Old Oct 05, 2010, 03:46 PM
Phaeton is offline
Find More Posts by Phaeton
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Build Log
Winter project - Piper PA-18 Super Cub - Ed Westwood plans - Scratchbuild
Intended to log the build in my blog, but since an Ed Westwood based Cub thread is hard to find, I'll post the progress here. My friend dijko will be building one as well, perhaps a combined thread.
(Moved from scale planes to this forum)
Details:
- Hacker A20-22L
- APC E 9x4
- Jeti Spin 11 (can deal with 6 servo's)
- Graupner R700
- ThunderPower 3s1p 1350 mAh / PolyQuest 3s1p 1200 mAh
- Ailerons: 2x Hitec HS-45
- Rudder: HS-81
- Elevator: HS-81
- Flaps: 2x HS-55
- Navigation lights (led's)
- Trexler's 11G or similar shape and size, probably custom made
- Functional landing gear inspired by toyjunker
- LE slats (somehow...)
Wingspan will be about 46.5". Flying weight around 20 oz. I hope...
Yvo
Phaeton is offline Find More Posts by Phaeton
Old Oct 06, 2010, 08:56 AM
Phaeton is offline
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
First steps, many to go...
Four hours of work, a few to go
Weigth: 21 gram / 0.74 oz.
Yvo
Old Oct 06, 2010, 03:16 PM
Phaeton is offline
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Looks like an old schoolbus or something like that at this stage...
Tomorrow:
- Rear fuselage upper part
- Motormount attempt 2
- Leds in the rudder and wiring
- Anything else I got time for...
Weigth: 30 gram
(Edit: I see I made a -correctable- mistake somewhere in de frame. Fame for who notices first... )
Yvo
Old Oct 06, 2010, 03:59 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
One of the braces on the left side behind the cabin is reversed!
What did I win? Oh yeah, FAME which a lot better than obscurity.
-Stone1295
Stone1295 is offline Find More Posts by Stone1295
Old Oct 06, 2010, 04:42 PM
Phaeton is offline
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
You're right, that's the second "flaw". I noticed that one later. But it's not the one I had in mind...
But ok, congrats
I've planned a cabin door on the right side. I did fiddle the door contours in, but forgot to "remove" the horizontal bar in the middel of the fuselage. Should be open and a separate door...
Yvo
Old Oct 07, 2010, 03:21 AM
Phaeton is offline
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Done so far. Including led's.
Next week:
- Correct mistakes
- Sanding
- Motor mount
- Horizontal stabilo
Weigth: 44 gram
Yvo
Old Oct 07, 2010, 03:30 AM
ipjodan is online now
Find More Posts by ipjodan
Gloves are awkward
ipjodan's Avatar
Preston, UK
Joined Dec 2004
I love build threads, looking forward to the next installments
ipjodan is online now Find More Posts by ipjodan
Old Oct 09, 2010, 08:41 AM
Phaeton is offline
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Downside of scratchbuilding ;-)
Scratchbuilding is fun, but handcutting is a touch less precise compared to lasercutting
Wing root square? No. But everything is glued in already... Ships. Is fixed.
Balsa and drilling goes well, but not that tidy..
And a few more things.
Progress:
One large ply piece on each side of the fuselage to carry the weight of the plane. Wings will be held together with a cf rod and that one goes through the ply.
Wiring done from wing connector to rx under the belly.
Yvo
Old Oct 12, 2010, 12:26 PM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Looking good!!
metalfred is offline Find More Posts by metalfred
Old Oct 12, 2010, 12:47 PM
Phaeton is offline
I prefer Deans
Phaeton's Avatar
Netherlands
Joined May 2006
Horizontal stab is attached, no connection (possible) between the two feathers, two pushrods it will be.
Wiring is complete, so next step: Wings with ailerons, flaps and navigation lights. Perhaps slats already when I figured out how to make them...
Yvo
Old Oct 12, 2010, 12:54 PM
sleb is offline
Find More Posts by sleb
Quads & Planes, cant beat them
sleb's Avatar
Cleveland, Ohio, United States
Joined Nov 2003
Looking Great!
sleb is offline Find More Posts by sleb
Old Oct 17, 2010, 10:50 AM
dijko is offline
Find More Posts by dijko
dijko's Avatar
Nederland, Overijssel, Hengelo
Joined Sep 2009
And we are off...
Well it seems the first step is taken
I would have loved to make a scale carbon frame but hell, I'd like to finish this plane in this century
dijko is offline Find More Posts by dijko
Old Oct 17, 2010, 12:42 PM
dijko is offline
dijko's Avatar
Joined Sep 2009
And then there were two :)
once you got one done... the second is easy
Old Oct 18, 2010, 02:02 PM
dijko is offline
dijko's Avatar
Joined Sep 2009
We have a rudder :D
A while back I picked up some annegre woodstrips (Light mahogany) 0.7 mm. x 3 mm. I think it was billing boats stuff.
For the rudder I split them to 1.5 mm., laminated them into the propper curve and then framed it with 1.5 mm. square sticks.
Old Oct 28, 2010, 04:02 PM
dijko is offline
dijko's Avatar
Joined Sep 2009
Starting to look like a fuse ;)
Went through another length of carbon rod, thankfully found just a little more in my stash.
So the bottom is all in and square. The tail bit is reinforced where the tailwheel is going to be fitted by glueing some 0.4 mm. ply to the bottom, a piece of 2 mm. balsa on top of that and another layer of ply to make a sturdy sandwich.
From a picture of the actual full size super cub parts i drew out some dimensions of the bridge pieces for the top of the fuse on the work top and made the first four out of 2 mm. spruce.
Total weight without the bridge pieces was 9 grams.
Build Log Winter project - Piper PA-18 Super Cub - Ed Westwood plans Phaeton Scale Kit/Scratch Built 0 Oct 04, 2010 12:07 PM
For Sale Super Cub Piper PA-18 4ch 2.4Ghz Plane nitrotekltd Aircraft - Electric - Airplanes (FS/W) 0 Feb 19, 2010 09:45 PM
Discussion RCM PA-18 Super Cub-Ed Westwood kenbwa39 Waterplanes 1 Dec 21, 2009 07:46 AM
For Sale Graupner Piper PA-18 Super Cub -------- LOWERED TO $47 termite Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Dec 05, 2009 07:07 AM
