Old Dec 21, 2010, 02:11 PM
Holtenbacker is offline
Find More Posts by Holtenbacker
Holtenbacker's Avatar
Modesto, California USA
Joined Jan 2004
Originally Posted by Fast_Eddy View Post
Dynam needs to make one of these planes!
And one of these
(we can blame it on Huggie)
Holtenbacker is offline Find More Posts by Holtenbacker
Old Dec 21, 2010, 02:22 PM
Fast_Eddy is offline
Find More Posts by Fast_Eddy
Rc Flying is my Sanity!
Fast_Eddy's Avatar
United States, CA, San Jacinto
Joined Mar 2010
Originally Posted by Holtenbacker View Post
And one of these
Oh yeah man!!!
I'll take one of those too!
That darn huggie
Always getting everybody in trouble..........
Fast_Eddy is offline Find More Posts by Fast_Eddy
Old Dec 21, 2010, 04:58 PM
kb5ixd is offline
Find More Posts by kb5ixd
United States, CO, Lakewood
Joined Sep 2010
another new twin
IF I had not got three (3) of the Dyman Grand Cruiser airframes already
I would be ordering two (2) of these --> http://www.nitroplanes.com/421scrcaitws.html
421 Scale RC Aircraft Twin-Engine Sky Trainer 46 - 71" Nitro/Electric Powered Remote Control Airplane ARF
It's really more the size I wanted BUT - Oh well
Guys weigh your Grand Cruiser's please - I would like to get a upper range that I have to work with - I am still worried I will need a bigger plane for my 30 minute fly time FPV set up.
Thanks in advance for your help
kb5ixd is offline Find More Posts by kb5ixd
Old Dec 21, 2010, 07:41 PM
Joined Jan 2004
Stock - 43 1/2 ounces
no flaps or retracts.
Old Dec 22, 2010, 11:52 AM
dbc is offline
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
kb5:
I'm afraid your never going to be able to achieve your goals of 30 min flight time and FPV with this plane.
Cruiser consumes about 200 mah per min in mixed flight. This would require more than a 6000 mah battery for 30 min. Two 3000 mah 3s would weigh about 21.5 oz and take up lots of space. There's no way this plane can accomodate them, nor fly with the additional 1.33 lbs of weight.
Something like this would stand a chance of fulfilling your requirements:
http://www.nitroplanes.com/90a268.html
Massive wing area and very light wing loading. I've got one and can tell that it would be able to lift lots of extra weight with no sweat.
30 minutes of powered electric flight (other than a glider) is difficult to achieve and will require a very light plane with a high lift wing and lots of wing area. The bigger scale twin that you're looking at is not really a very good candidate, either.
dbc is offline Find More Posts by dbc
Old Dec 22, 2010, 06:07 PM
kb5ixd is offline
Joined Sep 2010
Ya I was thinking to small - New Build - ordered or here now
421 Scale RC Aircraft Twin-Engine Sky Trainer 46 - 71" Electric Powered Remote Control Airplane ARF
Twin Engine Sky Trainer Fuel/Electric-Powered Radio Controlled RC Plane ARF
Wing Span: 71in / 1800mm Wing Area: 763 sq.in / 49.5 sq.dm Flying Weight: 11.0 lbs /5000g Fuselage Length: 62.6in / 1590mm Engine Required: 2c :0.40-0.46 x2 Radio Required: 6 channels ; 10-11 servos
1 Ea $199.00
Exceed-RC's Monster Power 46 (670kv) BrushlessMotor_63M54
OutRunner Powerful Brushless Motors give .10 to 1.60 size models the clean quiet convenience of electric power with an emphasis on power and durability. Pitted against any other their equivalent glow engine counterparts, these lightweight, high torque, hight output motors will more than satisfy the most power hungry pilot.
