This thread is privately moderated by bakchos, who may elect to delete unwanted replies.
Old Oct 01, 2010, 11:43 PM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
Gallery
Turnigy 9x V2 rx
turnigy 9x v2
bakchos is offline Find More Posts by bakchos
Old Jul 21, 2011, 12:21 PM
kha is offline
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Avoiding adding of the connector.
You can avoid adding the 2pin connector and just use a spare pin on the main connector == the 'S' pin of the "BATT" position.
In some board revisions it's connected to the "pairing" slot and one will need to cut the trace between those.
kha is offline Find More Posts by kha
Old Sep 17, 2011, 02:41 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Backhos did you have any luck with reading the rssi voltage?
msev is offline Find More Posts by msev
Old Sep 17, 2011, 07:36 AM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
i switched to chainlink LRS, but i think it's been done.
Old Sep 17, 2011, 07:50 AM
msev is offline
Joined Sep 2010
I saw your voltage measurements, did you make any more voltage measurements? Or is still that behaviour that you stated..
Old Sep 17, 2011, 07:57 AM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
it always behave like that, i know Rmilec LRS is compatible with those numbers.
Old Sep 17, 2011, 08:02 AM
msev is offline
Joined Sep 2010
Just to make sure....So for 100% reception 1.07V and for 0% voltage that is over 1,25V? In between would you say linear voltage drop?
Edit: I have the receiver from hobbyking, does it make any difference? and my 9x is the v2 from HK..
Old Sep 17, 2011, 08:03 AM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
i dont remember, this was a year ago i think and i dont have this rx anymore.
Old Sep 23, 2011, 02:16 PM
Toffe87 is offline
Find More Posts by Toffe87
Joined Jul 2011
Anyone got any luck? The RVOSD reads 1860-1870 as long as i got signal and drops to 400ish when i turn it off. Even when i walk out of range it is 1860-1870 until it looses and goes to 400ish
Toffe87 is offline Find More Posts by Toffe87
Old Jan 11, 2012, 07:07 PM
caall99 is offline
Find More Posts by caall99
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
does this mod work?
i apologize for resurrecting this thread, but would hate to go through the trouble of ruining my receiver just to try this out.
thanks
caall99 is offline Find More Posts by caall99
Old Jan 12, 2012, 07:42 AM
simplyfly is offline
Find More Posts by simplyfly
go ahead and try
Canada, ON, Maynooth
Joined Nov 2011
I am in the same boat... late to the party. I am going to attempt this mod for use with one of the hobbyking sub $50 OSD systems w/ GPS. I am in over my head, for sure. I dislike soldering, and am no good at it, so this is asking a lot of me... Hobbyking product suggestion. 9x Rx with RSSI output... $15
simplyfly is offline Find More Posts by simplyfly
Old Jan 12, 2012, 07:56 AM
caall99 is offline
Joined Jun 2011
instead of waiting for a response i went ahead and did the mod.
my recommendations are as follows:
1. find the smallest tip soldering iron that you can
2. spend the absolute majority of your time prepping. ensure all contacts are clean and glue the thin wire to the board prior to soldering. this is your strain relief, and will also position the wire for you.
3. strip only the bare minimum that you need, to make a solid contact to the left side of the resistor.
4. touch the solder to the iron tip before touching the joint between wire and resistor.
5. keep your iron on low heat!!!
6. the actual soldering should take no longer than 4-5 seconds.
7. done!
It appears to be working. good connection between rx and tx = about 1.05v while a poor connection is closer to 1.25v. When transmitter is turned off, the line voltage drops to .8v. this is not optimal... but no big deal. You are only interested in the values while the transmitter is on anyways...
Old Jan 12, 2012, 12:01 PM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
Hey guys, thans for your interest,
Like i said i dont have this system anymore, i use Long Range System Chainlink, but the result should be the same i was getting.
And btw, this is not a thread, its my blog lol
Hope you guys get it working
Old Jan 12, 2012, 04:27 PM
caall99 is offline
Joined Jun 2011
bakchos, sorry to have hijacked your blog. So, I did a test with the RSSI output from the Turnigy 9X into my DragonOSD. I copied your mod method, every step of the way. Unfortunately, it appears my RSSI signal is fluctuating very wildly when i look at it on my OSD video. between 60% and 100% when rx and tx are right next to each other and not moving. I already calibrated it, so thats not the problem. Is the RSSI out from the Rx not buffered? Is that why my readings are so unstable?
Old Jan 12, 2012, 04:32 PM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
i am pretty sure you need a cap and a resistor to create a buffer, look at the poor man osd thread "remzibi osd" there is information about buffer for rssi.
Alert Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) tallflyer Electric Plane Talk 32 May 24, 2014 11:12 PM
New Product Turnigy 9X 2.4GHz 8Ch Receiver (V2) - US$ 8.99 CrashingDutchman Radios 30 Nov 01, 2013 03:39 PM
Discussion Adding 2.4gHz booster to Turnigy 9X V2? g00bd0g FPV Talk 9 Jan 22, 2012 04:02 AM
Discussion hobbyking Turnigy 9X 9Ch Transmitter (v2 Firmware) any experience? jitup Radios 1 Jun 09, 2010 05:54 PM
Discussion Turnigy 9X radio + Corona DSSS v2 ? sebbe Radios 11 Sep 21, 2009 03:25 PM
