Old Dec 13, 2010, 07:24 PM
hobbypartz is offline
Find More Posts by hobbypartz
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
Glad u guys love the Gens Ace. This battery is sure to dominate the market because of the price and the quality that comes with it.
Here's the test result using the following batteries:
Sky LiPo 2200 3S 25C
Blue LiPo 2200 3S 30C
Gens Ace 2200 3S 25C
Thunder Power 2250 3S 45C
hobbypartz is offline Find More Posts by hobbypartz
Old Dec 13, 2010, 07:31 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
When are you getting another shipment?
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Dec 13, 2010, 07:57 PM
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
These Gens Ace just came in last week!
Gens ace 450mah 2S1P 7.4V 25C Lipo battery pack
Gens ace 800mah 2S1P 7.4V 20C Lipo battery pack
Gens ace 800mah 3S1P 11.1V 20C Lipo battery pack
Gens ace 1300mah 2S1P 7.4V 25C Lipo battery pack
Gens ace 1300mah 3S1P 11.1V 25C Lipo battery pack
Gens ace 1550mah 2S1P 7.4V 25C Lipo battery pack
Gens ace 1550mah 3S1P 11.1V 25C Lipo battery pack
Gens ace 1550mah 4S1P 14.8V 25C Lipo battery pack
Gens ace 2200mah 2S1P 7.4V 25C Lipo battery pack
Gens ace 2200mah 3S1P 11.1V 25C Lipo battery pack
Gens ace 2200mah 4S1P 14.8V 25C Lipo battery pack
Gens ace 2200mah 6S1P 22.2V 25C Lipo battery pack
Gens ace 2600mah 3S1P 11.1V 25C Lipo battery pack
Gens ace 3300mah 2S1P 7.4V 25C Lipo battery pack
Gens ace 3300mah 3S1P 11.1V 25C Lipo battery pack
Here's more due to arrive early next week.
Gens ace 1000mah 2S1P 7.4V 25C Lipo battery pack
Gens ace 1000mah 3S1P 11.1V 25C Lipo battery pack
Gens ace 2500mah 3S1P 11.1V 25C Lipo battery pack
Gens ace 2500mah 3S1P 14.8V 25C Lipo battery pack
Gens ace 3300mah 5S1P 18.5V 25C Lipo battery pack
Gens ace 3300mah 6S1P 22.2V 25C Lipo battery pack
Gens ace 6000mah 2S3P 7.4V 25C saddle pack Lipo battery
Gens ace 3300mah 4S1P 14.8V 25C Lipo battery pack
Gens ace 450mah 3S1P 11.1V 25C Lipo battery pack
Gens ace 3800mah 4S1P 14.8V 25C Lipo battery pack
Gens ace 3800mah 6S1P 22.2V 25C Lipo battery pack
Gens ace 4000mah 5S1P 18.5V 25C Lipo battery pack
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
Here's a cool review
Gens Ace Battery Review (13 min 23 sec)
Old Dec 13, 2010, 08:02 PM
Joined Jan 2004
Yup. Saw those and that's great but I'm waiting on the small 3s 450 packs. I have to get a few bigger packs too but I have to wait for the plane to arrive so I know how big I can go before I order.
Old Dec 14, 2010, 07:58 AM
Rumple is offline
Find More Posts by Rumple
Ignint McNugget
Rumple's Avatar
behind Jaggi lines
Joined Jan 2004
Thanks for sharing the data.
The superiority of the Gens Ace over the Blue Lipo is striking in your graphs. And yet the Blue Lipo is marketed as 30C whereas the Gens Ace is 25C.
Would be nice to see discharge comparisons at higher currents (40A is less than 20C for these packs).
Rumple is offline Find More Posts by Rumple
Old Dec 14, 2010, 09:04 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
The voltage drop should be pretty proportional to the current because the Internal resistance should be similar unless the temperature changes. I think that's where it comes into play. I know a pack may be labeled 30C but if you really pulled 66A, the pack would heat up really quick and the IR may change as well making things worse (or better, depending on the ambient temp and airflow). If you are pulling 66A from a 3S 2200, just look at how long it will last before it's depleted. 10C average current pull even at 100% depletion will last only 6 minutes (rough estimating here). 20C would last you 3minutes and so on.
40A for a 3S 2200 I think is a pretty good measuring point for a full throttle value.
Melnic is offline Find More Posts by Melnic
Old Dec 15, 2010, 09:01 PM
Rumple is offline
Ignint McNugget
Rumple's Avatar
behind Jaggi lines
Joined Jan 2004
Yesterday I received 6 Gens Ace packs: 3x 3s 1300 25C, 2x 3s 1550 25C, and 1x 3s 800 20C. The small pack came with a JST-type connector, and the others had the HXT 3.5mm protected bullets. Here are the stats for the as-received packs:
Old Mar 30, 2011, 09:32 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I got in box of batteries I recently purchased.
4 more 3S 25C 2200mAh
and 2 4S 3300mAh
After the first charge, the 4S 3300mAh packs are 2-3 milliohms per cell.
The 3S 2200mAh packs are 3-4milliohms per cell
I"ve also updated post #1
Incidently, I have about 50 cycles on one of my original 3S 2200mAh 25C packs and I"ve been abusing it for the last 15-20 Cell Internal resistance is now 4-5milliohms per cell. WAY better than how my Nanotech was doing and WAy better than my Blue Lipos do. I"ve been taking the Gens Ace way down to like 95% discharge training some people on my 450 Helicopter in a buddy box.
Both batteries came with the HXT 4mm Red Cased Bullet connectors installed.
Old Mar 30, 2011, 10:20 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
I cut them off to add Deans but are they any good?
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Mar 30, 2011, 10:36 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I use those HXts on my 4S planes and my 6S 550mm+ helis
Deans on others
Old May 15, 2011, 03:25 AM
hobbypartz's Avatar
Los Angeles
Joined Mar 2009
Gens Ace Magic Trick with Traxxas E-Revo (0 min 19 sec)
Old May 15, 2011, 03:37 AM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
and 2 4S 3300mAh
Nice to see they have some good 4mm gold bullets installed, much better than the Deans if you as me.
Jocke is offline Find More Posts by Jocke
Old May 16, 2011, 04:45 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
When running constant current of 50 or 60 amps these are getting hotter than Dean's connectors if that means anything to you. I'm pretty comfortable lumping the 30 amp powerpoles, Dean's, these red bananas , Traxxas , and some others into a "50 amp" catagory.
gulio is offline Find More Posts by gulio
Old May 16, 2011, 07:04 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I got in some 1300mAh 25C 3S packs for my smaller foamies. 2 and 6 milliohms per cell. That's not bad at all. I'll report after I have some more flights.
Mini-Review New line of lipos - Gens Ace justerik Batteries and Chargers 5 Nov 10, 2010 08:07 AM
New Product HobbyPartz Gens Ace Lipos Mikey 68 Batteries and Chargers 4 Oct 02, 2010 02:16 PM
Discussion Gens ace 5000mah 40C 2S Lipo battery ericyao22 Car Talk 2 Aug 14, 2010 03:00 AM
Discussion Test report of Gens ace battery from Jocke ericyao22 Batteries and Chargers 17 Jun 29, 2010 11:03 AM
