Old Sep 30, 2010, 02:18 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Gens Ace batteries from Hobbyparts
Hobbyparts has some new batteries called Gens Ace. (click Gens Ace on right of main page)
Looks like they are going to surplant the Blue Lipos maybe?
NOTE:
On my 25C pack, On the back, it says not to charge above 5C.
It also says Store Long Term at 3.4V per cell. I believe this to be WRONG! should be 3.85V per cell.
Ace Power Website
Actual Weights and measurements taken buy users (IR is when new and broken in):
6S
6s 3300mAh 25C (500 heli) : 544g 138mm x 45mm x 41mm This requires a 2010 Align 500 or a Battery Tray MOD to fit.
Average Internal resistance per cell = 2-3 milliohms (using iCharger 3016B)
6S 5300mAh 30C : 759g 139mm x 64mm x 43mm
Average internal resistance per cell = 1-2 millihoms
4S
4S 3300mAh 25C (warbirds) : 380g
Average internal resistance per cell = 2-3 milliohms (using iCharger 3016B)
Came with red cased HXT 4mm Bullet/Bananna jacks
3S
3S 2200mAh 25C : 192g 110mm x 25mm x 33mm.
Average Internal resistance per cell = 3-4 milliohms (using iCharger 3016B)
3S 1300mAh 25C : ??g 72mmx25mmx35mm
Average internal resistance per cell = 5 milliohms (using iCharger 3016B)
Melnic is offline Find More Posts by Melnic
Old Sep 30, 2010, 02:43 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
http://www.rcgroups.com/forums/showthread.php?t=1315730
If they prove to be of the same quality as the one that was sent to Charles for testing two months ago, bust out your credit card....
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 30, 2010, 03:07 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I talked to someone there (I got lucky as I was calling about something else). He said that the label says 5C max charge rate. They are working on posting pics. I know my nanotechs are 5C max charge rate and the 25C nantotech packs perform like 30C turnigy or blue lipos!
Old Oct 01, 2010, 01:58 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I found this link:
http://www.made-in-china.com/showroo...tery-Pack.html
Old Oct 01, 2010, 07:29 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
There is a link to source in first post of my GensAce 25c 3S2200 thread
http://www.rcgroups.com/forums/showthread.php?t=1283407
Old Oct 01, 2010, 11:05 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
So would you say there were comperable to the Nanotechs? or better/worse?
I saw that your sample Gens Ace batteries had Clone Deans, I'm told these have the bananna/bullets on them though.
Old Oct 02, 2010, 09:20 AM
Southern Pride
I would say that one should read my post on both and decide for themself.
http://www.rcgroups.com/forums/showp...8&postcount=41
One should also consider that I now have 134 cycles on the Gens Ace and it is still doing great while I have had the Turnigy only a very short time and have only 29 cycles only. Perhaps one should also search for other post by others on these.
Perhaps another point to conside is that Ace cells are almost perfectly matched even when discharged 95% and remain so after 100 cycles while Turnigy was mis matched from the very beginning. Others will likely point out that a sample of one means very little. This is some what true but then when most purchase a single Lipoly they expect it to be a s good as others of the same type. Few are willing to except the fact that they may have to deal with getting a occasional lower quality one.
Added: I just ran across this post which just happens to show I am not the only one to get a nano with a non balanced / matched cell.
http://www.rcgroups.com/forums/showp...&postcount=531
Perhaps not a big deal and it may be fine after a balanced charge however my qusetion is how does a cell get that much lower than the rest if it is indeed checked at the factory, they have a very high turn over rate (claimed over 30,000 per day) and was not damaged during pack assembly?
FYI My nano cells were perfectly balanced when received. Only monitored discharges showed the cell capacity mis match.
Charles
Old Oct 02, 2010, 05:12 PM
amigob is offline
Find More Posts by amigob
Netherlands
Joined May 2009
your not the only one, with unbalance in the nano
http://www.rcgroups.com/forums/showp...&postcount=449
Bart,
amigob is offline Find More Posts by amigob
Old Oct 03, 2010, 12:19 AM
Southern Pride
I know I saw your post same as I have seen numerious post on other HK LiPolys about new ones with cells below 3.5v etc. Most just say charge them and they will be fine. If they were other brands they would say make the dealer replace them. If a Thunder Power ,Hyperion,,PolyQuest or numerious other brands started going down hill that fast most would scream fool. If I post comments such as I just have some will say there Charles goes again running down / attacking HK LiPolys and that is the reason I only linked to that one post prior to your post. See what you did ,got things stirred up again. .
Charles
Old Oct 03, 2010, 12:24 AM
mickydee is online now
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi Charles,
If you needed to buy batteries and were plunking down you hard earned cash, would you go with Gens Ace, TP, Hypherion, etc?
I trust your opinion and am just curious.
Mickydee
mickydee is online now Find More Posts by mickydee
Old Oct 03, 2010, 04:07 AM
amigob is offline
Netherlands
Joined May 2009
I am going to order a nano tech again
because people where just saying that I had bad luck
I hoop I had,
Because they are cheap, but at the moment I don't believe it.
Bart,
Old Oct 03, 2010, 06:55 AM
TreeDiver is offline
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
Bad thing of HobbyCity is their quality control.
These GensAce have maybe a better quality control. So less risk to get a bad pack.
IMO we have a potential winner here, especially for USA RC people.
Looking forward to the first reports of fellow RC pilots about these GensAce packs.
TreeDiver is offline Find More Posts by TreeDiver
Old Oct 03, 2010, 09:22 PM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
I ordered a few so we will see
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Oct 04, 2010, 09:31 PM
rsasaki is offline
Find More Posts by rsasaki
They will soar on wings..
rsasaki's Avatar
USA, CA, Danville
Joined Aug 2004
Brief test
I just received a 3s-2200mAh 25C Gens Ace battery from Hobbypartz. Ordered Thursday, got it today. Weight: 193g.
Torque 2818/900
Turnigy 13x6 light electric wood
Emax / Hobbywing 60A esc
5 second run-up:
Gens Ace 2200 (new)
499.7W
11.54V
43.3A
Velocity Power 2200 (37 cycles)
460W
11.2V
41A
We will see how it performs over many more cycles, but it certainly looks interesting. Paid $22.02 with tax and free shipping.
Ron
rsasaki is offline Find More Posts by rsasaki
Old Oct 05, 2010, 03:58 AM
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
@Ron
Pack is also new.... and needs a few cycles to get loose.
Cool. The voltage under load is already very good.
Mini-Review New line of lipos - Gens Ace justerik Batteries and Chargers 5 Nov 10, 2010 09:07 AM
New Product HobbyPartz Gens Ace Lipos FieldofDreamsFlyer Batteries and Chargers 4 Oct 02, 2010 03:16 PM
Discussion Gens ace 5000mah 40C 2S Lipo battery ericyao22 Car Talk 2 Aug 14, 2010 04:00 AM
Discussion Test report of Gens ace battery from Jocke ericyao22 Batteries and Chargers 17 Jun 29, 2010 12:03 PM
