Old Sep 29, 2010, 01:56 PM
dlazarus6660 is offline
Find More Posts by dlazarus6660
If it flies, I crash it!
dlazarus6660's Avatar
United States, FL, Mary Esther
Joined Nov 2006
Build Log
Veco kit "The Warrior"
I bought this kit over the summer and I thought I would try to build or rebuild the fuse and tail feathers. I have most of the kit punched out parts but I need a few more and I could use a little help with some of the formers.
Please don't tell me I can buy the plans and or kit from(insert name here)
I know this already.
The wings are almost complete and they needed some minor repair.(all done)
I need the firewall and landing gear formers and the rear most former.
Also, I need the locations of said formers measured from the tail spacer.
Any help here.
dlazarus6660 is offline Find More Posts by dlazarus6660
Old Sep 29, 2010, 09:01 PM
The Kiwi is online now
Find More Posts by The Kiwi
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
Compared to the Chief, Smoothie, Thunderbird, and Tomahawk, I don't think that the Brave / Warrior pair were ever particularly popular. I doubt that a measurable number of currently active model people held onto any patterns for either of those Veco kits.
The Kiwi is online now Find More Posts by The Kiwi
Old Oct 02, 2010, 04:22 PM
jimgee1 is offline
Find More Posts by jimgee1
Joined Aug 2006
Seems if you don't want to search for plans, even if any are available, you're stuck to the TLAR (That Looks About Right) method of design. Good luck. I hope you complete it, fly it, and post some pics and/or video of the maiden flight.
Jim Gallagher
jimgee1 is offline Find More Posts by jimgee1
Old Oct 02, 2010, 10:14 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
As jimgee says, use the wing chord as a unit, the height of the fuse as another one, and guestimate. The tail should be about twice the chord, looks like.
this ain't museum scale...or rocket science....
howell
gwinhh is offline Find More Posts by gwinhh
Old Oct 03, 2010, 12:55 AM
greggles47 is offline
Find More Posts by greggles47
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
The front former can be as wide as the engine you are using. That is just make the bearers to suit your engine then the width of the bearers sets the width of the former.
Obviously the height of the fus at this location sets the former height.
There is probably no real need for a rear former. If you think the fus needs stiffening up, install some 1/8 or 3/16 sq to prevent the sides from caving in.
regards
Greg
greggles47 is offline Find More Posts by greggles47
Old Oct 03, 2010, 08:12 AM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
At one time I had drawings of the Warrior parts. I'll look and see if I still have them.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Oct 04, 2010, 05:48 AM
Joined Nov 2006
Thanks Jim!
Thanks Jim!
I would appreciate that.
I was hoping someone had traced the parts on the back of the plans or separately.
Daniel
Old Oct 05, 2010, 08:53 PM
I looked and did not find the Warrior drawings.
Old Oct 07, 2010, 10:19 AM
Joined Nov 2006
Thanks.
Thanks for looking, Jim. Maybe they will turn up someday. Keep me in mind if they do.
Daniel
Old Oct 08, 2010, 01:07 PM
realglow is offline
Find More Posts by realglow
Eat, Sleep, Fly!
realglow's Avatar
Joined Mar 2001
I built and flew most of the VECO stunt kits in the 1950's but do not have parts outlines of the Warrior. You should be able to get really close by looking at the plans....
Brings back lots of memories. Thanks.
James in eTEX
realglow is offline Find More Posts by realglow
Old Oct 09, 2010, 09:42 AM
Joined Nov 2006
Thanks James.
I'm leaning toward buying the plans from Tom Dixon Model Airplanes Plans.
http://tomdixon.tripod.com/plans.htm
Old Oct 09, 2010, 10:37 AM
Old Timer
The Kiwi's Avatar
Joined Jun 2010
Tom is keyboard-challenged. When you are ready to order, you will need to either telephone him, or use Snail-Mail, the old USPS route.
Kiwi
Old Oct 11, 2010, 07:07 AM
Joined Nov 2006
Thank you Kiwi
Thank you Kiwi.
I read that on his web site. Joe Wagner, the designer of The Warrior, still sells plans too!
Daniel
Old Oct 24, 2010, 07:01 AM
Joined Nov 2006
Plans
I bought the plans from Tom Dixon of the Veco Warrior.
I was a little disappointed when I open them.
I was expecting the fuse with the turtle deck and two cockpits.
Didn't happen.
It is plans of the early version.(?)
No turtle deck, just a solid 1/2" block of balsa(hollowed out) for the nose and the rear decking.
Also the formers are just a square former.
Looks like I'll have to draw my own fusalage plans on the backside of the Tom Dixon plans.
I wish Tom D. was more of an on-line kind of guy so I could discuss the issue I have.
Now what I really need is to find a complete Warrior kit and clone it.
Old Oct 24, 2010, 07:56 AM
Old Timer
The Kiwi's Avatar
Joined Jun 2010
I never built any of the mid-sized Vecos like the Warrior or Brave, although I had a Squaw at one time that I removed the badly damaged fuselage from and substituted a profile following the semi- P51 shape of the original Tomahawk (of which I had several). I believe that the Squaw had a built up turtledeck area.
The only difference I can recall between the Brave and Warrior was the addition of coupled wing flaps. If anyone can tell you which body style and kit version was which, between fully built up and semi-log, it would be Joe Wagner (I didn't mean which one of the Brave & Warrior named pair).
For Sale Wing Warrior RTF $90- REDUCED PRICE K_Heff Aircraft - Sailplanes (FS/W) 6 Sep 02, 2010 09:46 PM
For Sale Wing warrior 48" rtf K_Heff Aircraft - Sailplanes (FS/W) 6 Sep 02, 2010 09:35 AM
Wanted VECO 61 Carb VampeD4 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Aug 20, 2010 08:07 AM
For Sale RTF Wing Warrior 48" K_Heff Aircraft - Sailplanes (FS/W) 0 Aug 13, 2010 12:09 PM
Data .049 Snapper/ Veco Scout plans etc. dankar04 Control Line 0 Aug 05, 2010 04:30 PM
