Old Feb 15, 2013, 10:13 PM
sporn is offline
Find More Posts by sporn
Joined Aug 2007
Yes, I was wondering about a BEC. Do the two parallel ESCs provide more security already?
sporn is offline Find More Posts by sporn
Old Feb 16, 2013, 05:07 AM
dbc is online now
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
In theory, if the BEC's are linear and not switch mode - which these are - the paralleling of them is acceptable and will result in some additional current capability. That's what I'm told.
I've gotten hundreds of flights on mine, all stock with flaps added, and had absolutely no problems. I did recently add a CF wing spar just for insurance. It's one of my favorite planes
dbc is online now Find More Posts by dbc
Old Feb 16, 2013, 09:03 AM
captain MoMo is offline
Find More Posts by captain MoMo
Mach One
captain MoMo's Avatar
Joined Apr 2011
Originally Posted by Joker 53150 View Post
That's what I was hoping to hear, minimal upgrades needed. I've got the servos for the flaps already although it sounds like most don't bother with them. A BEC isn't a must with all the servos and retracts? This will be my first plane with more than 4 channels.
Ok
I have added the flaps and the CF on the main wing. I have also put some fiberglass rebar tape under the tail wing along the length to reinforce it. Yesterday I flew her and did some loops and rolls. I lost her with the white clouds in the background for a good 10 seconds and thought it was over but she is so stable that she was flying the same straight line! I found her and resumed. Tip: don't have a heated conversation when flying!
captain MoMo is offline Find More Posts by captain MoMo
Old Feb 16, 2013, 06:26 PM
Charley38 is online now
Find More Posts by Charley38
United States, TX, Kerrville
Joined Oct 2003
Originally Posted by Naval Warfare View Post
I finally got my HK 480 1320's installed. (They took so long to get here I almost forgot I'd ordered them.) Wow! It was def worth the 50 bucks.
It took her from a pussy cat to a tiger. I can now turn her with authority rather than pucker when she was in a turn, and see the dreaded wing waggle.
Hi Nav,
Had to search you out since you're not posting about DF airliners these days.
That twin flight looks good but yer hammerin' it! Looks like some of my maiden flights. UH, why no landing vid?
I'm putting together a Freewing Mosquito right now. The LG doors are a PITA! I'm gettin' there slowly. Always wanted to try a twin and with electrics we have a reliable option.
Shoot me a PM if you feel like it. Lookin' forward to it.....
CR
Charley38 is online now Find More Posts by Charley38
Old Feb 16, 2013, 07:18 PM
dahawk47 is online now
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Has anyone glued the wing to the fuse? When mine went into the reeds after completely losing elevator, 3 out of the 4 bolt mounts ripped out. No other damage. I was lucky.
Thinking that since my car is big enough for transporting the plane fully assembled, might as well epoxy the wing to the fuse.
I suppose if I ever need to get at the wiring, I could remove a window from the top.
Any other downside I'm missing?
-Hawk
dahawk47 is online now Find More Posts by dahawk47
Old Feb 19, 2013, 06:17 PM
NOTAR 600 is offline
Find More Posts by NOTAR 600
ohio usa
NOTAR 600's Avatar
Joined Nov 2007
-Hawk
I'm not sure Hawk. I mean with the bolts taking most of the force, the damage seems somewhat minimal. With the wing glued on....another crash could possibly damage both the wing and fuselage. Just my two cents.
NOTAR 600 is offline Find More Posts by NOTAR 600
Old Feb 19, 2013, 06:41 PM
Joker 53150 is offline
Find More Posts by Joker 53150
Joker 53150's Avatar
United States, WI, Muskego
Joined Sep 2012
A special delivery came from UPS today! Some minor box damage, but no visible damage to any of the contents. I assembled the main components and hooked up the electronics to make sure everything works, and no problems found. Next step is to take it back apart and assemble it for real, with the required upgrades so it's ready for flight in a month or so.
Looking at the stark white plane has me thinking of how to make it special. Does paint hold up well on this foam, or are the vinyl decals a stronger option? With paint I know I can always touch it up and getting around the compound curves isn't a problem...
Joker 53150 is offline Find More Posts by Joker 53150
MJF is offline
MJF
Find More Posts by MJF
MJF
Waiting Fer Da SEFF
MJF's Avatar
United States, GA, Perry
Joined Jul 2010
Picking up used non retract version this week-end...
can't wait to give it a go..
