My Carl Goldberg Electra Project
Back around 1992-1993 or so, right around the time I moved out of Mom's house, I bought an Electra Deluxe kit from the LHS in my hometown.
Did not get around to building it until sometime later, somewhere in the 1990's I built the vertical and horozontal stab. Around 2000 I built the right wing at a friends house. By 2003 I was splitting a house with some other guys and the Electra was stored on top of my wardrobe. I didn't have room to build it and it wound up sitting there for 7 years. I bought a house of my own about a month ago and even though I'm still a bit cramped for building space, I want to finish her up and fly. Part of my plan was to go out and get myself a RTF foam sailplane to learn on, so I purchased a Radian a couple of weeks ago and have been flying that. Last night I pulled the box out and checked to see if I still had all the parts after all this time. Thankfully it looks like everything is still there. I went out last night and got some building supplies, and began work on the left wing. This is going to be my first build ever. After 18 years the Electra design is a bit dated now. I plan on omitting the Turbo 550 motor, spinner, and prop that came with my Electra. I'll go with a brushless motor, ESC, and a folding prop instead. Pictures coming soon. In the meantime I'm reading these threads: http://www.rcgroups.com/forums/showt...=551753&page=3 http://www.rcgroups.com/forums/showt...php?t=1175043/ I only hope I can make mine look as nice as theirs!
Doing some lunchtime research on brushless motors for my Electra. It appears that most people doing this sort of conversion recommend this engine:
http://www.hobbycity.com/hobbyking/s...idProduct=2106 So here's my newbie questions: This is an outrunner motor, so that means when it's powered up, it spins, correct? Would it have to be mounted in a different way from the Turbo 550, or can I complete the fuselage as per the original plans and just pop the A22-20L into the mount instead of the Turbo 550? -- edit There's also some pilots running this engine in the Electra: http://www.e-fliterc.com/Products/De...rodID=EFLM1305 which my LHS sells, so this could be a safe choice And some pilots are running this one: http://www.hobbycity.com/hobbycity/s...idproduct=3883 gah, the choices are dizzying. Looks like all of them would require modding the firewall and mounting to that. |
Joined Mar 2009
Actually, the only thing that's really dated about it is the power package that you're not going with. The plane design itself is still around in various forms from several manufacturers. I flew an Electra back in the day. It was a pretty decent floater! Back then, a 15 minute flight meant bragging rights. Good luck with it! I can only imagine that with todays power packages that it will be that much more fun. Robbie |
Do you guys think this combo would work?
A22-20L Folding Prop Spinner 35mm Folding Prop Spinner 35mm Aeronaut CAM 10 x 6 hexTronik PRO 36A BESC (backordered) hmm.. all the appropriate ESC's at Hobby King seem to be backordered.. for this motor I need a spinner for a 3mm shaft, correct? --edit: maybe this ESC instead. |
Yeah, the dog thing is interesting...I am a dog person, own a 110lb Black Lab, love'em. A good size group of us fly at the local highschool, there is about 50 acres of nice mowed green grass and it is about 1000 ft. wide, the whole area looks more like a public park than the back of a school, on the weekends there are all sorts of people out using the space. Some of these dog owners almost seem to have an attitiude...like we arent suppose to be there, and that its OK for them to let the (big) dogs run free, with no leash, which I really dont have a problem with, until they purposely walk right through the small area that we have planes on the ground. Sometimes your in the air with one, following it, and also trying to watch your plane on the ground so that it doesnt get trampled and kicked around.
I have seen dog owners sense a bit of frustration from us R/C guys, they say "thought you guys arent suppose to fly here?" I tell them that the local school district allows electric and non-powered flight, and remind them that there is however a Leash Law! Then add that "our planes dont crap all over the field where kids play" Seems to end it pretty quick. OK. As for the motor mount, I did much the same thing as some of the pictures in the replys above, I beefed up the firewall, then made a spacer of sorts from a block of hardwood, and sanded it down to the odd shape it needs to be to mount the motor angled to the side and down, so that the output shaft on the outrunner was centered. I used hardwood because balsa does not alow for a very good base to mount (screw) the motor to. I also used an aluminum "turbo" type spinner that allows air to get right to the motor throught the center of the spinner itself, and drilled two cooling holes in the cowl (hind sight may have looked better on the bottom) Hope that helps. I eliminated the center dihedral from the wing mainly because I have a few sailplanes that have a flat center section too, and they fly sooo well, that I thought I would try it here, and it flies very well. Hope this helps. |
P Farley,
Great pictures of your Electra build. My first RC model, way back in '88, way the Electra, actually, I've built two. It's a timeless model, but certainly needs the updated touches you've added. That lipo looks positively lost on the battery "door" . We've come a long way from the days of flying one of these with a 6 cell sub C Nicd pack .I liked your comments on the issue of dogs around the flying site. As an animal lover who happens to be "owned" by a Belgian Shepherd mix, I appreciate your view on owner responsibility. Best of luck with your new Electra ![]() Pete |
electra
Rehabed my electra this year,and it has flown all summer. The plane is powered buy a master air screw folding prop, gear box and brushed 550.
I just had a brand new motor fail after about an hour of flying, so this winter it will be converted to a turnigy 35 36 1300, with the same prop.This plane will fly for hours in good thermel conditions no problem,it does not like gusty conditions, but light steady wind is good.Good luck with your electra, mine was built in 1988 was never flown untill this summer,Im so glad I kept it.Its a real confidense builder. |
Quincy IL
Joined Jul 2006
Built a new body from old plans. Wing and tail feathers from original Electra in the 1980's.
Eflight 450 outrunner Turnigy 30 amp esc and 3 cell 2200 lipos. APC 10 x 6 folding prop. Had to extend the fuse about 4 inches in the nose, move lipos into nose along with ESC. Balances nicely and with a decent nice day get flights longer than an hour. Adjust motor down thrust until little or no throttle to elevator mix is needed. Currently flying via JR PCM 10X with FlyDream 2.4 module and a 6 channel FlyDream receiver. Fun plane Hugh |
Building continues, I'm nearly done with the wing. Trying to work when I can, while taking care of things for the new house as well.
I'm building on a ceiling tile that's on the coffee table in my "man cave". This photo is from when I was working on the left half of the wing on Friday night: |
| Thread Tools | |
| For Sale Carl Goldberg Electra Sailplane $60.00 | solarr | Aircraft - Sailplanes (FS/W) | 1 | Sep 30, 2010 10:04 PM |
| Discussion Covering Carl Goldberg Electra | knfevg | Electric Sailplanes | 2 | Apr 02, 2010 06:16 PM |
| For Sale Carl Goldberg Electra | Cyril | Aircraft - Sailplanes (FS/W) | 2 | Feb 10, 2010 12:32 PM |
| For Sale Carl Goldberg Electra, Electric Sailplane. | solarr | Aircraft - Sailplanes (FS/W) | 0 | Dec 20, 2009 02:37 PM |
| For Sale Carl Goldberg Electra | solarr | Aircraft - Sailplanes (FS/W) | 0 | Oct 17, 2009 09:12 AM |
