4 point hydro 3 point hydro
Wparsons this Is for you..You told me the Miss Elam. Ive been talking about right along.Is not a 3 point hydro?Well here you go.You asked If I wanted to get Into It about the two hull's?Well here's the 4 point video crashing. See the difference between a 4 point hydro hull an the three point Miss Elam.
This Is a 4 point hydro freeze the frame at 16 second's Your again wrong at what a 4 point actually Is!!!!! :
Also the same full size Hydro same hull as our's Is also a 3 point Hydro!!! The Elam Plus 4 point Hydro
That's not my def.. mind you but there's the Miss Elam Both scorpion an myself own are In fact 3 point Hydro's!!!!!!!!Lol....Right OFF A PROBOAT ORDER PAGE... Here's a 3 point hydro def efinition: An RC boat hull design found in some RC powerboats is the hydroplane hull. Unlike the monohull, the hydroplane hull design has more than one surface in contact with the water. This design creates space for trapped air under the boat that helps to lift it up out of the water so that there is less drag (less hull touching the water) and the boat can acheive higher speeds.The 3-point hydro, catamaran, tunnel hull, and outrigger are RC powerboats featuring a hydroplane hull design and known for speed. Outriggers are the fastest of the hydroplane hull designs but the trickiest to handle. Catamarans and tunnel hulls provide a better balance of speed and handling for the beginning racer. AquaCraft Top Speed 2 features a tunnel hull hydroplane design. Pro Boat Miss Llumar is a nitro hydroplane with the 3-point hydro hull and the Pro Boat Miss Elam (Buy Direct) is another example of a hydroplane hull. Pro Boat Apache (Buy Direct) and the Pro Boat Blackjack 26 Brushless (Buy Direct) are electric catamarans. Dumas Hawk Hydroplane 7.5 is an example of an RC outrigger. Also Known As: hydro RC Boat Terms Related to Hydroplane * Flat-Bottom * Monohull * Airboat I need to use your line again!!!!!I love It when people lead others down the wrong path with wrong Info..... I'm getting bent out of shape over it simply because he's giving bad information, and I don't like to see people lead down the wrong path.HAHAHAHA "CLASSIC" Gee also watching both vids over again!!Dont look like much of those front sponsons touch water !!!!!LOL...Also maybe 2 dozen other vids Ive just watched on the 3 pointer's do either..... |
Guys don't listen to mxz70017, he doesn't know what he's talking about at all...
He just claimed the UL1 rides on the transom, but it doesn't. The transom is way out of the water. Just look at any picture of it running... ![]() He's also claiming the front sponsons shouldn't be touching the water, but they should. If they weren't meant to be in the water, the boat would look more like a tunnel hull. There's a very good reason that sponson shape, accuracy and sharp edges make a HUGE difference in how a hydro runs. As for the Elam, I wasn't referring to the canard version, I found references to the full size pickle fork being a 4 point because it had rear ride pads. Not once did I claim that the model miss elam was a 4 point... in fact I said it was a 3 point all along, and that the transom is clear of the water at speed. Coles notes.... a PROPERLY running modern hydro will be running on the trailing edge of the sponsons, and the prop. No part of the transom will be in the water at all. Quote:
ok here we go!!!!
Now you come back In here after asking me straight up whats the UL1 ride on the prop an no riding plates!!!!!Then you come back an tell me that Is all It runs on After you Mr Twist It posted a link to show an describe how that hull style runs on the rear front sponsons an the wetted are of a flat bottom transom In your own post !!!!!Man you should get your facts straight boy!!!! Your own words.....There's three points of contact/lift (sponsons and prop), but there's no ride pads in the rear... How does it stay on the water then??? Does it fly on just the prop??? How about the miss vegas deuce, it's a more traditional looking unlimited hydro... Ok really you can have this boy I am out!!!! |
Outrigger!!!!!LOL
That Info Mr Guru was for a outrigger!!!!!lol... |
OK:
Good, maybe now the quality of posts will go back up. Quote:
And, just as a final nail in your coffin.... That's a stock brushless miss elam... Want to tell me how that rides on the ride pads, with only half the prop in the water? Here's a shot of Darin Jordan's race prepped miss elam: Still don't see any way those ride pads are in the water unless almost the whole prop is submerged... Same boat, at speed... notice the transom (and ride pads) out of the water, and the sponsons on it...
lol exactly!!!!!
The Miss Elam Is a 3 point tunnel hull!!!!
He's also claiming the front sponsons shouldn't be touching the water, but they should. If they weren't meant to be in the water, the boat would look more like a tunnel hull...Now you go copying an pasteing quotes about me saying It wasnt a 4 point hydro !!!Again Mr Twisty You go find where you told me It was a 4 point hydro...An you Pal are again talking aboput a hole different boat mixing again what I say about a Miss Elam tunnel hull 3 point hydro!!!To the Ul1 flat transom hydro.As well as the vegas duece....Get what Both me an Scorpion own an Is talking about STRAIGHT!!!!! Before you come In here with your speal about again I dont know any thing!!!!!!!Before you open your PIE HOLE SPUTTERING THINGS THAT ARENT ABOUT THE SAME BOAT!!!!!!!!! LOL WHAT SHOT DID YOU JUST PM ME AN TELL ME I CANT RUN THE INTERNET TOO JUST WHAT 10 MINUTES AGO GOOD GOING CHAMP !!! YOUR OWN WORDS BASHING ME...... OK this Is the final one... You can all see Mr Twisty here knows all.An yes again I dont Know Jack good luck with his all so humble an 100% Info..He's all your's!!!!! |
| Thread Tools | |
| Discussion 4 point tic tocs harder with my 450 than with my 250 ?? | mattijs321 | Mini Helis | 7 | Sep 08, 2010 11:38 AM |
| For Sale Prather Spitfire 3.5 Outboard Hydro | Hydro Phil | Boats (FS/W) | 5 | Sep 07, 2010 06:18 AM |
| Discussion 250+mph RC 3 Point Outrigger Hydro | Amp Abuser | Racing Boats - Electric | 3 | May 10, 2010 06:56 PM |
