Old Aug 14, 2011, 12:34 AM
Ezza is offline
Find More Posts by Ezza
DS= -$ & :-)
Ezza's Avatar
Byron Bay, Australia
Joined Feb 2006
Since buying this plane the conditions haven't permitted much flying with it but today was perfect slermal conditions. I got some good stick time and tuned it 90% now. Very happy with it, so well behaved and looks great in the sky. It does the most axial roll. With a slight dive for speed it requires no down stick at all.
I'm flying at the recommended cg which isn't that nuetral but it does need about 4 clicks of down trim(almost 1mm of down) even in the mild lift conditions today. Anybody else finding this?
Eric
Ezza is offline Find More Posts by Ezza
Old Aug 14, 2011, 09:20 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
So, Are you suggesting that the incidence is off??
This would be odd to me since they nailed it on the Ceres and Cyril both....
R,
Target
target is offline Find More Posts by target
Old Aug 14, 2011, 10:48 AM
David Cortina is offline
Find More Posts by David Cortina
David Cortina's Avatar
United States, CA, San Marcos
No he did not suggest that. Maybe it is a little nose heavy.
David Cortina is offline Find More Posts by David Cortina
Old Aug 14, 2011, 01:50 PM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Just an aside, the more I see the Fosa fly (in TK's hands) the more I like it! Looks like a very competitive model.
-Aaron
Avaldes is offline Find More Posts by Avaldes
Old Aug 14, 2011, 01:56 PM
Stuart B is offline
Find More Posts by Stuart B
AKA RustyKnee
Dorset, UK
Joined Dec 2006
dont you mean tail heavy?
Not a Fosa I know, but my Ceres (aslo Baudis) seems to need a bit of down trim. Wonder if the suggested cg by Jiri is quite rear ward.
Stu
Stuart B is offline Find More Posts by Stuart B
Old Aug 14, 2011, 02:34 PM
If the CG is ahead of the center of lift the plane will pitch up as it accelerates with elevator trim unchanged.
Old Aug 14, 2011, 02:36 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
The recommended CG of 98 mm from the leading edge is a good cg location. Some may say it is on the aggressive side. A slightly more forward CG will help the model track straight a little more easily at slower speeds.
I do not find the incidence to be off at all. For cruise speed the trim is neutral. For speed I use a little bit of down trim (~.5 mm) and for thermal I use a bit of up trim (~.5).
The Fosa is a very competitive model. I think it is more than capable of holding its own against the other top F3B models available. It is very stiff and strong. The RDS is very well done. The fit and finish is excellent. The support and service I get from SoaringUSA and Baudis models is second to none. They really helped me out on short notice to get me models in time for the World Championships. I really don't think I could be happier with my choice of model for the World Championships.
Tom
Kiesling is online now Find More Posts by Kiesling
Old Aug 14, 2011, 02:46 PM
Stuart B is offline
AKA RustyKnee
Dorset, UK
Joined Dec 2006
I remain to be convinced but I am aware of taking the thread going off topic.
I have only seen the Fosa at an F3F comp as I don't do F3B, but it certainly looks like an efficient and fast plane. My Ceres is nicely finished. Baudis do seem to have good build quality.
Stu
Old Aug 14, 2011, 03:29 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Stu
I'm on your side with interpreting the "down trim" situation.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Aug 14, 2011, 03:53 PM
I was not taking a side. I merely stated that it is possible to have a forward CG if the plane tends to pitch up as it is accelerated with a fixed trim position. It is counter intuitive at first glance. Look up static/ dynamic stability. I realize that there are instances that forward trim could be needed in static flight if the CG is too aft.
Old Aug 14, 2011, 03:57 PM
Joined Dec 2005
Please don't tell me to look up anything...
Old Aug 14, 2011, 04:03 PM
OK, please don't look up anything
Old Aug 14, 2011, 05:24 PM
Stuart B is offline
AKA RustyKnee
Dorset, UK
Joined Dec 2006
Cheers Chris
I will check out dynamic stability out of interest.
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Dave- Ezza never posted if he had up or down trim in the model.
R,
Target
Old Aug 14, 2011, 06:30 PM
Ezza is offline
DS= -$ & :-)
Ezza's Avatar
Joined Feb 2006
Hi Guys,
Sorry for the confusion, this is my fault. After reading your comments above it seems my cg is off by 2mm. When I built the plane I measured the centre of the ballast box(I thought 96mm), but after re checking I see that it is 98mm.
I guess the good news is I get to remove some weight and it should fly even better. Even with cg out it flies amazing.
Eric
Discussion U/k Open F3b + Electric F3b Trial cagjf3b Multi Task F3X 0 Sep 20, 2010 09:29 AM
Discussion Should I go with a Vampire F3B, Extreme F3B, or any other suggestions? thetechnorat Multi Task F3X 57 Sep 18, 2010 05:22 AM
Discussion baudis zoom wing bolts help! 3lad3 High Performance 3 Aug 15, 2010 05:51 AM
Wanted Right Wing for Baudis Ceres F3B Maki Aircraft - Sailplanes (FS/W) 2 Aug 03, 2010 08:44 PM
Sold Baudis Trinity F3B X-Tail PDX Slope Pilot Aircraft - Sailplanes (FS/W) 2 Apr 03, 2007 11:06 PM
