Old Oct 06, 2010, 04:10 PM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
OSD PRO with PPM RX
I am not clear if the OSD PRO RTH feature will work with PPM RXs that implement their own hold or failsafe.
I use PPM Corona RXs on the whole, the standard ones implement hold on loss of signal and the synth versions will implement failsafe.
Does the RTH feature work with these RXs ?
srnet is online now Find More Posts by srnet
Old Oct 07, 2010, 01:25 AM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Yes, that works fine. Lots of people using the Corona with OSD Pro. Just select "PCM/Failsafe" instead of "PPM/no failsafe" in the safety wizard.
billpa is offline Find More Posts by billpa
Site Sponsor
Question PPM to TX problem with arduino generated PPM Nase DIY Electronics 64 Oct 15, 2014 12:16 PM
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 03:59 PM
Help! Elogger Throttle, OSD PRO throttle in/out, RX and ESC metalfred Eagle Tree Systems 6 Jul 01, 2010 02:27 AM
Discussion How to obtain a PPM signal with a Royal Pro or Royal Evo (firmware 3.30) YannickF DIY Electronics 0 Nov 03, 2009 12:17 PM
Discussion Help with my ET OSD Pro & RangeVideo Tx harness Cralis FPV Talk 122 Sep 11, 2009 11:35 AM
