Old Oct 06, 2010, 08:43 AM
ImmersionRC is offline
Find More Posts by ImmersionRC
Joined Mar 2009
New Product
ImmersionRC PowerBox(AV) - AVAILABLE NOW!
ImmersionRC is proud to announce a new product designed specifically for FPVers.
The ImmersionRC PowerBox(AV) provides a distribution point for both Audio/Video signals, and also DC power, for use in an FPV groundstation.
The buffered video ports accept a single A/V input, using standard 3.5mm FatShark/ImmersionRC jacks, and buffers it to four outputs, also using the compact 3.5mm jacks.
Connecting a pair of goggles or two, an A/V recorder, an antenna tracker is now possible without bulky cinch cables.
The other side of the box takes one or two (redundant) DC power inputs (typically 3s Lipos), and provides four heavily filtered, fused, outputs.
A built-in microcontroller monitors the voltage levels of the input(s) and provides an audible warning at a preset (programmable) voltage level.
The PowerBox ships with custom 5 meter 3.5mm to 3.5mm A/V cables which are ideal to connect the A/V outputs directly to one or more pairs of FatShark goggles.
The PowerBox is currently available to ImmersionRC retailers, and a few retailers have already received their first shipment.
M.S.R.P is $99, and includes the powerbox, and a full cableset.
ImmersionRC is offline Find More Posts by ImmersionRC
Old Oct 06, 2010, 09:24 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
Nice!
A question, does the powerbox use both power inputs at the same time or does it switch between batteries? In other words is it possible to use two batteries with different capacities without risking one battery to charge/drain the other?
boopidoo is offline Find More Posts by boopidoo
Old Oct 06, 2010, 09:38 AM
nabazul is offline
Find More Posts by nabazul
Joined Jun 2010
How does the adjustment of the videolevel on the video out work? I dont see any screws or switches.
nabazul is offline Find More Posts by nabazul
Old Oct 06, 2010, 09:40 AM
Capy-Norway is offline
Find More Posts by Capy-Norway
Capy-Norway's Avatar
Norge
Joined Feb 2009
I see what you did here, the video diversity will be in your Duo box
Capy-Norway is offline Find More Posts by Capy-Norway
Old Oct 06, 2010, 10:23 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
They are there if needed according to the spec sheet
Shikra is offline Find More Posts by Shikra
Old Oct 06, 2010, 10:52 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Originally Posted by boopidoo View Post
Nice!
It switches to the one with highest voltage with a .4V hysteresis, you can thus combine batteries of different capacity, but obviously not of widely different voltage, hence combining a 3S and a 2S doesn't make sense.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Oct 06, 2010, 10:54 AM
ssassen is offline
Joined Jul 2004
You need to remove it from its box, by removing one face plate (2 screws), you'll find a trimmer inside that lets you set video level. By default they come shipped with the level set to 1, hence no amplification, you can however change that from about 0.5 to 1.5x, enough to allow for correcting devices that have a video level which is out of specification.
Cheers,
Sander.
Old Oct 06, 2010, 01:33 PM
nabazul is offline
Joined Jun 2010
Cheers,
Sander.
so this is actually only for the videoinput and not for the different outputs? I am asking because if you put a very long videocable on one of the outputs the signal at the other end is sometimes not strong enough. http://media.elektronik-star.de/imag...28_1_title.jpg those boxes have a screw where you can boost the signal of every single output. Think i missunderstood that from the powerbox's specs. Maybe its something for V 2.0
Old Oct 06, 2010, 01:38 PM
ssassen is offline
Joined Jul 2004
The video level of our video amplifier is not attenuated by cable length, simply due to the fact that our output impedance is low enough for the cable to not matter. Cable lengths up to 25 meter have been tested which showed no ill effect. I think what you have experienced is one of the shortcomings of a cheap and not properly designed video buffer/splitter.
Cheers,
Sander.
Old Oct 06, 2010, 02:57 PM
Blue Collar is offline
Find More Posts by Blue Collar
United States, NE, Omaha
Joined Oct 2005
Sander
Is it possible to have 3 12V outputs and 1 6V output with the powerbox? The 6V output would be for an EZtracker.
Mark
Blue Collar is offline Find More Posts by Blue Collar
Old Oct 06, 2010, 03:02 PM
ssassen is offline
Joined Jul 2004
Originally Posted by Blue Collar View Post
Sander
Mark
No, all outputs are the same voltage as the input. However I use a simple 3A UBEC connected to one of the outputs. Due to the effective LC filtering the noise generated by the UBEC doesn't show up on any of the other output and generally a UBEC running a few digital high torque servos straining to get a heavy antenna pointed is pretty much as dirty as it gets
Cheers,
Sander.
Old Oct 14, 2010, 11:05 PM
ramboky is offline
Find More Posts by ramboky
New Zealand
Joined Apr 2010
Just received my PowerBox. Build quality is of the standard you expect from ImmersionRC products.
I now have EzUHF and EzOSD in the air and EzTracker and PowerBox on the ground. Clean, realiable, single power source solutions.
ramboky is offline Find More Posts by ramboky
Old Oct 15, 2010, 01:58 AM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
I'm getting mine this weekend (I hope ) can't wait!
trappy is offline Find More Posts by trappy
Old Oct 15, 2010, 02:54 PM
jdm66 is offline
Find More Posts by jdm66
jdm66's Avatar
France, Pyrénées Orientales
Joined Feb 2009
Hi
where it's possible to find at +-100 US ?
thank you
jdm66
jdm66 is offline Find More Posts by jdm66
Old Oct 15, 2010, 09:21 PM
ramboky is offline
New Zealand
Joined Apr 2010
I've got ImmersionRC gear before Trappy!? That can't be right!
I really like that this gives me single power source simplicity and security on the ground. No more worrying about which batteries I have charged and which will run out first. Just one big battery to power everything.
Everywhere I looked the price was the similar - 130.00USD. I don't expect you'll find it cheaper.
For Sale ImmersionRC FPV equip 4sale bnhdent Non R/C Items (FS/W) 4 Dec 03, 2010 12:57 PM
Discussion ImmersionRC TrackR2 weirdness. g00bd0g FPV Talk 12 Jul 27, 2009 12:35 PM
Help! Airwave Mic connection to ImmersionRC TX chancesAU FPV Talk 0 Dec 25, 2008 03:05 AM
Discussion FatShark RCV922 + ImmersionRC 10mW Tx now CE certified AnthonyRC FPV Talk 2 Jun 16, 2008 12:52 PM
