Old Oct 01, 2010, 10:28 PM
ny_hawk is offline
Find More Posts by ny_hawk
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
The definitive paint for EPO foam
Okay well, I have looked and searched and have yet to find the final word on what the best paint is for EPO foam...
I am testing and have tested several kinds of paints and so far none adhere the way I want them to..
So out of all the brilliant minds and vast experience set here has anyone found a paint that will actually BOND to EPO foam. And by EPO foam I DO NOT mean some other kind of foam... The word foam is often tossed around these fora quite a bit and it's silly because different foams do not have the same properties at all..
So far I have tried:
"Epoxy" paint
Plastic paint
Enamel paint including Testors $500 per gallon paint.
Several Rustoleum primers and paints
Wondering about polyurethane based paints... So far doesn't seem like there are a lot of this type out there..
So has anyone found a paint that actually bonds to EPO foam? I refuse to believe that nothing will properly bond to this surprisingly nonreactive type of foam.
Jim
ny_hawk is offline Find More Posts by ny_hawk
Old Oct 02, 2010, 01:25 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
what is EPO foam. I know EPS and EPP but EPO?
Anyway, any foam needs a filler primer layer. Its normal to start with Spackle filler and one or more coats of clear water based acrylic varnish sanded down, or glass and epoxy.
Over thatt we normally spray Humbrol/Tamiya style oil based enamels.
Old Oct 02, 2010, 01:34 AM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
EPO stands for Expanded PolyOlefin... It is a very durable foam with a nice natural finish, normally has large beads, is shiny in appearance and is very flexible, not brittle.. It is also very non-reactive.. It handles normal CA and I have not found any paint or solvent that eats it up, though something may..
Glassing is fine but there must be a best paint out there for EPO (the manufacturers often paint these models).. Polyurethane glue is used to bond it so perhaps a paint based on that or a primer.. Also wondering about polycarbonate paints..
Jim
Old Oct 02, 2010, 02:45 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Nothing sticks to olefins at all.
One of its main features.
Teflon apart, its the nearest to non stick there is..think polythene.
You might find a solvent that attacks it enough to get some form of key.
Try some on scrap and see.
If CA sticks it, which surprises me, why not paint Thin CA over the airframe?
Hmm. Dome olefins seem to take cellulose and alcohol based inks..
have you tried normal car solvent primer...it might works.
Once you have a primer down, all else becomes relatively trivial.y
Id try clear dope with cellulose thinners, ad cellulose car spray primers first.
Also some car fenders are made of olefin type plastic, and you may be able to get proprietary etch primers made for those that will attack it enough to get a key...
Old Oct 03, 2010, 06:20 AM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
If I can find some solvent that attacks it then how to use this as a key?
I had thought of this but it seemed like cleaning the bathroom with a toothbrush... lol Also not sure how CA would sand... Spray on CA would be cool.. Never seen it though...
What kind of brush would work with CA?
have you tried normal car solvent primer...it might work.
Hmm, no haven't.. Will look into it..
I'm trying a polyurethane base coat now.. So far no great results..
Jim
Old Oct 03, 2010, 02:02 PM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
Tom Hunt uses house paint from Home Depot mixed at the store to match his warbird color schemes.
http://www.rcgroups.com/forums/showt...t#post15880398
The secret to getting the paint to stick seems to be washing the plane (foam) down with alcohol before painting to remove the mold release agent. Tom's P-51 has been around for months now and shows no real wear on the paint.
Ron Williams is offline Find More Posts by Ron Williams
Old Oct 06, 2010, 09:50 AM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Krylon fusion has seemed to work for me on EPO foam. Just tested it out, and it looks great. On EPS foam, it will eat it alive if applied heavily, and sometimes works in small amounts. On EPS, I'll use Krylon Short Cuts spray paint.
Clean the foam lightly with rubbing alcohol and let it dry, then spray the Krylon Fusion over it, and after it dries, use something like Minwax polycrylic clearcoat to seal the paint.
