Old Apr 20, 2011, 02:36 PM
sanman55 is offline
Find More Posts by sanman55
sanman55's Avatar
powder springs georgia
Joined Nov 2003
Originally Posted by sioannid View Post
For the metal part I used an old Allen 1,5mm wrench which I bent accordingly and glued it with 5min epoxy glue.
The plastic part I actually made it myself using a part from the body of my esky lama V4 as long as I was waiting for my order of the Nylon arms (look at the Pic).
Follow the link to find them: http://www.europemodels.eu/c_6_Model...ttings/page_3/
Very inovative....will keep that in mind.....
sanman55 is offline Find More Posts by sanman55
Old Apr 22, 2011, 06:44 AM
Naval Warfare is offline
Find More Posts by Naval Warfare
Screw the wind, let's fly!
Naval Warfare's Avatar
United States, GA, Sautee Nacoochee
Joined Feb 2008
Originally Posted by bamaguy View Post
At last, a day here in Northern Alabama without TStorms, Tornados, and/or 25+ mph winds! What a great little airplane! Three clicks of down and 3 clicks of right aileron and she was hands-off straight and level. Slows down real nice (I did not use flaps) for nice scale like landings-mains then nose gear.
Sanman55 is correct about the elevator being quite sensitive..even with -30% expo. Balanced her at 55mm. I did test the flaps at a few mistakes high (good thing, I did)....they have way too much lift, even though I had 20% down elevator mixed. Gonna work on that for another day. Any input from others who use their flaps would be most welcome.
Mine was the RTF version, as Nitro was out of stock on the ReceiverReady one. It came with a pair of Dynam 30amp ESC's. One ESC only caused the motor to "beep" rapidly and NOT rotate. I re-programmed it, which fixed the problem. Also the BEC's in each ESC were active and connected to the channel 3 lead. I cut off the center pins to isolate and disable the BEC output from both ESC's in the suppled Y harness and installed a spare Turnigy 3amp UBEC. BTW, using the supplied 3/blade props, and no washers added (yet) for additional downthrust. Seems to fly a bit faster than "scale speed", anyway...good enough for me!
Now that I know that she flys really well, I'll install the E-Retracts next week.
Congrats shipmate. She's a blast aint she.I never wouldve thought she was so docile.
Naval Warfare is offline Find More Posts by Naval Warfare
Old Apr 24, 2011, 11:07 AM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
retracts!
I got the retracts and have them installed, now I have to wait for better weather for the real test. These are from Hobby King. The base of the retract is too wide to fit in the preinstalled mounts though so those had to come out and I hot glued the retracts in.
http://www.youtube.com/watch?v=EJrIJQ606BI
raz is offline Find More Posts by raz
Old Apr 24, 2011, 06:04 PM
Joined Feb 2008
Very nice Ron. Got a link to em?
Old Apr 24, 2011, 06:42 PM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Why thank you Dale and fancy seeing you in here..lol Here they are.
http://www.hobbyking.com/hobbyking/s...dProduct=11301
http://www.hobbyking.com/hobbyking/s...dProduct=11302
Old Apr 24, 2011, 08:07 PM
robusp is offline
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
Guys,
I need honest answer.
Is it me and my mostly wot flying? Is it me doing rolls and loops? I am flying it just like war-bird in a dogfight.
Is anybody else FLYING this plane? Or just scale like flying?
I had three good flights today. That was after I strengthen the wing. I added spar in front and short one in the back, I ran some wide filament tape whole chord all the way between main gear.
On the forth flight I had to dial some elevator to keep the nose level.
I love the plane. Like the looks and sound. Performance wise its great too.
Rob
robusp is offline Find More Posts by robusp
Old Apr 24, 2011, 10:10 PM
celm is offline
Find More Posts by celm
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
Naval Warfare what hindges did you use for the flaps?
celm is offline Find More Posts by celm
Old Apr 24, 2011, 10:28 PM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Originally Posted by robusp View Post
Guys,
Rob
I like flying scale and this plane is perfect for that type of flying with big loops and slow rolls.
Old Apr 25, 2011, 04:59 AM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Hinges For Flaps
I used the hinges that were included with the plane. They work just fine.
bamaguy is offline Find More Posts by bamaguy
Old Apr 25, 2011, 05:15 AM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Guys,
Rob
For this type of plane, I prefer scale type of flight up to some "air show" flight manuvers that you might see when Bob Hoover would perform in his Aero Commander twin turbo.
For "dog fight antics, I'd get a P 51!
Old Apr 25, 2011, 07:44 AM
sanman55 is offline
sanman55's Avatar
Joined Nov 2003
If I want loops and flips and spins I too fly my mustang or my funjet..I keep this bird level and right side up It is a joy to fly. I did put in some carbon in the wings..they just looked too flimzy to me....
Old Apr 25, 2011, 08:00 AM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
has anyone tried the eflite retract kit on this plane?
Old Apr 25, 2011, 08:20 AM
robusp is offline
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
I guess I was expecting too much from it then.
I fly my planes all the same. Some just do it faster, some make tighter turns, some will stall, some land at walking pace, some land like shuttles, some do knife edge, some hover, some will fly all day inverted and so on.
I was thinking if you build a plane with almost unlimited vertical, you made a performance model it should handle basic loops and rolls.
Rob
Old Apr 25, 2011, 08:45 AM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Do a search on this thread, I think I remember someone did use them.
Old Apr 25, 2011, 11:25 AM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
i just placed the order for this plane,will go down to the LHF to buy the eflite retracts
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 05:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 07:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 12:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 04:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 09:41 PM