Model #: Monster Power 46 (63M54)
Kv: 670Kv
Input Watts: 800W
Resistance: .04 ohms
Idle Current: 3.90A
Continuous Current: 40A
Max Burst Current: 55A
Cells Ni-Cd/Ni-MH: 12-16
Cells Li-Po: 4-5
Weight: 12.2 oz (310g)
Overall Diameter: 2.0 in (50mm)
Shaft Diameter: .32 in (8mm)
Overall Length: 2.15 in (55mm)
2 EA $49.95
Turnigy 5000mAh 5S 20C Lipo Pack
Spec.
Minimum Capacity: 5000mAh
Configuration: 5S1P / 18.5v / 5Cell
Constant Discharge: 20C
Peak Discharge (10sec): 30C
Pack Weight: 666g
Pack Size: 149 x 48 x 42mm
Charge Plug: JST-XH
Discharge plug: 4mm Bullet-connnector
2 EA $41.39
51mm/ 2in FM04-403 Plastic Spinners
2 EA $3.00
Wooden Propellers: JXF JXF-12x6-Propeller
2 EA $8.00
Exceed-RC's Volcano/Proton Series 60A BrushlessESC_07E06-60A
brushless ESC are micro processor controlled and will work with all types of brushless motors. The Volcano Series brushless ESC can be used in airplanes, sailplanes, helicopters, or 3D helicopters. The controllers come pre-programmed and are ready to use when you receive them. Additional controller adjustments are available and can be accessed and adjusted with your transmitter and program card
Innovative Discharge Monitoring and Protection Design for real time battery pack monitor Multiple protection features: Low-voltage cut-off protection, over-heat protection, throttle signal loss protection
3 start modes: Normal / Soft / Super-Soft, compatible with fixed-wing aircrafts and helicopters
Throttle range can be configured and is fully compatible with all transmitters currently available on the market Smooth, linear and precise throttle response
Separate voltage regulator IC for the microprocessor
Supported motor speed (Maximum): 210000 RPM (2 poles), 70000 RPM (6 poles), 35000 RPM (12 poles)
Our pocket-sized Program Card can be purchased separately to provide easy programming to the ESC at the field. With a program card, you can activate the music playing function on the ESC
Model #: Volcano/Proton-60 (07E06)
Cont. Current: 60A
Burst Current (>10s): 80A
BEC Mode: Switch
BEC Output: 5V/3A
Li-ion/Li-poly: 2-6
Ni-MH/Ni-Cd: 5-18
Prgrammable: Yes
Weight: 60g
2 EA $59.95
Specifications:
Professional High Speed SG-5010 Servo
Dimensions: 1.57" x 0.79" x 1.44" (40 x 20 x 36.5mm)
Weight: 1.44oz (39g)
Operating Speed (4.8V no load) : 0.14sec / 60 degrees
Operating Speed (6.0V no load) : 0.11sec / 60 degrees
Stall Torque (4.8V): (8 kg/cm) (110oz/in.)
Stall Torque (6.0V): (11kg/cm) (156oz/in.)
Temperature Range: -30 to +60 Degree C
Dead Band Width: 4usec
Operation Voltage: 3.5 - 8.4Volts
Features:
- Coreless Motor
- Double Boll Bearing
- Light Weight
- Less Noise
- Connector Wire Length 300mm
12 EA $9.99
EC3 Battery Harness 14AWG for 2 Packs in Parallel
2 EA $3.38
Charging harness
Charging harness.
To suit most chargers, including iMAX, Bantam etc.
1 EA $3.52
HK-010 Wattmeter & Voltage Analyzer
HK-010 is compact and accurate wattmeter and power analyzer, but this one also includes an inbuilt balancer. Its robust alloy case make it a good carry-anywhere item.
Specification:
Working voltage range: 0-60V
Working current range: 0-100A
Power: 0-6000W
Cell count: 1-6S
Battery type: LiPo/LiFe/LiIon
Weight: 140g
Dimensions: 103x49.5x20mm
Working temperature range: -20~50C
1 EA $18.99
4A UBEC w/ Low Voltage horn
It can handle 4amp draw and comes with a low voltage warning buzzer. Should your pack drop to below 3V per cell the buzzer will sound, telling you its time to land your plane before you kill your expensive Lipo pack.
