/hobbyking/s...dProduct=12942 I know that there are lots of motor/fan unit mods/options on here, but I want to hear from those running the stock PNP model motor/edf using a 3S 2200mah battery (as I have many of those). I will upgrade the ESC. So those flying or have flown with the stock motor/edf, running 2200mah 3S batteries: 1. Does it fly well? Some report that it doesn't fly at all, others say it flies fine... 2. I am not looking for big speed, but what kind of top end does the stock set up have with 3S? 3. What kind of flight time using this 3S setup? 4. I see that some have used 4S batteries, but will the stock motor handle that (with an upgraded ESC of course)? I hope that I can test EDF's out for little expense to see if I like them...so I don't want to purchase different batteries or motors/edf units to start off. At $70 + ESC if the stock set up is good for training with a 3S, then there is nothing to lose in trying it...if I have to purchase the kit and purchase motor/edf, and different batteries, then I need to consider all my options (and get Mrs. Boss's stamp of approval). |
Austria
Joined Jan 2004
I never flown it stock ... but I made from day 1 the dual ailerons I flown stock ESC and motor many times ... but ... randomly at start up, after few seconds, the ESC was sort of making a reset, so did switch off power, luckily BEC was all time working. This problem was reported by many people ... eventually I manage to take off with partial throttle .. eventually, putting back the stick to low position, you can re-arm the ESC ... so only 1 or 2 second of off power ... Anyhow, old ESC was risky to be used ... and eventually I trashed it. Motor and EDF are good. On 3S, stock speed is decent ... and you get 3m20s of full power with 2200 3S ... and almost 4m full power with 2850 3S (this still fit in the stock battery slot) Also, have a look of the elevator servo, mine came unglued after 1 flight ... anyhow, after 10/15 flights I notice it is not accurate anymore. So, in my case: From the PNP solution ... ESC has been removed, and so the 2 servos are gone for 3 good servos. Considering the little difference in price between ARF and PNF, I think PNF solution still make sense Tchuss e_lm_70 ps: As we speak, it is possible that the ESC used in the new PNF are not faulty as the old one ... |
Australia
Joined Jun 2010
I purchased the kit version, then added this $40 4s EDF unit.
Link- http://www.hobbyking.com/hobbyking/s...v_45A_ESC.html Its not overly fast, so I suspect the stock setup would be quite slow. I think you need the extra power to get out of trouble with these jets. If you want an EDF that flies slow without to much of a stall worry then consider the F9F Panther. Link- http://www.hobbyking.com/hobbyking/s...dProduct=11407 Mick |
you may be right at the upper limit of that 50 amp e.s.c...my hawk pulls 47 amps , but i'm running 4 cells
the other issue is venting your e.s.c. try to get a nice airflow over and around it, believe it or not, that makes a real difference.. i have an e.d.f. 64mm warbird, Me182, when it was stock it only pulled 25 amps so i figured the stock 30 amp esc was good to go, but it was buried in the fuse, and got no air. and you guessed it, the first hot day i flew it, it smoked.... i didn't lose the plane, and replaced the e.s.c. with another 30 amp, but i made sure the airflow around it was unobstructed and large enough for the job, now that is one of my favorite planes to fly |
Joined Aug 2010
Hope this helps |
Joined Feb 2012
Thanks for all the great info so far. Currently leaning towards the PNF version just to get my feet wet.
Any recent purchases where you are receiving the 50A ESC with the model? When I read "It's not rocket fast. And is slower then my HZ Supercub." I almost stopped, but read on that the SC was modded. I hope it wouldn't be slower than my good ol stock Super Cub. Do you think this model would fly 45-50 mph on stock setup with a 3S? (with upgraded ESC). |
Austria
Joined Jan 2004
It make loops from level without problem Personally I did not feel the need to go 4s so far Tchuss E_lm_70 |
United States, CO, Lakewood
Joined May 2011
I fly on 3s and it's on par with my pz spitfire, so I say it's doing about 60 flat and level, also it was my first successful edf after a couple of trash ones I picked up at bh, one of them was an a-10 that flew with a ni-mh. It took 200 ft to rotate and then immediately stalled and crashed.... Never buy from bh.
| Thread Tools | |
| New Product F4D Skyray 64mm EDF by FMS Model, now at Hobby Lobby | Joe 1320 | Foamy EDFs | 785 | May 06, 2013 08:21 PM |
| Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review | Spackles94 | Foamy EDFs | 69 | May 19, 2012 02:46 AM |
| Discussion Hobby King A4 Blue Angels EDF Jet | airbagit13 | Electric Ducted Fan Jet Talk | 8 | Nov 04, 2010 11:37 PM |
| For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) | The Don | Aircraft - Electric - Jets (FS/W) | 10 | Dec 07, 2008 10:24 PM |
| Discussion broken fan on 64mm sapac t45 edf | newguy2005 | Foamy EDFs | 0 | Jul 19, 2008 04:44 PM |
