Old Feb 09, 2013, 08:41 AM
High Voltage
shock's Avatar
Motorcity
Joined Sep 2010
Mine came with 30a esc , 1100kv motors stock.
Its now running 40a esc , 1250kv motors with 8x6 2 blade apc props.
I also use a 3 cell, 2600mah, 55c battery. I can literally take off in about 3 feet of runway.
shock is offline Find More Posts by shock
Old Feb 09, 2013, 09:58 AM
United States, FL
Joined Mar 2012
Finally powered her up yesterday and had a heck of a vibration Took the spinners off and that seemed to fix the problem. Will plan on maidening without them for now if the weather cooperates. I've read about the spinners needing to be balanced, but I have no idea how to check or balance them. Any help would be appreciated.
rcflyinff is offline Find More Posts by rcflyinff
Old Feb 09, 2013, 11:58 AM
United States, MD
Joined Apr 2011
Are you using the stock plastic spinners? They are light and in my opinion unlikely cause cause of bad vibrations. They will help increase vibs from the slightly bent shaft or bad bearings in the motor. So, I would check the shafts on both motors and rotate them to see if the bearings are bad or not.
captain MoMo is offline Find More Posts by captain MoMo
Old Feb 09, 2013, 01:14 PM
United States, FL
Joined Mar 2012
Thanks Capt. Yesterday was the first time the motors were powered up. I would hope that the new motors were true, but I guess anything is possible. Once I removed the spinners, the motors seemed to be smooth. Looked at the props at different angles while they were running and didn't notice and wobble or vibration. Do you know of any good spinners that would mount up to the stock motors?
Old Feb 09, 2013, 01:59 PM
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
Just maidened in -4c temperature and 10 to 15mph winds. Very stable and flew beautiful. Gear cycled no problem so not sure what the other guy had issues with at 65f. It does have good stock power. Landings are a breeze to grease in.
gewiens is offline Find More Posts by gewiens
Old Feb 09, 2013, 05:20 PM
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
The spinners that come with the GC are basically junk. I suppose you could possibly balance them. It's done similar to balancing a prop. Just put it on a prop balancer and lightly spin it and see where it stops. The heavy side will normally be on the bottom when it stops. spin it several times to confirm the heavy side and then start adding weight to the opposite side, a little at a time, until the spinner stops randomly and not at the same spot every time.
Herman Munster is online now Find More Posts by Herman Munster
Old Feb 09, 2013, 05:55 PM
OldeMan's Avatar
United States, AZ, Gilbert
Joined Jul 2012
Maidened my new Cruiser today and must say -- I am extremely impressed -- what a terrific plane! Everything "stock" for me, right now, with one addition: a Guardian 2D/3D stabilizer. Today was a particularly gusty day, too, so the backup was appreciated. However, experimenting with the Guardian on and off, it was clear the plane didn't need much help.
Thrust-to-weight was almost exactly 1:1... more than enough to twist, spin, and loop to my heart's content. The retractable gear did really well in grass too.
All in all, I had a blast.
OldeMan is offline Find More Posts by OldeMan
Old Feb 09, 2013, 11:35 PM
Joined Aug 2007
http://www.hobbyking.com/hobbyking/s...00kv_560w.html
Just installed two of these motors with counter rotation. Will be using 2 1600mah 4s batteries parallel and two 65A escs, 8x6 apc props. Should give me about 1000 watts total.
Waiting for the winds to calm down.
sporn is offline Find More Posts by sporn
Old Feb 09, 2013, 11:43 PM
Look Up!
gewiens's Avatar
Joined Apr 2008
So how do they fit? No shimming or anything needed? Gonna be changing mine soon and just curious.
Old Feb 09, 2013, 11:58 PM
Joined Aug 2007
I had to drill new holes in the firewall and shave just a little bit of foam from the engine covers. Otherwise they fit perfectly.
I also load my 2 batteries through the cockpit window and slide them underneath my pilots. I use regular scotch tape as a hinge . Easier than loading from below.
Other mods include additional wing spar, 4 navigation lights, flap speed reducer, bigger wheels
My all up weight is probably about 1700 g vs. 1200g stock.
Old Feb 10, 2013, 12:03 AM
Look Up!
gewiens's Avatar
Joined Apr 2008
Cool. Good to know. I put some 2" lite flite wheels on mine now to soak up bumps. Going to order motors tonight.
Old Feb 10, 2013, 01:21 AM
Joined Nov 2007
Wow, that's a lot of extra weight for a plane this size
Old Feb 10, 2013, 01:41 AM
United States, MD
Joined Apr 2011
Read through this thread. On some kits the landing servoless gears act funny at low temperatures. I can't explain why but mine did the same. I just replaced mine with another manufacture and no longer had any problems since. In fact, I had the same issue with the landing gear on my Dynam Turbojet, another fine model by the way.
Old Feb 10, 2013, 02:24 AM
Look Up!
gewiens's Avatar
Joined Apr 2008
No harm intended bud. Mine are not having issues so i'm happy. Had 2 more flights after that post and even cycled the gear a couple of times during flight and no issues. Super impressed with this bird. The twin engine addiction has started today.
Old Feb 10, 2013, 09:47 AM
United States, MD
Joined Apr 2011
That's fantastic. So they must have corrected whatever problem they had. Enjoy, it's one of my favorites. Try the Turbojet a well if you like this one!
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 05:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 07:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 12:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 04:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 09:41 PM
