Old Sep 30, 2010, 07:00 PM
rcdude123 is offline
Find More Posts by rcdude123
United States, CA, San Jose
Joined Dec 2009
mamba max vs mamba max pro
what is the difference, is one censored and the other not? the pro can take 6s but the max can only take 3s. is censored for more experienced drivers?
rcdude123 is offline Find More Posts by rcdude123
Old Oct 01, 2010, 05:58 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Sensored motors have of course sensors in them that tell the ESC where or how the motor shaft or armature is position and the esc can right away start the motor without cogging.
Its not a matter of one is good for the average user and the other is for more advance users.
Unless you're racing you really dont need to get the sensored motor cause then you need a sensored ESC if you want to use that feature and the sensor in the motor is a component that can fail and when it does the motor wont work.
freechip is offline Find More Posts by freechip
Old Oct 01, 2010, 08:19 AM
Redfisher is offline
Find More Posts by Redfisher
Nice day for RC'ing
Redfisher's Avatar
Palmerston On. Canada
Joined Jul 2010
I like the options on the pro, for example the cheat mode which runs censored at start up then turns it off for more power is cool.
Redfisher is offline Find More Posts by Redfisher
Old Oct 01, 2010, 06:18 PM
Joined Dec 2009
so it dosn't take any more ability to use a sensored motor, it just gives you better start ups. do both syestems come with sensored motors?
Old Oct 03, 2010, 06:57 AM
AL3xGR is offline
Find More Posts by AL3xGR
Greece
Joined Nov 2009
Pro is much better.It can drive even 1/8 scale motors.It run both sensored and sensorless mode.
AL3xGR is offline Find More Posts by AL3xGR
Old Oct 08, 2010, 11:48 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Got off the phone with Castle tech support. Mamba Max is up to 3S. Will not do sensored control and about 80A max.
feathermerchant is offline Find More Posts by feathermerchant
Old Oct 08, 2010, 04:21 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
You can use a separate BEC after disabling the onboard MM BEC and it will run 4S. You may get lucky and have it arm on 5S, but thats iffy with the newer ones. My oldest MM (bought when they had just come out) will run 5S using a separate BEC.
I'm running my 2WD Slash with a MM right now, 3600 Medusa running 3S.
Duster_360 is offline Find More Posts by Duster_360
Old Oct 09, 2010, 09:30 AM
snellemin is offline
Find More Posts by snellemin
United States, TX, Spring
Joined Jul 2008
I use to run my MM on 6s A123, with the use of a dimension engineering park bec. The trick was to disable the voltage cutoff all together.
snellemin is offline Find More Posts by snellemin
Old Oct 10, 2010, 12:50 AM
Joined Dec 2009
do the mamba max and mamba max pro combos come with the same motors? and are the motors sensored or sensorless?
Old Oct 10, 2010, 06:39 AM
Nice day for RC'ing
Redfisher's Avatar
Joined Jul 2010
The castle motors are sensorless.
Old Oct 10, 2010, 02:22 PM
Joined Dec 2009
thanks
Gallery Mini Revo vs. mamba max pro vs. tekin redline 10.5 sensored EvgenUA Electric Power Cars 13 Aug 18, 2010 04:05 AM
Sold Mamba Max Mamba Max ESC and CMs-4600 Motor (540 size, 4600Kv) - $125 Stevep36 Cars - Accessories (FS/W) 1 May 07, 2010 12:25 PM
Discussion Mamba Max Pro with Brushed motor cbr6fs Castle Creations 5 Nov 27, 2009 08:13 PM
Discussion Mamba Max Pro Q? dodgeboy93 Castle Creations 8 Nov 12, 2009 08:03 AM
Discussion mamba max pro on a 3s or 4s lipo 5th scale dragbikebam Motorcycles 9 Oct 27, 2009 09:04 PM
