Old Oct 05, 2010, 03:07 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Build Log
Small Micro Quad only 11" across @175g(The Ripper)
I am getting ready to build a DIY Quad using a Gaui GU-344 gyro from a 330X quad. I am shooting for a light powerfull quad for acrobatic sport flying not an AP platform as you would figure by the size. Quad will be 11" across and it will be 10" motor 2 motor. Any veterans out there that want to "chime in" Please do. Here is a list of parts I will be using.
(4)Trex 250 booms
(4)Trex 250 Boom Mounts
(2)4" Square CF 1mm Thick
(4)Turnigy Plush 6a ESC's
(4)1811-2000 Brushless Motors 2000Kv
(4)6" 3 Bladed Props(2 rev & 2 reg)
Motors will be mounted using Zipties and hot glue to save weight.
I am figuring about 200g total weight without batt.
Batt will most likely be a Hyperion 45C 900mAh 3S @ 89g or a Outrage NRG 35C 1300mAh 3S @ 123g.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
Just got the frame built. It weighs 50g without Landing Gear. Still gotta put a big hole in the center for the wires. Gonna mount the motors next.
Site Sponsor
Old Oct 05, 2010, 03:08 PM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
Pics of the frame w/motors mounted with zipties and hot glue. Looks like it will come in at about 160g total without batt. I will have the exact weight once its done.
Site Sponsor
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
decided to just solder all the ESC/motors instead of using bullet connectors but that will prolly change. Was not sure if they would get here today so stayed up late soldering last night. Here are a few pics of the finished quad. I just drilled holes in the CF and ziptied the wires for now.
Site Sponsor
Old Oct 05, 2010, 03:09 PM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
Flight vids:
"The Ripper" Powerfull DIY RC Quad Copter (4 min 37 sec)
"The Ripper" Powerfull DIY RC Quad Copter video 2 (0 min 57 sec)
"The Ripper" Powerfull DIY RC Quad Copter Video 3 (1 min 13 sec)
Pics w/LED's installed.
Site Sponsor
Old Oct 05, 2010, 03:26 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
reserved 4
witespy is offline Find More Posts by witespy
Old Oct 06, 2010, 09:04 AM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
12" across means motor to motor?
i've made one some weeks ago with 12" motor 2 motor. very agil and perfect for acrobatic flying
setup:
motor: keda 20-50s 1088kv
esc: hobbywing 10A
props: epp 84.5 cw/ccw
battery: turnigy 3s1000 30C
kk mini quadrocopter - LPR/LPY550 (2 min 27 sec)
and some pics: http://warthox.bplaced.net/?p=112
warthox is offline Find More Posts by warthox
Old Oct 06, 2010, 09:14 AM
Bisso is offline
Find More Posts by Bisso
Bisso's Avatar
France
Joined Jun 2007
Currently building a tri with similar specs, but 8" motor to motor using similar material for the frame
One way to save weight is by using "horizontal stabilizer support" and screwing the motor into it
I had quite some luck on this one, the motor holes spacing is exactly the same as the support holes spacing
If it's not the case for you, use a narrow band of CF attached to the support and extending it on both sides, light and easy
The other advantage of this mount is that you can tilt the motor around the arm or move it for easy adjustement
Bisso is offline Find More Posts by Bisso
Old Oct 06, 2010, 09:59 AM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
setup:
esc: hobbywing 10A
http://www.vimeo.com/15106147
WOW thats some sweet flying and that quad ha mad power. It sounds pissed off. Hehe. Looks like I'll have to try a quad with those motors. Looksmlike they are on backorder at HK and Nitro Planes wants $10 more for each motor. Not sure if the real hacker motor is any better but they is like $38 each. Thanks for the vid and breakdown of equipment used.
Site Sponsor
Old Oct 06, 2010, 12:35 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
setup:
esc: hobbywing 10A
pretty cool, is it setup + or X?
+ seems more aerobatic, or is it the same?
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Oct 06, 2010, 01:20 PM
warthox is offline
Joined Aug 2009
its +
Old Oct 06, 2010, 03:34 PM
tonkajeep34 is offline
Find More Posts by tonkajeep34
NTX Helidillos
tonkajeep34's Avatar
USA, TX, McKinney
Joined Sep 2009
Looks cool, can't wait to see how it turns out
tonkajeep34 is offline Find More Posts by tonkajeep34
Old Oct 06, 2010, 03:48 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Tony,
The hot glue will melt with the motor temps. Ask me how I know this... Make a simple pinch block mount out of your favorite light material instead.
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old Oct 06, 2010, 04:01 PM
MarcAntonio is offline
Find More Posts by MarcAntonio
Speed Nut
Joined Jan 2010
Interesting, I have 4 of those same 10 gram motors coming and 4 6A plush escs.
My build will be very light. though with 5x3 gws 3bladed props, 6mm square carbon, and 8" across.
MarcAntonio is offline Find More Posts by MarcAntonio
Old Oct 07, 2010, 10:16 PM
Z06 Tony is offline
Z06 Tony's Avatar
Joined Sep 2008
Originally Posted by jesolins View Post
Tony,
Cheers,
Jim
I am gonna use a light small batt so my flight times will be short. I will check the motors after my 1st 3 mins of flight to see if it gets soft or melts. I am using zipties also. The hot glue is just to keep it in place. I would have had it done by now but waiting on bullet connectors for the motrs/ESC's. I was gonna direct solder them to save weight but decided its not gonna save alot of weight anyway. Thanks for the warning cus I would not have thought to check the glue for melting. I should have the bullets Fri so looking at getting it airborn this weekend. If it flies I will get someone to shoot a vid of some sport flight.
Site Sponsor
Discussion Kessel run in less than 12 parsecs...in your living room: Millennium Falcon copter Smokescreen38 Micro Ready-to-Fly 17 Jul 13, 2010 04:55 AM
For Sale NIB Ripper brushless motor 2928/09 for sale less than 1/2 price Ben-Rod Aircraft - Electric - Power Systems (FS/W) 0 Feb 18, 2009 01:03 PM
Link a small less than 15g motor (16,7 / 4,0mm) powerditto Electric Motor Design and Construction 2 Oct 10, 2006 08:42 AM
Discussion Less than 2 weeks for SMALL CANADA! Ken Park Electric Flight Events 1 Jul 17, 2006 08:20 AM
I need a small plane for backyard, less turning radius than J3-S e-sailpilot86 Parkflyers 18 Apr 12, 2003 12:32 AM
