Old Apr 09, 2012, 07:10 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Originally Posted by rcrich View Post
Lf what battery and esc are in it?
My current power setup:
Turnigy nano 1000mAh 3s 45/90c $10.47 USA warehouse
HK 25/30 A esc $9.23
Turnigy 2730-3000 motor $10.78
Turnigy 2730-3000 motor USA Fancy Foam $16.25
APC 4.75 x 4.75
leadfeather is online now Find More Posts by leadfeather
Old Apr 09, 2012, 08:03 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
I reall like and cant wait for some video! Do you think the cheap 9 gram servos by towerpro can hold up in this fast sled. Maybe need metal gear at this speed........
rcrich is offline Find More Posts by rcrich
Old Apr 09, 2012, 09:35 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Originally Posted by leadfeather View Post
I propped up to a 4.75 x 4.75 and took it out in the "calm before the storm". this evening. Top speed was clocked at 90mph!! I was thrilled to achieve this with a stock motor.
And there is still room for more speed with the stock motor, it still came down cold!
I would love to break 100 mph with a stock blue wonder motor.
Dan,
Thanks for the heads up on whats happening here. I am just getting a similar setup in a new F-16 prop jet I am working on.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Apr 10, 2012, 06:47 AM
Winging it >
Joined May 2006
Originally Posted by dz1sfb View Post
Dan,
Ken
Looks nice! Is this F-16 made from your new foam?
Old Apr 10, 2012, 07:19 AM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Yes it is!
Ken
Old Apr 10, 2012, 07:21 AM
Winging it >
Joined May 2006
Yes it is!
Ken
I wanna get a box of your foam. When do you anticipate it will be back in stock?
Old Apr 10, 2012, 08:59 AM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
We are getting a sample of the second production run either today or tomorrow for our approval. If we are able to okay it, probably within the next 3 weeks.
BTW that model there was made from a box of the seconds. That limited offer is an excellent deal.
Ken
Old Apr 10, 2012, 06:21 PM
Winging it >
Joined May 2006
I'm using the HXT 900 servos. I think they are up to the task. This plane is very pitch neutral so I don't think the servos are working much even at high speed.
On the power system and heat; I do not fly WOT (wide open throttle) all the time. For the speed runs, I set up an approach, full throttle for 4 or 5 seconds. Then during the pull up, I cut power and glide around for the next speed run. This is just the way I do it. It allows me to relax a little between the high adrenaline, low altitude, high speed passes. I think it is a lot easier on the power train too.
With the really thin wing I noticed the jet feels more skiddish at low speeds and actually "locks in" much better at high speed. Could be the thin airfoil or maybe due to the small-ish fin.
Old Apr 10, 2012, 06:39 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
I always love your designs LF. I just ordered some parts for this build and the motor is rated for 2 cells and it will be run at 3 cell is that really bad for it? Or is that why you only use it for 4-5 second bursts at full out.
Old Apr 10, 2012, 07:59 PM
Winging it >
Joined May 2006
Motors should be rated for amps or watts , not cell count. If you pull the same watts with 3s and a smaller prop compared to the watts pulled with 2s and a larger prop you should be fine. Always start conservatively and check (heat) as you go.
The short bursts of power and high speed cooling both will keep the motor from overheating... overheating is the main concern of pulling too much power.
Old Apr 10, 2012, 08:45 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
thanks understand now.
Old Apr 11, 2012, 07:31 AM
Winging it >
Joined May 2006
I want to prop up a little more still, since the motor is coming down cool and I want to explore the practical top limit of my current set up with a stock motor. I "think" I want more pitch but not more diameter. I'm considering cutting down a 6 x 5.5 prop to 4.5 x 5.5. Not sure if this is the right way to go... time to study up on props a little.
Old Apr 16, 2012, 09:10 PM
drainpipe is offline
Find More Posts by drainpipe
drainpipe's Avatar
Joined Dec 2011
motor mount
Can someone point me to a good motor mount for the Turnigy 2836-2350? It looks like some folks are using the GWS mounts. Is there any place in the US that stocks these?
drainpipe is offline Find More Posts by drainpipe
Old Apr 16, 2012, 09:37 PM
Winging it >
Joined May 2006
adreher's fast little 16" X-Raycer.
Adam's X-Raycer ....fast.... (2 min 44 sec)
Old Apr 16, 2012, 10:21 PM
compass is offline
Find More Posts by compass
compass's Avatar
USA, CA, Elk Grove
Joined Jan 2009
I bought both the Tee and L brackets here, and plan to try them out on my next X-Racyer. My GWS mounts seem to break often (yeah its me).
http://justgofly.com/Order%20Form.htm#Mounts
Compass
compass is offline Find More Posts by compass
New Product MACH1RC.COM, awesome graphics for the scratch builder, now announcing the "Shockwave" leadfeather Foamies (Scratchbuilt) 39 Nov 25, 2011 06:14 PM
Discussion Gaui X-5 At RCHobbyHelicopter.com johnIn2SonAZ Large Electric Helis 27 Jul 09, 2010 11:11 PM
Xray T1 Raycer with extras. machine Cars - Cars and Parts (FS/W) 0 Jun 02, 2004 01:37 PM
