Old May 26, 2011, 10:38 AM
protocol is offline
Find More Posts by protocol
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
850mah/20c, JST leads? why?
Hi All,
I have 1x 800mah/20c (2 more in mail), but for some reason it came with a JST lead (I should have read the description closer, d'ohh). I think my 50mm 20A EDF will kill those leads.
Who is this battery for? If I replace the connector with an XT60 or EC3, will I be ok? I don't want to replace the battery leads, unless there's a safe way to do it.
thanks
protocol is offline Find More Posts by protocol
Old May 26, 2011, 03:43 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Really? I thought everyone knows that battery is for ME.
I use the JST's on all of my >1000mah packs but that is my way.
Chose a connector and stay with it as it is your standard. When you buy a pack expect to change the connector. That is a given now-a-days.
If you can't solder talk to you LHS or FB and have them do it for you.
Rick
rampman is offline Find More Posts by rampman
Old May 27, 2011, 04:03 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Originally Posted by protocol View Post
Hi All,
thanks
It's not just the connector that's the problem. Unless they've changed, they also have a very small gauge wire. I took Charles suggestion and spliced in some heavier 16g wire about an inch from the pack. It's probably just convenient For GensAce to use the JST pigtails, but it doesn't make sense on a battery this size. I wasn't happy when I got mine.
Azarr
Azarr is offline Find More Posts by Azarr
Old Aug 17, 2012, 02:54 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I don't get this for a couple of reasons. First, my readings are higher (though I have something that might explain that), and second, what is a 3016b? Is that a typo or an old charger?
Originally Posted by Melnic View Post
Hobbyparts has some new batteries called Gens Ace. (click Gens Ace on right of main page)
Looks like they are going to surplant the Blue Lipos maybe?
NOTE:
On my 25C pack, On the back, it says not to charge above 5C.
It also says Store Long Term at 3.4V per cell. I believe this to be WRONG! should be 3.85V per cell.
Ace Power Website
Actual Weights and measurements taken buy users (IR is when new and broken in):
6S
6s 3300mAh 25C (500 heli) : 544g 138mm x 45mm x 41mm This requires a 2010 Align 500 or a Battery Tray MOD to fit.
Average Internal resistance per cell = 2-3 milliohms (using iCharger 3016B)
6S 5300mAh 30C : 759g 139mm x 64mm x 43mm
Average internal resistance per cell = 1-2 millihoms
4S
4S 3300mAh 25C (warbirds) : 380g
Average internal resistance per cell = 2-3 milliohms (using iCharger 3016B)
Came with red cased HXT 4mm Bullet/Bananna jacks
3S
3S 2200mAh 25C : 192g 110mm x 25mm x 33mm.
Average Internal resistance per cell = 3-4 milliohms (using iCharger 3016B)
3S 1300mAh 25C : ??g 72mmx25mmx35mm
Average internal resistance per cell = 5 milliohms (using iCharger 3016B)
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Aug 17, 2012, 10:24 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
typo, should be 3010B charger.
Btw, the temperature you test a battery at makes a huge difference and back then, I did not log that. Lower tempatures = higher IR.
the standard temp you measure at SHOULD be about 72F but I don't think I measured at that temp back then.
Melnic is offline Find More Posts by Melnic
Old Aug 18, 2012, 01:10 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Ah, thanks. What about the number of cycles on a pack. I probably have 20-40 cycles on my packs, and was getting 12-14 mOhms. (4S 2200 mah).
Old Aug 18, 2012, 07:56 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
After the break in period, the IR only gets worse, not better from my experiance.
How much worse depends on the pack quality and how you have cared for it.
Mini-Review New line of lipos - Gens Ace justerik Batteries and Chargers 5 Nov 10, 2010 08:07 AM
New Product HobbyPartz Gens Ace Lipos Mikey 68 Batteries and Chargers 4 Oct 02, 2010 02:16 PM
Discussion Gens ace 5000mah 40C 2S Lipo battery ericyao22 Car Talk 2 Aug 14, 2010 03:00 AM
Discussion Test report of Gens ace battery from Jocke ericyao22 Batteries and Chargers 17 Jun 29, 2010 11:03 AM
