Old Nov 24, 2010, 11:55 AM
RetoF3X is offline
Find More Posts by RetoF3X
F3B and F3K
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
I casted lead in brass U-profiles for my FS3. Else you can make the dimension a tenth of a mm smaller and overpaint the lead.
The FAI limit for most of our planes is above 4.2kg (56dm^2*75gr/dm^2) and I flew only in one F3B contest where people were going over 4kg AUW (very windy Kirchheim 2009).
Reto
RetoF3X is offline Find More Posts by RetoF3X
Old Nov 25, 2010, 01:12 PM
jukka is offline
Find More Posts by jukka
Finland
Joined Nov 2007
Originally Posted by mlachow View Post
The 3-view says 2100-3400g. Also note that the wing area is only 54,4 dm2. This is less wing area than any other F3b model out there. Even the Freestyler has an extra 2dm2 of area. That's 843 in2 for the metric impaired. It almost starts looking like a real sailplane.....
Mike, where did you get the three views of Fosa and Cyril.
I have not seen them ever.
Please, could you put them here to the thread?
Jukka
jukka is offline Find More Posts by jukka
Old Nov 28, 2010, 06:14 PM
RetoF3X is offline
F3B and F3K
RetoF3X's Avatar
Joined Mar 2009
FOSA vs FS3, here we go
Mike and I did a day of comparison and we got some data. Draw any conclusion you want (Mike and I agree to draw no conclusion out of it):
I have only the launch heights in the earlier morning when we flew distance (after that, my Zlog died). Only weak wind, with more and more thermal activity:
Plane; height; ballast (equal wing loading); line diameter
FS3:269m 0% 1.22mm
FS3:250m 50% 1.12mm
Fosa:234m, 50%, 1.12mm
FS 3, 257m 50% 1.22mm
Fosa: 273m, 50%, 1.15mm
FS3: 289m, 70%, 1.12mm
Fosa: 269m, 70%, 1.12mm
FS3: 201m, 70%, 1.22mm
Fosa: 289m, 70%, 1.12mm
FS3: 257m, 70%, 1.12mm
Fosa: 272m, 70%, 1.12mm
Speed runs in the afternoon:
Fosa:
17.4s
16.4s
17.3s
FS3:
14.11s
19.8s (cut)
17.29s
16.57s
Fosa:15.55s
FS3 17.21s
Fosa:17.33s
FS3:16.16s
Last flights we flew interlaced, condition were varying in the morning and got flater towards the evening. I did not list all the cuts we flew, there were tons of it (sometimes also problems with base B). Mike had a 17.8s with a cut, I had a 18.xs with a cut, both PBs in cutting. Don't remember if the 19.8s was a cut.
Mike has Fosa launch data for his speed runs, where he flew heavier than in distance. I unfortunately don't have mine for the FS3.
Mike was already flying very well with his new plane and the Fosa left a good impression.
Reto
Old Nov 28, 2010, 07:03 PM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Russia, Tomsk Oblast, Kargasoksky District
Joined Sep 2008
Cool pics and post
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Nov 28, 2010, 07:11 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
Look at the photos. This is a Freestyler 3 wing with leading edge aligned with Fosa leading edge. Note that the Fosa has less wing area.
mlachow is offline Find More Posts by mlachow
Old Nov 28, 2010, 07:35 PM
mlachow is offline
Joined Oct 2005
Yes, the 19.8 was a cut. The 17.8 was a 265m launch. The uphill to base B with a side hill valley in between and the windsock in the middle of the course took a while to get used to. Plus the extra overload of only two people to launch and wind down winches and get over to base A without tripping over the winch that was close to the sight. Not enough time to get ready and properly prepare to fly a speed run. And hoping newly trained guys push the buttons correctly. I did add a little nose weight later on and adjusted rates on elevator some.
Air got worse later and it started to cool down.
I did fly some flights just above the wing loading of a Freestyler full of the stock ballast. For you F3j guys, I was flying the thing in no wind at a 20.5 oz/ft2 wing loading. Best launch at that weight was 252m
The 15.55 was a 269m launch, 19.15 wing loading or about 87% for the freestyler guys.
The initial unballasted launch may have been 284m or that could have been some lift later in the flight.
The 289m launch was some distance flying. Nice air, I counted 34 laps in 4 minutes.
Now I need to find a day with wind (and not real cold). I want to see what it does when I have it filled up with ballast at 3750g
Old Nov 28, 2010, 08:01 PM
RetoF3X is offline
F3B and F3K
RetoF3X's Avatar
Joined Mar 2009
I flew all my runs with 70% ballast on the FS3, the 14.11s was in a period of quite good air.
Mike had quite good air on his 17.8s cut run as well, keep in mind that the fastest flight (I am aware of) with cut is about 16.xs.
Mike looked actually quite happy with those high wing loadings, the Fosa could launch and handle them well in the light conditions.
Reto
Old Nov 30, 2010, 07:03 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
So, I guess the real question would be, will you be trying to double up with a second Fosa for the worlds, or not?
I was sursprised to hear a rumor that one of your team mates is changing planes before the worlds.....
R,
Target
target is offline Find More Posts by target
Old Nov 30, 2010, 09:21 AM
mlachow is offline
Joined Oct 2005
R,
Target
Realistically if you want 3 of a model for the worlds, you have to start the year with 4.
Right now I'm just hoping for some nice days the next few months.
Old Nov 30, 2010, 10:12 AM
Avaldes is online now
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Plus there are always new models that the producers release just before the WC so you might have to wait till the last minute to get your planes.
Avaldes is online now Find More Posts by Avaldes
Old Dec 04, 2010, 03:54 PM
Love2Fly is offline
Find More Posts by Love2Fly
Love2Fly's Avatar
Augsburg, Germany
Joined Mar 2001
Hi Fosa Enthusiasts,
Met Jiri in southern Germany today with a friend who picked up his Fosa, simply gorgeous and incredibly well built and finished.
Here are a few pictures of another customer's Fosa with Jiri's RDS linkage pre-installed and the RTF fuselage.
Can't wait for Jiri to build mine.
Enjoy, Martin
Love2Fly is offline Find More Posts by Love2Fly
Old Dec 04, 2010, 09:00 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Mike-
You shoulda been a politician!
Which models willl you likely be using at the WC? Are you as of yet undecided?
R,
Target
Old Dec 20, 2010, 10:58 AM
mlachow is offline
Joined Oct 2005
Not much happening. Winter decided to arrive in December. Next Fosa is on order.
Old Jan 24, 2011, 06:26 PM
mlachow is offline
Joined Oct 2005
All quiet and covered with snow here....
Discussion U/k Open F3b + Electric F3b Trial cagjf3b Multi Task F3X 0 Sep 20, 2010 09:29 AM
Discussion Should I go with a Vampire F3B, Extreme F3B, or any other suggestions? thetechnorat Multi Task F3X 57 Sep 18, 2010 05:22 AM
Discussion baudis zoom wing bolts help! 3lad3 High Performance 3 Aug 15, 2010 05:51 AM
Wanted Right Wing for Baudis Ceres F3B Maki Aircraft - Sailplanes (FS/W) 2 Aug 03, 2010 08:44 PM
Sold Baudis Trinity F3B X-Tail PDX Slope Pilot Aircraft - Sailplanes (FS/W) 2 Apr 03, 2007 11:06 PM
