Old May 12, 2011, 10:00 AM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by raz View Post
A friend I fly with lost signal to his Yak a couple times while using a DX7 radio system and both times when we were picking up the pieces the Rx was blinking instead of a steady light like it's supposed to be.
" I use a separate Bec, TX (DX6i) was at 5.3 volts. Batt was at 4 volts when I checked it."
I have no personal experience with Spekrum stuff, but I have read in numerous forms that 2.4 receivers do not like voltage any less than 4 volts..Especially Spekrum. Futaba says 3.5v minimum. Probably a good chance that under load, your voltage to the receiver was below 4volts and the receiver took a momentary "dump".
bamaguy is offline Find More Posts by bamaguy
Old May 12, 2011, 08:36 PM
Naval Warfare is offline
Find More Posts by Naval Warfare
Screw the wind, let's fly!
Naval Warfare's Avatar
United States, GA, Sautee Nacoochee
Joined Feb 2008
who's to say.I didnt have a screwdriver on me to disassemble it, and I had to pull the batt since I didnt know what may be about to burst into flames.
Sooooo, I have no idea if the rx was blinking or not. I've gotten all the way into an LVC state and not lost a spektrum signal.Especially with a ubec.
Naval Warfare is offline Find More Posts by Naval Warfare
Old May 13, 2011, 09:29 AM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Having a ubec in won't help at all if the Rx looses signal with the Tx and from the sounds of it I would guess that's what happened.
raz is offline Find More Posts by raz
Old May 13, 2011, 11:42 AM
Holtenbacker is offline
Find More Posts by Holtenbacker
Holtenbacker's Avatar
Modesto, California USA
Joined Jan 2004
Umm......Again. Spektrum at the scene of a who dunnit.
Holtenbacker is offline Find More Posts by Holtenbacker
Old May 15, 2011, 11:35 AM
sioannid is offline
Find More Posts by sioannid
Joined Jan 2011
Originally Posted by sioannid View Post
Dear friends I have a problem with one of my motors. My cessna came with two 30A escs. Yesterday, fortunately on the ground while testing, one of my motors started to loose and gain power then stop and start and making sounds like the esc was reseting. Then it started to make a constand beep, beep.
I disconnected and reconnected the battery and the problem persisted.
I searched the internet and I found a pdf file that explains how to program the esc with the transmiter, and I reprogrammed it. (the pdf works fine so I attached it).
The two motor start simultaneously, they even reach max RPM, but the problem persists.
Nothing gets hot or even warm since the problem happens at the beginning of the operation.
Is it the ESC or the motor?
Please help!
Stavros
Today I tested both escs and motors and one esc created the same problem with both motors, so I concluded that the esc was the problem.
Then I opened the shrink tube that was covering the bad esc to see if there was an obvious problem. The one of the two aluminium plates used to cool down the esc was too close to the nacked electric sircuitry and stuck in place with weak two sided adhesive film. I placed it correctly and covered the esc with the apropriate shrink tube.
Miracle!! The bad esc works fine again
I tested 3 batteries full throtle and everything works like a clock.
sioannid is offline Find More Posts by sioannid
Old May 16, 2011, 10:06 PM
Fast_Eddy is offline
Find More Posts by Fast_Eddy
Rc Flying is my Sanity!
Fast_Eddy's Avatar
United States, CA, San Jacinto
Joined Mar 2010
Only problem i came across on mine was that one of the esc's had a cold solder and some times would not power up. Re-soldered and all was well....
Fast_Eddy is offline Find More Posts by Fast_Eddy
Old May 17, 2011, 01:32 AM
Capt. Crunch is online now
Find More Posts by Capt. Crunch
It's all fun till Crunch!
Capt. Crunch's Avatar
InSane Diego
Joined Jan 2002
Does anyone on this thread know JakCharles personally?
If so what's happened tohim? several peeps have bought stuff and not received them yet.
Crunch
Capt. Crunch is online now Find More Posts by Capt. Crunch
Old May 19, 2011, 06:05 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
retracts options
what are a good inexpensive retract system that will work on this model.
THESANDMAN is offline Find More Posts by THESANDMAN
Old May 19, 2011, 07:28 PM
huntingfield is online now
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
Got my Dynam Grand Cruiser last week. I bought it from nitroplanes and it arrived undamaged. I love this plane, it takes off nicely and as had been mentioned in this thread, it requires a little power on to land. One of my motors is a bit noisy but runs fine. The nose landing gear strut bends quite easily at the mounting plate, it's easy to take out and straighten though. I also found that one of the aileron servos stopped working while I was tinkering with the control throws. I did some trouble shooting and found the supplied y-harness bad, replaced with Hitec harness. The Dynam 2.4 radio that I got with the plane doesn't bind to the reciever consistantly. I didn't trust this radio so I am using my Spektrum Dx6i, the Dynam radio can go in one of my other planes! I have also put slightly large diameter wheels on the plane to help when flying on our grass field. I plan to upgrade to retracts so I will also add a seperate BEC. Although I have made a few modification I would highly recommend this plane.
huntingfield is online now Find More Posts by huntingfield
Old May 20, 2011, 01:53 AM
hippojia is offline
Find More Posts by hippojia
Any 1 try this b4?
http://www.hobbyking.com/hobbyking/s...dProduct=15094
hippojia is offline Find More Posts by hippojia
Old May 20, 2011, 07:13 AM
whatala is online now
Find More Posts by whatala
San Jose, CA
Joined Sep 2003
not myself and this is for jet, I order another set from pw-rc for 52.00 including shipping.
whatala is online now Find More Posts by whatala
Old May 20, 2011, 06:34 PM
sanman55 is offline
Find More Posts by sanman55
sanman55's Avatar
powder springs georgia
Joined Nov 2003
Page 29- post 423- will get you started..$30 and a little work to make one stearable...or just go with whatala said for probably the best deal..and least work..still don't see how phillip does it ...he's the man
sanman55 is offline Find More Posts by sanman55
Old May 21, 2011, 07:26 AM
sanman55 is offline
sanman55's Avatar
Joined Nov 2003
one last time....
Sense this is the LAST day of earth think I will go flying one last time...If I owe anyone any money will pay you on Sunday
Old May 21, 2011, 07:48 AM
San Jose, CA
Joined Sep 2003
I will bring all my planes with me to the other side and fly
Old May 21, 2011, 01:37 PM
sanman55 is offline
sanman55's Avatar
Joined Nov 2003
Won't need them cause i will be flying myself....
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 05:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 07:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 12:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 04:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 09:41 PM