The UBEC comes with an extended section of PCB, you can use this to help mount the UBEC or you can simply cut it off.
Although this is a UBEC and can handle up to 23v, its warning system is only designed for 2cell. Some would consider using a UBEC for 2cell as overkill, however it ensures a stable current, less heat and a higher amperage can be used.
This UBEC can be used with up to 23v input. If you use a 2 cell pack only, it will also warn you if your cells drop to 3v per cell.
1 EA $11.25
ZIPPY Flightmax 3000mAh 3S1P 20C
Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the hobby market today!
Spec.
Capacity: 3000mAh
Voltage: 3S1P / 3 Cell / 11.1v
Discharge: 20C Constant / 30C Burst
Weight: 239g (including wire, plug & shrink wrap)
Dimensions: 137x45x18mm
Balance Plug: JST-XH
Discharge Plug: XT60
1 EA $13.41
FPV/ATV
one (1) Camera forward (KX-600SHQ)
One (1) Camera down (Sony 1/3" Super HAD Color CCD II) (still thinking)
KX-600SHQ Hi-RES CCD Camera
The KX-600SHQ is the newest addition to our camera family. It offers an unbelievable picture for its tiny
size. The KX-600SHQ is approximately 1/2 the size and weight of the popular KX-191H Camera, but offers an
extra 50 line of resolutions PAL or NTSC.
The KX-600SQL also incorporates impressive upgraded features such as 3D-Digital Noise Reduction, Wide Dynamic
Range Picture and OSD functionality. All this make the KX-600SHD the perfect camera for any FPV application.
PRODUCT DETAILS:
Sony 1/3 " Super HAD Color CCD II
600TVL Horizontal Resolution
On Screen Display (Pelco D)
3-D Digital Noise Reduction
Highlight Suppression BLC
Digital Zoom (Max. x32)
Sense-Up Function (Max. x256)
8-Zone Privacy Masking
Digital Day & Night Function
Digital Wide Dynamic Range
Freeze / Mirror / V-Flip / Rotate
Fast Shutter Speed (1/60 ~ 1/100,000)
Adjustable Sharpness & Brightness
Supports 12VDC Power Supply
Lens: 3.6mm
1 EA $129.95
500mW RX/ TX Set [900MHz]
Our medium power 500mW, 900Mhz transmitter is a excellent balance of power and range performance in the
900MHz band. This revised version of the transmitter set is half the weight of the former version in the god case. This transmitter weighs in at 31 grams. It also offers phase lock loop technology to lock on it's channel and minimize drift.
The 900MHz Receiver comes complete with standard whip antennas, power connector and AV cables. It is able to
receive on 12 selectable channels, 4 channels in three different frequencies (900MHz, 1.3GHz & 2.4GHz).
PRODUCT DETAIL:
4 channel 900MHz, 500mW transmitter (US 910Ghz only)
12 channel Phase Lock Loop receiver
Transmitter weight = 31 grams
WHATS IN THE BOX:
900MHz, 500mW Transmitter
RX & TX omni directional whip antennas
12 channel receiver
Power connector
RCA Cables
1 EA $110.95
900MHZ 1500mW Tx/Rx & 1/3-inch CCD Camera NTSC
12 Channel 900Mhz Tx/Rx video system with CCD camera.
A high power 1500mW Tx on 900mHz ensures a very long signal range!
Unlike other generic systems, we have produced a wiring loom and included it with the camera so that the Tx and camera will be compatible and on the same voltage.
Included.
1 x SONY CCD 1/3inch Camera
1 x 900Mhz 8 channel Video Transmitter (1500mW) (turned down to 950mw)
1 x 900Mhz 12 channel Video Receiver
Camera spec.
