Old Jul 06, 2003, 04:39 PM
jetset44 is offline
Find More Posts by jetset44
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Li-Po Cell Rupture
Got a question for the group. I recently bought a 3 cell 950 mAh Li-Po battery from Wild R/C for my IFO, but after only 2 charge/discharge cycles one of the cells ruptured and leaked a blue fluid inside the pack (see the attached picture). The voltage of the two good cells is still 4.1V, but the bad cell is down to only 1.6V. I used the popular Wes-Tech charger to charge the pack, at the 3 cell setting with a current of only 450 mAh.
Has anyone else experienced this kind of cell failure? Is this problem most likely due to a defective cell or could something have gone wrong while charging it? My IFO has the stock power system (Speed 280, 10x4.7 prop, 4:1 gearbox) and pulls 2.7 amps, which is only a 3C discharge rate for this pack. That should be well within the capability of the pack.
jetset44 is offline Find More Posts by jetset44
Old Jul 06, 2003, 05:20 PM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Well, using a semi-educated guess...
I'd say it was a cell failure.
Reasoning:
1. If it was the charger, it would have wiped out the entire pack.
2. If it was too heavy of an amp draw, again, would have wiped out the entire pack.
However, it could have been an unequalized pack charge from the factory, thus causing the failure as well. Were the packs assembled at the dealer, or the factory? That's what I'd be asking the dealer.
Have you brought this up with the company you bought it from? That would have been the immediate thing to do.
WJ
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Jul 07, 2003, 07:08 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
As with any product, there are inevitably going to be some people who experience a failure right off the bat. There is simply no way to assure that every product that leaves the factory is in perfect condition.
If you can find that you did nothing wrong, then you can only conclude that you received a defective cell. It happens.
mkirsch1 is offline Find More Posts by mkirsch1
Alert Bad TP Li-Po cell , With Photo tucson-01 Batteries and Chargers 26 May 25, 2004 08:44 AM
Brand new Poly-Quest Li-po cell recieved dead?? MAKODS Batteries and Chargers 5 May 20, 2004 12:03 PM
Tp Li-po Cell Internal Resistance hall woo Batteries and Chargers 2 Apr 09, 2004 06:53 PM
Can it be done? 3 gram outrunner on single li/po cell. Matthew Cotten Castle Creations 7 Mar 24, 2004 04:24 PM
Which li-po cell should be the next? eta Batteries and Chargers 3 Jan 08, 2004 05:30 AM
