Old Nov 30, 2011, 03:20 PM
Force10 is offline
Find More Posts by Force10
Australia, NSW
Joined Mar 2011
Hi strike3
I have had few incidents during testing where the stabilizer had few contacts with wall and also my 2 year old dropped it from the table which bent the stabilizer I have managed to straighten it but can see a indent at that spot and think that it is bit week at those spots Also when the elevators move I can see stabilizer is not rock solid as it moves at those week points. I might not do it straight away but first take it out for few flights and access it
Force10 is offline Find More Posts by Force10
Old Nov 30, 2011, 03:43 PM
Strike3 is offline
Find More Posts by Strike3
I don't want to land yet!
Joined Jan 2010
You could try putting carbon rods (2mm) in it to stiffen it up... mine moves slightly too, I think it is because of the way the whole tail section is separated from the fuse... no big problem...
Strike3 is offline Find More Posts by Strike3
Old Nov 30, 2011, 05:21 PM
cloaked is offline
Find More Posts by cloaked
Why did I sell them all.
cloaked's Avatar
Australia, NSW, Sutherland
Joined Dec 2010
Clear Packing tapes works wonders.
cloaked is offline Find More Posts by cloaked
Old Nov 30, 2011, 05:58 PM
m_ark is offline
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
+1
the styrene (?) stabilisers come with a skin that holds their rigidity - replace that with packing tape and or carbon fiber /bamboo skewers and they'll be as strong as they ever were.
the flexing you see is due to the control system not being well designed. if you were to replace the control surface horns with ball links and appropriate connectors, they would rotate as necessary and the horizontal stabiliser wouldn't flex as much.
I made a 1/4" balsa tail and painted it white for mine and it's added noticable weight to the tail, which reduces flight times.
i'm thinking about cutting circles out of the broad sections and iron on covering (or more packing tape).
m_ark is offline Find More Posts by m_ark
Old Nov 30, 2011, 06:03 PM
Strike3 is offline
Joined Jan 2010
Yeah you're right... The angles are not helping either with the single servo position trying to drive the hinges which don't sit at the right angle... They bind slightly but the foam allows it to move ok... No real issue
Old Nov 30, 2011, 10:25 PM
Force10 is offline
Australia, NSW
Joined Mar 2011
I have some iron on film I might try that see if it makes any difference or may be insert couple of carbon rods and then iron on film . Will do it over the weekend will let you guys know how I go
Old Dec 01, 2011, 02:14 AM
m_ark is offline
Gravity sucks.
Joined Mar 2011
Dunno how a hot iron would go on the foam - i was talking about ironing film covering onto balsa.
Old Dec 01, 2011, 05:24 AM
Force10 is offline
Australia, NSW
Joined Mar 2011
I have used hot iron on foam with my super cub lp at it worked fine I will give it a go
Old Dec 02, 2011, 10:52 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Video from today @ A51. my first video attempt with the HK HD Wingcam. Enjoy :-)
Hawks @ A51 (6 min 44 sec)
jim350 is offline Find More Posts by jim350
Old Dec 02, 2011, 11:01 PM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
Nice Jim. Geez you can really see the flex in the vertical stab.
ozzi supercub is offline Find More Posts by ozzi supercub
Old Dec 02, 2011, 11:31 PM
Strike3 is offline
Joined Jan 2010
Cool Jim... definitely a better camera than mine!
You were flying too high for us at the start, although we were dogging each other for the cameras as well... certainly shows the closing speeds
I'll do some editing later, gotta get the pizza oven fired up... my daughter has 5 friends staying over tonight... OH NO, 14 year olds!
Hope I get some sleep for tomorrow's flying... should be nice again!
Old Dec 03, 2011, 07:29 AM
Strike3 is offline
Joined Jan 2010
Here's a bit more Hawk action from today...
Hobbyking T45 Hawk's dogfight at Area51 (6 min 31 sec)
Old Dec 04, 2011, 04:09 AM
Strike3 is offline
Joined Jan 2010
Chasing a Mig15..
Hobbyking RC T45 Hawk & Mig15 70mm EDF (6 min 16 sec)
Old Dec 04, 2011, 05:48 AM
Force10 is offline
Australia, NSW
Joined Mar 2011
Great video mate
Old Dec 04, 2011, 09:54 PM
short_circuit is offline
Find More Posts by short_circuit
Joined Jan 2011
Just received my kit. I see that theres no markings on the ESC, just a black heatshrink tube.
Is this still the 30A or is it higher than that?
Also, what mods should I be looking at doing before the maiden? I see that people recommend a larger amp. ESC. Any structural mods?
Also, can anyone point out the specs of the stock motor?
short_circuit is offline Find More Posts by short_circuit
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
