Old Nov 28, 2011, 02:00 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
The whole video was over 14 minutes long. I flew for 3 minutes first time when the cam wasn't set right too....
I can see in the vid the directions I was flying as you guys called the turns to get me back home. I need to be able to see more of the ground under the jet - that canopy blocked what I usually can see when it was mounted on the Moth. I simply couldn't see the field at all.
It was a 5000mah 40C 4S lipo.
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 28, 2011, 02:20 AM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Wow now watching the video i can understand how Strike3 looked like a mouse cursor. you did an excellent job of following him, especially when he disappears through the houses.
jim350 is offline Find More Posts by jim350
Old Nov 28, 2011, 02:37 AM
m_ark is offline
Find More Posts by m_ark
Gravity sucks.
Australia, QLD, Toowoomba
Joined Mar 2011
hmmm, FPV dogfighting T-45's - anyone? haha
m_ark is offline Find More Posts by m_ark
Old Nov 28, 2011, 03:42 AM
Strike3 is offline
Find More Posts by Strike3
I don't want to land yet!
Joined Jan 2010
Might need some bright strobing LED's to make them more visible
Strike3 is offline Find More Posts by Strike3
Old Nov 28, 2011, 04:35 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I got my xenon strobe I made for my Hawk sitting on the bench still... time to install it?
Old Nov 28, 2011, 04:45 AM
Force10 is offline
Find More Posts by Force10
Australia, NSW
Joined Mar 2011
Hi guys
Just got new t45 last week and have done all the mods ailerons rudder flaps and so on but really need some help before I go for my first flight as this is my first EDF can someone please tell me how much movement should I have on my elevator I think I'm not getting enough may be somewhere between 5 to 10 degrees is there any way I can increase that. Rest of the control surfaces have enough movement
Any help or tips will be much appreciated
Force10 is offline Find More Posts by Force10
Old Nov 28, 2011, 05:04 PM
m_ark is offline
Gravity sucks.
Joined Mar 2011
Originally Posted by Force10 View Post
Hi guys
elevator control surface is increased by moving the control link closer to the base of the control surface horn and farther from the root of the servo horn, deflection is measured more often in millimetres than degrees - I'm not sure off the top of my head but my elevator deflection is something like +/- 8mm at the trailing edge of the control surface.
i also run with a generous dose of exponential - like 20-30% centre stick deadening. - i find that i don't have to fly with dual rates setup this way.
Old Nov 28, 2011, 06:10 PM
Force10 is offline
Australia, NSW
Joined Mar 2011
Thanks for your reply m_ark I think I have the control horns mounted at the right position but just to double check please see picture below and total deflection in mm is about 5mm is that enough if not I tried increasing the length of the control rod but im already on maximum i dont understand what is that i m doing wrong
Old Nov 28, 2011, 07:58 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Take a photo of your elevator servo installation. Looking at your photo, the pushrod linkages are all the way out - I have a feeling you may have installed the elevator servo the wrong way around.
I can't check on mine at the moment (packed up for my move) but I'm pretty sure the servo output spline needs to be toward the tail, not toward the nose.
Maybe someone else can jump in and confirm?
Other than that, if the servo linkage is on the last hole of the servo arm and the elevator linkage is on the 2nd last hole of the elevator arm, you will have plenty of throw with your rates set at 100%.
I'm like M_ARK, I fly with 30% expo and no dual rates on elevator.
vanderbrander is offline Find More Posts by vanderbrander
Old Nov 28, 2011, 09:40 PM
m_ark is offline
Gravity sucks.
Joined Mar 2011
the control horns are in the right position but in my limited experience i might suggest you have them the wrong way around? If you turn them 180 degrees they will be closer by about 5mm to the servo, and give better clearance to the control arm when activated.
Something else to consider is hinging the control surface at the contol horn.
You said this was your first EDF - is it also your first rc jet?
Old Nov 29, 2011, 03:08 AM
Force10 is offline
Australia, NSW
Joined Mar 2011
Thanks guys for you help I will post the picture of my servo installation tonight.M_ark I have Trojan t28d that I have been flying for a while but before that I was flying heli( blade 450) but this is the first jet that I have bought in kit format and assembled it my self and I know I have lot of learning to do
Old Nov 29, 2011, 11:55 PM
Force10 is offline
Australia, NSW
Joined Mar 2011
Thank you M_ark i turned the servo horns around 180 degrees and it is working fine now getting enough movement .Thanks Vanderbrander for your input
Old Nov 30, 2011, 12:55 AM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Hi Force10.
You have to take a look to your elevator horn.
The clevis pin has to be at the level of the hinge line. If all horns at 90 deg, than you should have equal up and down movement.
Takis
takiss is offline Find More Posts by takiss
Old Nov 30, 2011, 05:38 AM
Force10 is offline
Australia, NSW
Joined Mar 2011
Hi Takiss
Thanks for your response could you please explain little bit more as how to get Clavis pin in line with the hinge line. I'm also considering building whole horizontal stabilizer and elevators with balsa wood would that work?
Old Nov 30, 2011, 05:55 AM
Strike3 is offline
Joined Jan 2010
The linkage where your rod fixes to the control horn should be as close as possible to the point where the surface pivots... then you can get full movement. Imagine for example that you have the clevis pin at the very back edge of the elevator surface, with full servo movement the deflection will only be small...
Balsa would work but why... the stock ones are fine.
New Product F4D Skyray 64mm EDF by FMS Model Joe 1320 Foamy EDFs 1032 Nov 30, 2015 09:00 PM
Article G&C Hobby F-16 "Fighting Falcon" 64mm EDF from NitroPlanes Review Spackles94 Foamy EDFs 69 May 19, 2012 02:46 AM
Discussion Hobby King A4 Blue Angels EDF Jet airbagit13 Electric Ducted Fan Jet Talk 8 Nov 04, 2010 11:37 PM
For Sale Replacement 64mm EDF fan units for EDO and Hobby Lobby jets (REDUCED) The Don Aircraft - Electric - Jets (FS/W) 10 Dec 07, 2008 10:24 PM
Discussion broken fan on 64mm sapac t45 edf newguy2005 Foamy EDFs 0 Jul 19, 2008 04:44 PM
