Old Oct 05, 2010, 09:48 AM
BRISVEGAS BABY
Joined Mar 2010
Help with CE OSD
I am having a problem with my CE OSD. Every feature of the OSD is working perfectly except the current meter does not seem to be working. When i have my plane at full throttle it still reads 0.0A. It is reading the correct voltage which i have confirmed with a voltmeter but it is not reading amp current at all. Is there something that i might have to adjust or check, or is this a manufacturing fault.
Cheers
nathan089 is offline Find More Posts by nathan089
Old Oct 05, 2010, 10:34 AM
Netherlands
Joined Sep 2007
Is the input and output correct (maybe you switched sides)?
marco899 is offline Find More Posts by marco899
Old Oct 05, 2010, 10:41 AM
USA, NY, Yonkers
Joined Aug 2002
I have a similar problem with mine also. The Voltage is correct but the current will not go above 4 amps on mine even though my watt meter shows 14amps.
pc_pilot is offline Find More Posts by pc_pilot
Discussion Ce osd Neo360 Video Piloting (FPV/RPV) 1 Sep 21, 2010 12:54 PM
Help! Help with broken Eagle Tree OSD Pro StealthWorkx Video Piloting (FPV/RPV) 1 Dec 13, 2009 09:52 AM
Discussion Newb Alert! Help with Fatshark Teleporter cam and ET OSD Pro djinni69 Video Piloting (FPV/RPV) 1 Dec 07, 2009 11:28 AM
Discussion Need help with Eagle Tree OSD RTH! Ellis108 Video Piloting (FPV/RPV) 2 Nov 30, 2009 10:28 PM
Discussion Help with my ET OSD Pro & RangeVideo Tx harness Cralis Video Piloting (FPV/RPV) 122 Sep 11, 2009 10:35 AM
