Old Sep 26, 2012, 08:55 PM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
With respect to RDS, is there a way to help preserve the pocket from wearing out? Some thoughts: polish end of wiper arm or giving the pocket a squirt of graphite powder?
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Sep 26, 2012, 09:11 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
So far, my most used Fosa's RDS is still pretty tight. This is after a year and a half of what I consider heavy use. I haven't done anything special to the system to protect it. Jiri has done a great job with his RDS system.
Tom
Kiesling is online now Find More Posts by Kiesling
Old Sep 26, 2012, 09:20 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Vic-
Just do your best to keep dust and dirt out of the pockets.
A little blast from a can of compressed air with the nose down followed by your dry lube should help keep it young.
SoCal is a harsh dusty environment. Poway is pretty dry, I assume TK might fly there most
Your plane should have it easier compared to that I would think!
target is offline Find More Posts by target
Old Sep 26, 2012, 10:46 PM
Eagle Butte User
Portland, Oregon
Joined May 2002
Thanks Tom and Target. Tom, I appreciate your real world experiences with the Fosa RDS from a competitive pilot's standpoint. I'd probably have to fly mine for 5 years to get the amount of time you have on yours!! And you're right Target. We are pretty blessed to have some nice slope sites up here. Just wish they weren't 1-3 hrs drive away!
So after a 6 month build hiatus I'm back at it. The home projects are finally done... I want to finish this one up before the Fall flying season is over at Eagle Butte.
I have to say my confidence has gotten better with RDS installs. I'm about finished with the flaps now. I find doing the mock up with the servo powered is very helpful. The servo pretty much positions itself in the optimum spot. Some changes I am making to my build are to give up on plans to use a 1450 LiFe pack w/regulator and go old school 4.8v. Elite 1500 pack. With MKS servos I decided it's not worth worrying about the *what ifs*.
Tom, what did you use to hold your ballast in place?
Vic
Old Sep 26, 2012, 10:53 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
The cone and a piece of wood or foam should keep the load back in the tube.
R,
Target
Old Sep 26, 2012, 11:19 PM
Eagle Butte User
Portland, Oregon
Joined May 2002
Ok..think I'll shape some wood rather than getting too fancy...
Old Sep 27, 2012, 03:18 AM
lblife is offline
Find More Posts by lblife
lblife's Avatar
USA, CA, Seal Beach
Joined Aug 2010
Both my Fosa's have a lot of time on the F3F coarse and are still very tight
lblife is offline Find More Posts by lblife
Old Sep 27, 2012, 10:24 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Thats a nice arrangement that Sam has there.
If you keep the plane inverted the cone will keep the block from falling out when a load is in there.
You might add a thread to the block somewhere and attach it to the inner nose with a 6" leash to avoid it dropping out if the cone gets pulled off upright.
The magnet is a nice solution, though, and pouring epoxy in there is an easy way to get a perfect fit. The time you would spend shaping wood gets spent putting tape for a barrier on the parts.
R,
Target
Old Sep 27, 2012, 02:00 PM
en_spt is online now
Find More Posts by en_spt
Also known as simon_t
en_spt's Avatar
Kent, England
Joined Nov 2005
I used a wedge of balsa with velcro glued to the bottom face, and the reverse velcro on the 'skijump' of the ballast tube.
Simon
en_spt is online now Find More Posts by en_spt
Old Oct 08, 2012, 09:57 PM
bluffman is offline
Find More Posts by bluffman
bluffman's Avatar
Joined Sep 2003
Flew the Fosa Lift today at fermin, very light lift 10 to 13. Before I arrived I added the fuse slugs, I put a wide piece of rubber band under the last slug and slid it in seemed like it wasn't going anywhere and it didn't. This was my second outing and at 5lbs14oz the plane flew great even in such light air, landing worked out great no sharp rocks. It will be fun to add all of the wing slugs and fly in bigger air. Ian
bluffman is offline Find More Posts by bluffman
Old Oct 09, 2012, 09:09 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Fermin at 10-13 isn't really "very light lift" for the rest of the world. Ian you are SPOILED!
Glad it went well.
R,
Target
Old Oct 14, 2012, 08:07 PM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Fosa/Fosa Lift
Howdy,
Fresh batch of Fosa/Fosa lift for anyone looking for a great model!
Best,
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Oct 22, 2012, 08:12 PM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
Just got back from Point Fermin, blowing a steady 18mph the fosa lift rocks I left with the biggest smile, it bangs turns AWSOME, I just have to learn how to adjust my set up to get the most out of the plane. Ian
Old Nov 18, 2012, 11:34 AM
Eagle Butte User
Portland, Oregon
Joined May 2002
I opted for MKS 6125e's in my fuselage, but you need to make your own back support for the rear servo since the slide-in support for the 3421/3517 won't work if you want to have access to the servos.
Old Nov 18, 2012, 12:36 PM
David Olson is offline
Find More Posts by David Olson
MCS / NCSS / SVSS / LSC / SAM
David Olson's Avatar
United States, CA, Santa Rosa
Joined Jun 2010
That is just pure "art".
David Olson is offline Find More Posts by David Olson
Discussion U/k Open F3b + Electric F3b Trial cagjf3b Multi Task F3X 0 Sep 20, 2010 09:29 AM
Discussion Should I go with a Vampire F3B, Extreme F3B, or any other suggestions? thetechnorat Multi Task F3X 57 Sep 18, 2010 05:22 AM
Discussion baudis zoom wing bolts help! 3lad3 High Performance 3 Aug 15, 2010 05:51 AM
Wanted Right Wing for Baudis Ceres F3B Maki Aircraft - Sailplanes (FS/W) 2 Aug 03, 2010 08:44 PM
Sold Baudis Trinity F3B X-Tail PDX Slope Pilot Aircraft - Sailplanes (FS/W) 2 Apr 03, 2007 11:06 PM