T-CAT is offline Find More Posts by T-CAT
Old Oct 10, 2010, 04:16 AM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Okay well so far I have come up with a process that looks like it may give me the results I want..
What I was really going for that perhaps I did not make clear here is to put a real finish on the foam but without glassing it... I wanted a finish that would not look like foam and that would be ding resistant...(the constant new dings make me nuts)
So far what I did was this..
1. Clean surface with alcohol..
2. Apply a light coat of CA over the area..
3. Sand above lightly 220 grit..
4. Apply a coat of primer..
5. Sand above 120 grit..
6. Apply a coat of finishing epoxy..
7. Sand above.. 120 grit
8. Apply a coat of primer..
7. Sand above.. down to 400 grit
9. Paint as desired..
10. Apply a clear coat..
I am up to 8 now..weight gain seems minimal..
The wing looked amazing after the epoxy was applied and appears to be much more ding resistant.. I had tried epoxy before but it didn't cover correctly, with the CA and primer this seems to help it cover evenly and it also seems to self level to a large degree..
In the end the finish should look like glass without the glass and be much more ding resistant.
I may try using different combinations of the above.. Such as CA with no epoxy as a base, or two coats of epoxy... In the future my technique for applying the CA will improve and the process will keep evolving..
Jim
Old Oct 10, 2010, 11:58 AM
WillyAA is offline
Find More Posts by WillyAA
USA, CA, San Diego
Joined Jan 2007
How do you spray CA?
A thought just crossed my mind. I used to work with leather a lot and used dye to color it. I have never tried dye on foam but wonder how it might work. Anyone ever tried it.
WillyAA is offline Find More Posts by WillyAA
Old Oct 10, 2010, 02:50 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Jim, I came across this while looking around the Klass Kote site recently:
http://www.wowplanes.com/product_inf...roducts_id=130
Liquid Sheeting, it's called. I had never heard of it before, have not used it, and have no idea if it's any good.
FWIW.
Harry D is offline Find More Posts by Harry D
Old Oct 11, 2010, 11:21 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
I haven't got that down yet.. This first time out I simply wiped it on with a cloth, well several cloths..
Aside from spraying it on, the cloth kept binding with it but I realized that I could use a foam brush with foam safe CA to get better coverage..
Old Oct 11, 2010, 11:27 PM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
FWIW.
Hey that's interesting.. Similar idea to what I am doing.. Wonder if it definitely works with EPO and how strong of a 'shell' it has...
Jim
Old Oct 13, 2010, 02:37 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Why would you layer epoxy and primer?
The primer doesn't bond that well to epoxy and the layers can peel off.
Epoxy with lightweight cloth for strength. Surfacing primer to fill the grain. Paint.
Pinecone is offline Find More Posts by Pinecone
Old Oct 14, 2010, 04:06 AM
ny_hawk is offline
ny_hawk's Avatar
New Rochelle, NY
Joined Jun 2008
Not clear really.. You seem to suggest using primer over the epoxy? I used primer over the epoxy for the same reasons, always have.
I haven't had a problem with primer sticking to the epoxy at all.
Old Oct 14, 2010, 02:05 PM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
I am talking about doing the epoxy - primer - epoxy - primer - epoxy layering that was mentioned.
A good way to develop delaminations.
Epoxy then primer then paint, tried and true and well proven to work
Discussion EPO Foam, Elapor Foam and "Z" Foam drypipe Foamies (Scratchbuilt) 7 Feb 05, 2010 05:04 PM
Discussion EPO Foam, Elapor Foam and "Z" Foam drypipe Electric Warbirds 1 Feb 04, 2010 10:25 PM
Help! How to paint foam so the paint won't peel off? Rob02Aggie Parkflyers 21 Oct 03, 2009 07:16 PM
Discussion EPO foam, what can i paint on it? Edwong Foamies (Scratchbuilt) 0 Jul 22, 2009 12:59 PM
Discussion Epo Safe Spray Paint For Edf greatplanes Foamy EDFs 4 Jun 16, 2009 04:57 PM