MJF is offline Find More Posts by MJF
Latest blog entry: eflite ultimate 20-300
Old Feb 19, 2013, 06:47 PM
Hollywood2979 is offline
Find More Posts by Hollywood2979
Hollywood2979's Avatar
United States, TX, Cibolo
Joined Nov 2011
I'm painting mine now that I have flown it, and put a spar in it. Gonna use regular craft store paint, so foam doesn't get eaten up, fastkote works well to and is water base.
Hollywood2979 is offline Find More Posts by Hollywood2979
Old Feb 19, 2013, 06:55 PM
doug.wagner is offline
Find More Posts by doug.wagner
I can fix that!
doug.wagner's Avatar
United States, ME, Bangor
Joined Jul 2011
If I had it to do over again, and had the time, I would paint the trim instead of using the stickers. They don't conform well to the compound curves, no matter how many times I flatten them with my thumb.
I now understand how my mom must have felt trying to get my cowlick to stay flat!
doug.wagner is offline Find More Posts by doug.wagner
Old Feb 19, 2013, 09:25 PM
DriverRX8 is offline
Find More Posts by DriverRX8
Brain/Thumb Interlock Off
DriverRX8's Avatar
Joined Mar 2011
I've only had mixed success painting these EPO airplanes. Paint just doesn't want to stick - which is why most models come with vinyl stickers. It's impossible, by my experience, to paint one color and then mask it with tape to apply overlapping colors. The mask tape pulls everything off. The paint also tends to peel, flake, and chip just by looking at it, especially on large areas that flex (wings). I have had fairly good luck with Krylon Fusion For Plastic spray paint. It will chip on you a little, but has been pretty durable by my experience. Again, though, forget overlapping colors that require mask tape over the first color.
I actually found the GC stickers to fit pretty well, with the exception of the wingtip tanks. You probably already know the trick, but I'll repeat it for other's edification: Spray a little soapy water on the airplane before you apply the stickers. It will allow you to re-position them and move them around to get them in the right place. Once you have them positioned, squeegee the water out from under the sticker with your finger, and let it dry. Works like a champ!
DriverRX8 is offline Find More Posts by DriverRX8
Old Feb 19, 2013, 10:16 PM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
I've painted a complete foam airplane with model masters enamel paint and I thin my paints with lacquer thinner. I used an airbrush so I do believe that makes a difference, I wouldn't recommend spraying a foam plane with rattle can lacquer paint. I've used rattle can enamel without any problems.
If you need to mask off an area take damp newspaper or paper towels and use them in place of the masking tape.
I've haven't had any issues with the paint flaking off. One of my painted planes has 2 years on the paint and other than normal hanger rash the paint has held up just fine.
Herman Munster is offline Find More Posts by Herman Munster
Old Feb 20, 2013, 06:50 AM
rcflyinff is online now
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL, Titusville
Joined Mar 2012
I've painted a few planes and pretty much have had your same experience. I used Krylon Short Cuts paint that's made for foam. Thought it would stick better. Wrong. Still chips & flakes off. Not sure what the solution is
rcflyinff is online now Find More Posts by rcflyinff
Old Feb 20, 2013, 01:13 PM
Joined Sep 2012
Anybody care to share their DR/expo settings for both scale and sport flying? I'm setting up my ER9X and would like a good general baseline to start from. Also, any mix for elevator and/or rudder useful or is this plane really as easy to fly as people claim?
Old Feb 20, 2013, 05:58 PM
I can fix that!
Joined Jul 2011
I had good luck painting my HZ Super Cub by lightly sanding the entire surface (I think I used 320 grit wet sanded). My main intention was to smooth out the the little bumps that I assume are used to release the foam parts from their molds. The real benefit of the sanding though is increased adhesion of the paints. I haven't lost any paint on the sanded areas except during the learning process where I changed my masking technique from low-tack tape to damp newspaper. I used el-cheapo rattle cans from Home Depot. Rustoleum, I think.
The paint did little to hide the alligator skin effect, and probably accentuated it with the year of abuse that that poor plane has taken. There are thin cracks in the paint around the perimeters of the tiny foam pellets that make up the surface. A more flexible, latex paint might have aged better. I'll try latex next time.
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 05:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 07:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 12:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 04:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 09:41 PM
