Espritmodel.com Heli Air
Old Oct 05, 2010, 02:18 PM
USA, GA, Atlanta
Joined Sep 2008
Comparison between FMS 1.4m Spitfire or Durafly HK 1.4 Spitire
Has anyone done a comparison of the FMS Spitfire compared to the cheaper Hobby King version? I'm curious if someone has had experience with both could chime in.
Spec on FMS Spitfire:
Wing Span:1400mm(46.42 inches)
Length: 1180mm(46.4 inches) Anyone know the correct length I've get conflicting information on two diffrent website. One website says 1250mm and another says 1180mm not sure which is correct.
Weight:1600g(56.4 OZ)
Motor: 520KV out runner(included)
ESC: 50A with external BEC(included)
servo: 5 servos included 4 x 9g and 1 x 17g for elevator
Retract: servoless electric retract included
Spec on Durafly Spitfire
Length: 1190mm
WingSpan: 1420mm / 55.9in
Propeller: 11x7E
Flying Weight: 1650g
Motor: C3542 Brushless outrunner 1100kv
ESC: 40A (Not included)
Battery: 11.1v 2200~2600mAh 3S1P (Not included)
Servos: 6 Total (9g x 4 ailerons/rudder/elevator) (20g x 2 retract 180deg)
Battery compartment size: 150 x 55 x 32mm
1) FMS Spitfire larger nose so easier to mod and add stronger power plants.
2) Both made of strong good foam and eaisly repariable
3) Servo's on Durafly Spitfire are horrible
4) Landing gear on Durafly is very weak
5) Price of Durafly Spit is considerably cheaper. $139 compared to $219
6) Both are relatively the same size at 1.4m
7) Both have retracts mechanical on Durafly and Servoless on FMS
8) Durafly does not come with ESC 40 is recommended but most people are putting in a 60A
9) It seems most people are flying the FMS on 4S however 3S for the Durafly. This is wiered as the Durafly is actually a little bigger and weighs a little more???
Anyone else would like to add to the list? And or please make comments about what you enjoy about your particular model.
Fidy$Trainer is offline Find More Posts by Fidy$Trainer
Old Oct 05, 2010, 03:25 PM
Joined Mar 2008
comparo
I have the durafly spit. before even considering flying it, every servo (save the gear units) needed to be replaced. although the concealed aileron linkage is nice, it was problematic with very sloppy throws and the inability to go back to zero. I had to install wing-mounted servos and plug the bell crank holes.
although I'm not terribly anal about scale looks, the wing has zero dihedral and the paint was cartoonish. I needed to address both these issues.
while the stock motor will get it airborne it wasn't enough for my tastes. The integral motor mounting tube limits motor choices. I had to essentially fillet the nose and dig out the mount to install an Eflite Power 32. The supplied spinner is junk..needed to replace that as well.
In it's favor, the Durafly Spit is quite robust and it is inexpensive. But given the amount of work I had to do and the $$ put into it I can't call it a "bargin".
In hindsight, I would have purchased the FMS Spit.
ltbidrawn is offline Find More Posts by ltbidrawn
Old Jan 10, 2012, 07:11 PM
frankswd's Avatar
Salem, OR
Joined Sep 2002
Ok, but what about the kicks on the FMS version? Or is it PERFECT!?!
frankswd is offline Find More Posts by frankswd
Old Jan 10, 2012, 07:30 PM
Strongbow's Avatar
Jacksonville, Fl.
Joined Jan 2010
Moot point since the Hobby King/Durafly has been dis-continued.
Strongbow is offline Find More Posts by Strongbow
Old Jan 11, 2012, 02:25 AM
frankswd's Avatar
Salem, OR
Joined Sep 2002
i just bought one last monday @ HK! maybe different?
Old Jan 11, 2012, 06:36 AM
Strongbow's Avatar
Jacksonville, Fl.
Joined Jan 2010
Not different. When present stock is sold out there will be no more. HK is not making this bird anymore. So, for those of you who want one, get them while you can.
Question HobbyKing Durafly Cessna 182 1.4m ? blackcat657 Foamies (Kits) 917 Oct 31, 2012 10:07 PM
Discussion Durafly spitfire I crash ALOT ! Foamies (Kits) 39 Oct 07, 2012 11:52 AM
Discussion Durafly supermarine spitfire b-29er Electric Warbirds 1 Sep 29, 2010 08:18 PM
Sold 4M ASW-24 1/4 Scale RTF Aerotow Shane Spickler Aircraft - Sailplanes (FS/W) 0 Aug 10, 2010 07:57 PM
