This thread is privately moderated by bakchos, who may elect to delete unwanted replies.
Old Jan 25, 2012, 03:04 PM
caall99 is offline
Find More Posts by caall99
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
why is my RSSI working without anything then?
for the last week the voltage range of 1.5 to 3 volts have clearly indicated signal strength. did i just get lucky? after calibration, my osd shows near 0% RSSI when transmitter is in microwave and 100% when next to the receiver. If i stand in between the two is dips to somewhere to 70-80%.
caall99 is offline Find More Posts by caall99
Old Jan 25, 2012, 11:02 PM
Seppos is offline
Find More Posts by Seppos
Australia, QLD, Brisbane
Joined Nov 2011
Good question, not sure how it works ! - maybe it is lowpass filtered a lot before it gets to the OSD?, maybe it samples fast enough and does max/min holding?
Seppos is offline Find More Posts by Seppos
Old Jul 09, 2012, 09:38 AM
guy1a is online now
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
i connected my 9x rx to the cyclopes osd unit and i get 1.7 when in best signal and 0.8 when rc link tx is turned off.
i guess it correspondence to what others had come out with.
thank you for the info
guy1a is online now Find More Posts by guy1a
Old Aug 05, 2012, 12:12 PM
voodou is offline
Find More Posts by voodou
France
Joined Aug 2010
Why not adding a LM358 to create a Voltage Follower / Buffer? Don't forget that when you connect the RSSI you take power that can false the data.
voodou is offline Find More Posts by voodou
Old Feb 20, 2015, 06:37 PM
Tuxit09 is offline
Find More Posts by Tuxit09
Joined Nov 2012
I guess this is pretty much a lost cause getting RSSI from the cheap radio.
Out of curiosity I did probe with multimeter, same results as majority of post here.
The one that posted had it working must be one fortunate soul.
Tuxit09 is offline Find More Posts by Tuxit09
Old Mar 03, 2015, 08:30 AM
smar2 is offline
Find More Posts by smar2
Joined Mar 2015
I guess not all hope is lost. A negative peak-hold circuit would correct the pin1 waveform. I designed and simulated a very simple one: http://www.partsim.com/simulator/#28397
When the RSSI portion of the input signal is at 0.02V, the circuit outputs 2.6V. When the RSSI portion increases to 0.75V (almost no signal), the output drops to 1.6V. When the RSSI is around 0.85V (signal lost), the output further drops to 1.55V.
The output values are well within 0-3.3V, so can be used with 3.3 and 5V ADCs. I intend to make this circuit and test it on a FlySky R6B receiver (A7105 rf chip), and I'll post the results.
Here is the schematic, in case partsim.com website changes or will be unavailable in the future. The voltage source simulates the input voltage from pin 1 (RSSI). Output signal is measured across R3.
Description: The voltage source simulates the input voltage from pin 1 (RSSI). Output signal is measured across R3.
smar2 is offline Find More Posts by smar2
Old Apr 29, 2015, 09:35 PM
EddieFC02 is offline
Find More Posts by EddieFC02
Canada, BC, Richmond
Joined May 2014
Has anyone ever mixed throttle/elevator on the Turnigy 9x Transmitter?. I'd like to know how it is done right.
EddieFC02 is offline Find More Posts by EddieFC02
Old Jun 15, 2015, 04:54 PM
TheKaduu is online now
Find More Posts by TheKaduu
Joined Dec 2012
Circuit to get RSSI for this receiver
I recenlty needed the RSSI from this 8ch rx. If someone is still interested, I'll post the circuit design files here along with the bodged connections to the rx...
The circuit is negative peak detector plus a 2nd order Sallen-Key topology low pass filter. The output can easily be fed to the adc of a microcontroller running at 3.3V or 5V. Here are the output voltages:
Tx on and very close to the rx = ~100mV
Tx off = ~600 to 850mV
The range of 600 to 850mV occurred during my tests because my 2.4GHz wireless router is in the same room. It should be 850mv, theoretically...
Just respond here.. Thanks
Kadem
TheKaduu is online now Find More Posts by TheKaduu
Old Jun 15, 2015, 06:50 PM
Joined Dec 2012
Attached are the images for the modifications and the design files for the circuit.
Zip file is exactly the same file that I sent to ITead PCB board house. Instead of 1.6mm PCB, I got 1.0mm for added compactness even though the Rx case has space inside enough to accommodate 1.6mm PCB thickness.
EDIT 1: I did not include the schematic or BOM. Here they are, attached... Also, BOM says the diode is a normal one but I used Schottky (fast recovery one)... You may want to use that also.
EDIT 2: Schematic image was blurry...
Enjoy!
Kadem
Alert Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) tallflyer Electric Plane Talk 32 May 25, 2014 12:12 AM
New Product Turnigy 9X 2.4GHz 8Ch Receiver (V2) - US$ 8.99 CrashingDutchman Radios 30 Nov 01, 2013 04:39 PM
Discussion Adding 2.4gHz booster to Turnigy 9X V2? g00bd0g FPV Talk 9 Jan 22, 2012 05:02 AM
Discussion hobbyking Turnigy 9X 9Ch Transmitter (v2 Firmware) any experience? jitup Radios 1 Jun 09, 2010 06:54 PM
Discussion Turnigy 9X radio + Corona DSSS v2 ? sebbe Radios 11 Sep 21, 2009 04:25 PM
