Old Oct 01, 2010, 02:22 PM
Jetskeeter is offline
Find More Posts by Jetskeeter
registered user
Jetskeeter's Avatar
Joined Aug 2007
making a 3.7v lipo
Is it possible to disassemble a 7.4 2s lipo and end up with 2 3.7 1s lipos? I have this 3 channel heli that uses a 3.7v lipo that won't take a charge anymore and was wondering if I could make two 3.7v from a 7.4v.
Jetskeeter is offline Find More Posts by Jetskeeter
Old Oct 01, 2010, 03:18 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Yes
rampman is online now Find More Posts by rampman
Old Oct 01, 2010, 03:28 PM
Capt. Crunch is offline
Find More Posts by Capt. Crunch
It's all fun till Crunch!
Capt. Crunch's Avatar
InSane Diego
Joined Jan 2002
Very, very carefully!
Capt. Crunch is offline Find More Posts by Capt. Crunch
Old Oct 01, 2010, 06:37 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Yes you can BUT some will say that if you had to ask you should not do it. If you're going to try anyways make sure you're doing it with a not fully charge pack to minimize the sparks and shorts if they should happen.
freechip is offline Find More Posts by freechip
Old Oct 01, 2010, 06:43 PM
Chophop is online now
Find More Posts by Chophop
Glad I'm not a Boll Weevil
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
The professionally made pack has shown me to be expertly made to prevent the main power leads from breaking off and/or shorting at the battery tabs under the tape. You need to study that, I don't think it's a big short problem on a 1S but the likely problem IS the breakage at the delicate aluminum battery tab.
Chophop is online now Find More Posts by Chophop
Old Oct 02, 2010, 08:34 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Part of the problem in doing the conversion is that the voltage output tabs on LiPO cells may or may not require the use of special fluxes and solders to connect the cells to PCB's or wires.
Here is a page full of LiPO cells and there are some accessory PCBs there too. And there are also some cells with the output leads already attached.
http://www.all-battery.com/li-polyersinglecells.aspx
What is the size of the battery on your helo as far as capacity and what is the discharge rate in use? Those are important considerations that play into selecting a battery.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 02, 2010, 12:03 PM
volto is offline
Find More Posts by volto
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
I asked a similar question about converting an unneeded 6S into two 3S batteries, and took the advice I was given to sell it and buy what I needed. Especially since soldering aluminum isn't on my resume.
volto is offline Find More Posts by volto
Old Oct 02, 2010, 02:38 PM
registered user
Jetskeeter's Avatar
Joined Aug 2007
thanks for the feedback. I have some soldering skill and will give it a shot.I have an extra 7.4 that I can use. I'll be sure to wear protective eye gear. the lipo is a 3.7v 1s 1000mah. the heli is a syma soo6g. these lipos seem to be scarce as hens teeth after market.
Old Oct 02, 2010, 04:03 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Here is a source for the flux and solder your might need to use. It all comes down to what the material is in the tabs that come out of the pack.
http://www.cheapbatterypacks.com/ind...D6B&sid=331296
Jack
Old Oct 02, 2010, 09:03 PM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
If your taking a pack apart, all the tabs will have been tinned and will take ordinary solder with no problems. All the packs I have made up from scratch have had one side of the tabs nickel plated and will take lead/tin solder fine. If you do play with new batts., try tinning both sides of a tab. I'm sure you'll find the nickel plated side will tin fine and the aluminum side won't, so try both sides.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
For Sale 1S 3.7V LiPO Portable Charger Torch8 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 08, 2010 10:21 PM
For Sale Eflite Blade 1S 3.7V LiPo Charger Torch8 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 27, 2010 10:09 PM
For Sale 3x Parkzone 1S 3.7V LiPo Chargers burga3 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 04, 2010 08:18 AM
For Sale 3x Parkzone 1S 3.7V LiPo Chargers burga3 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 01, 2010 06:22 PM
Rant 3.7V lipo & 3.7V Li-ion =7.4 V Hybrid Cell:P lostrider Micro Helis 2 Mar 19, 2005 03:10 PM
