Old Oct 03, 2010, 11:26 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
Help!
Keeping prop attached to 1.5mm motor shaft with 2s power
My micro sukhoi lately has been throwing props, I guess the rubber GWS prop adapters are getting worn out. Is there anything else light that will hold onto the shaft better? These are just push on and slip off really easily, especially after some use & changing props while testing. I can't use a metal collet because it's weight prohibitive.
Is there a glue I can use that will help it stick, but keep it serviceable in the future?
I've got an AP03 4000kV motor on 2s lipo, so it gets the prop going pretty quickly for that style adapter.
habitforming is offline Find More Posts by habitforming
Old Oct 04, 2010, 06:33 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Will one of these be too heavy?
MegaTesla is offline Find More Posts by MegaTesla
Old Oct 04, 2010, 08:10 AM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
unfortunately, I think so. The airplane is already heavier than I would like, so every little gram counts
Old Oct 04, 2010, 08:31 AM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
I will measure the weight when I get home. I also use dental rubber bands instead of heavy o-rings.
Old Oct 04, 2010, 08:57 AM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
Thanks much! As a reference, the prop adapter I have been using is 0.7g.
It's this one: http://www.aeromicro.com/Catalog/gws...1__1020450.htm
Old Oct 04, 2010, 04:05 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Either of these will work.
TODD
http://bsdmicrorc.com/index.php?productID=665
http://bsdmicrorc.com/index.php?productID=716
I R Irv is offline Find More Posts by I R Irv
Old Oct 04, 2010, 04:34 PM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
The one I showed weighs 0.48g if you use a dental rubber band with it.
Old Oct 04, 2010, 04:54 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
Originally Posted by I R Irv View Post
the plastic collet I like, but what keeps the GWJ prop saver attached to the motor shaft? is it just a press fit?
Old Oct 04, 2010, 04:57 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
wow! that's a lot lighter than I expected. any idea where I could order one (or at least who makes it)?
Old Oct 04, 2010, 07:05 PM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
On my stock Sukhoi the shaft is threaded. You might be able to do the same with yours. Or roughen up the shaft and glue the prop saver on.
Another light version is the one that Radical RC sells. It's a wood bushing for the GWS prop and you glue it on.
Petefoss is online now Find More Posts by Petefoss
Old Oct 04, 2010, 07:45 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
I've got the wood ones. Great for threaded shaft & 1s operation. Definitely doesn't work with smooth shaft & 2s operation. I glued the GWS spinner/adapter on for now. We'll see how that goes.
Old Oct 07, 2010, 06:08 PM
Dongo is offline
Find More Posts by Dongo
Dongo's Avatar
Here, There, Somewhere
Joined Jul 2004
Hello,
Did you ever find out where to get the one MegaTesla posted in post #2?
Daniel.
Dongo is offline Find More Posts by Dongo
Old Oct 07, 2010, 07:25 PM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
Originally Posted by Dongo View Post
Hello,
Daniel.
I'm not 100% sure, but I think they came with the AP03 (3g) motors that I ordered from HobbyKing. Either that or with the 5g motors that are included in some of the smaller airplane kits.
Old Oct 07, 2010, 07:39 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
BP Hobbies has them.
TODD
http://www.bphobbies.com/view.asp?id...02&pid=V797843
Old Oct 07, 2010, 10:18 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
Thanks everyone for your help. My idiot self never realized that one of the metal style prop savers came with my D1400-2000 motor. I was just digging around looking for something else and came across it. Where to source the dental rubber bands? I don't have braces and am at least 14 years away from having a kid that will need them, if I get to work on it immediately.
Discussion 1.5mm Shaft C-Clip (e-clips) VasMan Micro Ready-to-Fly 5 Aug 17, 2010 09:58 PM
Discussion Replacement for FF-030PK (1.5mm shaft, mount screws on 5mm radius) C05XL C05M AD-C5? coreyfro Electric Motor Design and Construction 0 Apr 27, 2010 02:32 AM
Help! How to secure prop to 1.5mm motor shaft? herk1 Power Systems 7 Apr 06, 2010 12:33 PM
Discussion 1mm shaft to 1.5mm prop adapter frankenfoamy Scratchbuilt Indoor and Micro Models 2 Jul 17, 2008 11:19 AM
Question Adaptor to fit 4x4 DD prop (4mm hole) to Medusa 12mm (1,5mm shaft)? AndrésMtnez Power Systems 6 Jul 27, 2006 04:25 PM
