Old Jul 07, 2003, 09:21 AM
ELarsen is offline
Find More Posts by ELarsen
Joined Jul 2003
Idea
Scale Robbe Gnat.. Ducted fan->Slope soarer convex
The project is actually headed mainly, by a good friend, and owner of the original kit. To lay out the history of the model briefly, the kit was bought of the shelf by Anthony on a visit to the UK. The aircraft never really flew, being fraught with reception problems, and a thrust to weight ratio headache. After a good stint of hanger time , the fairly bedraggled fuselage was hauled out and restored under the new guise of being a scale slope soarer. Solid balsa elevons were fitted, with a Red Arrows livery scheme covering. The aircraft is almost ready for her maiden flight in the new attire. This will basicly take the form of a series of hand launches, at a spot that has a light gradient, to extend the flight time in order to get the bird trimmed/setup.
The big question at the moment, is where to put the Center of Gravity. It obviously Cant be in the same position as before, when she was running the ducted fan, as the lack thereof, will mean all of the force couples go out the window. Her highly tapered scale wings, and fairly uncambered aerofoil section, mean that eyeballing it is a little tricky.
Is there anyone who could offer some assist on the matter, and/or give any hints on the conversion itself, before we go throwing the little airey off a mountain.
Erik Larsen
Cape Town, ZA
ELarsen is offline Find More Posts by ELarsen
Old Jul 08, 2003, 03:03 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Hi Erik
Welcome to RC Groups
The C of G of your Gnat should be in the same place regardless of the power plant. So if you know what it was at before then use that as a starting point. You may find that you need to move it slightly to get the desired flying characteristics.
If you think about it the model doesn't become uncontrollable once the power is cut and she becomes a glider. Centre of Gravity is a moveable feast within a small window of what is stable for a particular airframe, you can move it backwards and forward to gain the desired control response and degree of stability but the power source is largely irrelevant.
Good luck with the maiden.
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Jul 08, 2003, 07:09 AM
ELarsen is offline
Joined Jul 2003
Thank you for the intel. I do now realise that I have posted the thread under the wrong division.
We're actually going to throw the little bird around the field today, so the timely response is much appreciated..
Erik
For Sale ROBBE GNAT D/FAN (UK add) kartman24 Aircraft - Electric - Airplanes (FS/W) 0 Jan 31, 2006 08:11 AM
NIB Krick Folland Gnat Ducted Fan Jet Kevlar47 Aircraft - Electric - Airplanes (FS/W) 1 Aug 03, 2003 09:37 PM
Question Robbe Gnat.. Scale Ducted-fan to Slope Soarer convex ELarsen Scale Sailplanes 1 Jul 09, 2003 10:51 AM
Robbe Gnat / Kyosho Fan / Mega 16/15/3 - Servo's?? NightSwan Electric Ducted Fan Jet Talk 9 Mar 28, 2003 12:04 PM
New Video of FO 141 Gnat, Ducted Fan Patrick Plawner Electric Ducted Fan Jet Talk 9 May 14, 2002 03:09 AM
