Closed Thread
This thread is privately moderated by Hightray, who may elect to delete unwanted replies.
Old Sep 29, 2010, 11:19 PM
Colorado, USA
Joined Sep 2010
Trader Rating: 0
Grayson Microjet V3 Motor and ESC
I am looking to sell the Grayson Microjet V3 motor with 30A Grayson ESC. All connectors, motor mount, screws, spinner, and 6x4 pusher prop included.
Everything you need to start rockin. Never used, just assembled. Found that it was something that I could not use with the size of my model.
$28.00 plus free shipping to you if you are in the United States.
Let me know if interested!
Motor:
Ni-Mh Battery:8 - 10 cells
Li-Po Battery: 2 / 3 cells
RPM per volt : 2200
Poles: 14
No Load Current / 10V: 2.05A
Max Current: 30A/60 sec
Dimension: 27.5x26
Shaft: 3.17mm
Weight: 34g
Recommended Max Propeller: 6x4 See Chart below
Recommended Model Weight: 200 - 500g (7oz to 22oz)
ESC:
Weight: 21.9 grams / 0.77 oz.
Use with Ni-Cd,Ni-Mh, Li-Ion, and Li-Poly batteries
Size: 32 x 24 x 9 mm
Auto throttle calibration
AUTO CELL DETECT!!!
BEC: 3 Amp (Suggested Use --> 2 Li-Poly=4 servos, 3 Li-Poly =3 servos)
Timing: Auto
High rate Switching: 8kHz
Auto Voltage cutoff Set at 3.0V A Cell Li-Poly 0.8 NiCd/NiMH
Brake: Programmable On/Off
Max RPM: 40,000 RPM with 14 pole motor
Auto shut down when signal is lost
Hightray is offline Find More Posts by Hightray
Old Oct 01, 2010, 09:21 AM
WesternFlyer's Avatar
USA, AZ, Chandler
Joined Mar 2007
Trader Rating: 141
PM sent
WesternFlyer is offline Find More Posts by WesternFlyer
Closed Thread
Mini-Review Grayson MicroJet V3 (39g, ~2300kv) Dr Kiwi Power Systems 24 Aug 09, 2010 11:44 AM
Discussion GH MicroJet V3 equivalent at HobbyKing pupeno Power Systems 1 Jul 29, 2010 08:41 PM
Sold Graysons MicroJet Combo (motor + esc) - $22 cutty01 Aircraft - Electric - Power Systems (FS/W) 2 May 07, 2010 01:07 AM
Discussion Grayson MicroJet V3 motoror similar Angus Sugna Power Systems 3 Mar 24, 2010 12:24 PM
Help! Functioning propeller for "GH MicroJet V3"? Vok_250 Power Systems 5 Jan 16, 2010 01:31 PM