CCD sensor type:1/3 color SONY CCD
Pixel;
NTSC: 510(H)*492(V)
Scanning system: Interlaced scanning
Synchronization: System:Inter
Horizontal resolution: 420TV line
Minimum Illumination 0.01LUX/F1.2
DSP+CCD: CXD3142R+405AK
S/N Ratio: 48dB
Gamma Modification: 0.45
White balance: Auto
Auto backlight compensation: Auto
Lens: 3.6MM
Audio: No
Input voltage: 9~12.6V
Electric current 80MA
Electronic Shutter: 1/50 (60) ~ 1/100,000s
Video output: 1.0VP-P composite video
Operation Temp.: -20~50
Flight time: Approx 60min/100mah 3S
FPV Tx Spec.
Channel: 8-Ch, AV synchronization
Power: 1500mW
Input voltage: 12V
Weight: 18g
Frequency: 0.9G 0.910G,0.980G,1.010G,1.040G
1 EA $105.50
Retacts and lights to come
Comments welcome - I also have two (2) Grand Cruiser's in the box to offer someone (Grayson's ARF's) - lol
I will be starting a new thread on this build...
Old Dec 24, 2010, 11:24 PM
kasra is offline
Find More Posts by kasra
Palo Alto, CA, USA
Joined Nov 2000
I just finished installing the E-flite retracts on the Cessna. Now I can't stop doing touch and go's. The plane's flying behavior did not change much as far as I can tell. Here is a video my good friend Don took yesterday at RSA.
Kasra and the Twin at RSA (2 min 1 sec)
kasra is offline Find More Posts by kasra
Latest blog entry: Car Show
Old Dec 25, 2010, 03:15 PM
dno264 is offline
Find More Posts by dno264
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Nice video Kasra. I like how you can float it in on landing.
-David
dno264 is offline Find More Posts by dno264
Old Dec 26, 2010, 09:34 AM
maguro is online now
Find More Posts by maguro
OpenTX University Staff
maguro's Avatar
United States, DE, Bear
Joined Apr 2007
Opened the C-310 yesterday. The foam on this plane feels so slick. Does it need to be cleaned with something like alcohol before applying the decals? What about gluing? I know epoxy works on this foam, will RC-56 canopy glue work? Any special prep first? (
The fuselage arrived with the windshield caved in, so I had to remove it to get it straightened out. Now I have to get rid of the rubber cement and reattach the windshield.)
Roger
maguro is online now Find More Posts by maguro
Old Dec 29, 2010, 10:06 PM
Fast_Eddy's Avatar
Joined Mar 2010
Roger
The glue that comes with it works great! I have to agree, the foam is really nice and smooth. They did a nice job on it.
On a Holiday note,
Santa gave me a battery for Christmas so im now up to 4 for the 310!!!
Old Dec 29, 2010, 10:33 PM
huggie9999 is offline
Find More Posts by huggie9999
Ex-President @ HMM
huggie9999's Avatar
United States, CA, Hemet
Joined Oct 2006
On a Holiday note,
Your wife gave you a battery for the plane she hates????????
huggie9999 is offline Find More Posts by huggie9999
Old Dec 29, 2010, 10:40 PM
Fast_Eddy's Avatar
Joined Mar 2010
LOL.......
No, My step son did........
Old Dec 30, 2010, 12:23 AM
robusp is offline
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
I ran it couple of days now with skis. What a riot!
I like this plane more and more.
I will try it tomorrow with 1 pusher and 1 tractor prop. Right now with 2 tractors it will bank on take off. I would like to see it take off on 50% power, gentle climb and no aileron or rudder input.
Rob
robusp is offline Find More Posts by robusp
Old Dec 30, 2010, 12:30 AM
Joined Jan 2004
want some video on skis
was thinking of floats. just for giggles
Old Dec 30, 2010, 09:38 PM
Fast_Eddy's Avatar
Joined Mar 2010
I would like to see that too!
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 05:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 07:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 12:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 04:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 09:41 PM
